標(biāo)題: 1602顯示漢字(年月日)走時的時鐘程序 [打印本頁]
作者: 大哥大雷神    時間: 2016-11-14 21:01
功能                :1602顯示漢字(年月日)走時
QQ                        :863888999
測試單片機        :STC89C52RC
外部晶振        :11.0592M
調(diào)試環(huán)境        :KEIL3
調(diào)試硬件平臺:使用 清翔電子科技 QX-MCS51單片機開發(fā)板測試通過
備注                :張強提供
日期                :
文件名                :
        //-------------------------程序功能-------------------------//
        利用定時器0走時,1602顯示,按鍵可調(diào)時間。
        //---------------------------備注---------------------------//
        //-------------------------使用說明-------------------------//
         硬件平臺:QX-X3;
         KEY13選擇調(diào)節(jié)時分秒,KEY14加,KEY15減。
         硬件平臺:QX-MCS;
         S2選擇調(diào)節(jié)時分秒,S3加,S4減,S5確認(rèn)。
#include <reg52.h>
#define uint  unsigned int
sbit lcdrs  = P3^5;        //液晶引腳定義
sbit led_cs = P3^6;
sbit lcden  = P3^4;
sbit dx = P2^7;//數(shù)碼管引腳定義
sbit wx = P2^6;
sbit key1 = P3^0;
sbit key2 = P3^1;
sbit key3 = P3^2;
sbit keyE = P3^3;
uchar num,key1num,count, hour=14,min=0,sec=0,year=16,month=3,day=1;
uchar code cg_1602[]={ 0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,
0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00,
0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00};//"年月日"
/*uchar week[][3]={"   ","Mon","Tue","Wen","Thi","Fri","Sta","Sun"};*/
/*延時函數(shù)*/
void delay(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
        for(j=114;j>0;j--);
/*1602液晶*/
void write_com(uchar com)//寫命令
        lcdrs=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)//寫數(shù)據(jù)
        lcdrs=1;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_by_xy(uchar x,uchar y)//坐標(biāo)定位
        uchar address;
        if(y==0)
        address=0x80+x;//y=0,寫第一行
        address=0xc0+x;//y=1,寫第二行
        write_com(address);
/*void write_char(uchar x,uchar y,uchar date)//坐標(biāo)定位顯示
        write_by_xy(x,y);//先定位
        write_data(date);//后寫數(shù)
void write_string(uchar x,uchar y,uchar *s)//寫字符串(這個指針還不大懂啊)
        write_by_xy(x,y);//設(shè)定顯示位置
        while(*s)//write character
        P0=*s;
        write_data(*s);
        s++;
void write_sfm(uchar add,uchar date)//寫時分秒函數(shù)
        uchar hour,ge;
        hour=date/10;//分解一個2位數(shù)的十位和個位
        ge=date%10;
        write_com(0x80+0x40+add);//設(shè)置顯示位置
        write_data(0x30+hour);//送去液晶顯示十位
        write_data(0x30+ge); //送去液晶顯示個位
void write_ymd(uchar add,uchar date)//寫年月日函數(shù)
  uchar hour, ge;
  hour=date/10;
  ge=date;
  write_com(0x80+add);
void write_cg()//寫入固定漢字和符號
        write_com(0x40); //設(shè)定CGRAM地址
        for(num=0;num<24;num++) //將自定義字型碼寫入CGRAM中
                write_data(cg_1602[num]);
        write_com(0x84);//年
                write_data(0);
        write_com(0x87);//月
                write_data(1);
        write_com(0x8a);//日
                write_data(2);
        write_string(2,1,":");
        write_string(5,1,":");
        write_string(9,1,"");
void init_1602()//初始化
        dx=0;wx=0;led_cs=0;
        hour=22;min=33;sec=55;key1num=0;count=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_string(0,0,"2016");
        write_string(5,0,"03");
        write_string(8,0,"01");
        write_sfm(0,hour);
        write_sfm(3,min);
        write_sfm(6,sec);
        write_sfm(4,year);
        write_sfm(7,month);
    write_sfm(10,day);
        write_cg();
        TMOD=0x01;//設(shè)置定時器0工作模式1
        TH0=(65536-50000)/256;//定時器裝初值
        TL0=(65536-50000)%256;
        EA=1; //開總中斷
        ET0=1; //開定時器0中斷
        TR0=1; //啟動定時器0
int is(uchar year)
int temp=20*100+year;
if((temp%4==0&&temp!=0)||(temp&&0==0))
return 1;
return 0;
/*鍵盤掃描函數(shù)*/
void keyscan()//按鍵掃描函數(shù)
        keyE =0;
        if(key1==0)
                delay(5);
                if(key1==0)//確認(rèn)功能鍵被按下
                        key1num++;//功能鍵按下次數(shù)記錄
                        while(!key1);//釋放確認(rèn)
                        if(key1num==1)//第一次被按下時
                                TR0=0; //關(guān)閉定時器
                                write_com(0x80+0x40+7);//光標(biāo)定位到秒位置
                                write_com(0x0f); //光標(biāo)開始閃爍
                        if(key1num==2)//第二次按下光標(biāo)閃爍定位到分鐘位置
                                write_com(0x80+0x40+4);
                        if(key1num==3)//第三次按下光標(biāo)閃爍定位到小時位置
                                write_com(0x80+0x40+1);
                        if(key1num==4)//第四次按下光標(biāo)閃爍定位到日位置
                                write_com(0x89);
                        if(key1num==5)//第五次按下光標(biāo)閃爍定位到月位置
                           write_com(0x86);
                          if(key1num==6)//第六次按下光標(biāo)閃爍定位到年位置
                           write_com(0x83);
                        if(key1num==7)//第四次按下
                                key1num=0;//記錄按鍵數(shù)清零
                                write_com(0x0c);//取消光標(biāo)閃爍
                                TR0=1; //啟動定時器使時鐘開始走
        if(key1num!=0)//只有功能鍵被按下后,增加和減小鍵才有效
                if(key2==0)
                        delay(5);
                        if(key2==0)//增加鍵確認(rèn)被按下
                                while(!key2);//按鍵釋放
                                if(key1num==1)//若功能鍵第一次按下
                                        sec++; //則調(diào)整秒加1
                                        if(sec==60)//若滿60后將清零
                                        sec=0;
                                        write_sfm(6,sec);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+0x40+7);//顯示位置重新回到調(diào)節(jié)處
                                if(key1num==2)//若功能鍵第二次按下
                                        min++;//則調(diào)整分鐘加1
                                        if(min==60)//若滿60后將清零
                                        min=0;
                                        write_sfm(3,min);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+0x40+4);//顯示位置重新回到調(diào)節(jié)處
                                if(key1num==3)//若功能鍵第三次按下
                                        hour++;//則調(diào)整小時加1
                                        if(hour==24)//若滿24后將清零
                                        hour=0;
                                        write_sfm(0,hour);;//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x80+0x40+1);//顯示位置重新回到調(diào)節(jié)處
                                if(key1num==4)//若功能鍵第四次按下
                                        day++;//則調(diào)整日加1
                                        if(day==31)//若滿31后將清零
                                    day=0;
                                        write_sfm(10,day);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x89);//顯示位置重新回到調(diào)節(jié)處
                                if(key1num==5)//若功能鍵第五次按下
                                        month++;//則調(diào)整月加1
                                        if(day==12)//若滿12后將清零
                                    day=0;
                                        write_sfm(7,month);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x86);//顯示位置重新回到調(diào)節(jié)處
                                if(key1num==6)//若功能鍵第五次按下
                                        year++;//則調(diào)整年加1
                                        if(year==100)//若滿100后將清零
                                    year=0;
                                        write_sfm(4,year);//每調(diào)節(jié)一次送液晶顯示一下
                                        write_com(0x83);//顯示位置重新回到調(diào)節(jié)處
                if(key3==0)
                        delay(5);
                        if(key3==0)//確認(rèn)減小鍵被按下
                                while(!key3);//按鍵釋放
                                        sec--;//則調(diào)整秒減1
                                        if(sec==-1)//若減到負(fù)數(shù)則將其重新設(shè)置為59
                                                sec=59;
                                        min--;//則調(diào)整分鐘減1
                                        if(min==-1)//若減到負(fù)數(shù)則將其重新設(shè)置為59
                                                min=59;
                                if(key1num==3)//若功能鍵第二次按下
                                        hour--;//則調(diào)整小時減1
                                        if(hour==-1)//若減到負(fù)數(shù)則將其重新設(shè)置為23
                                                hour=23;
                                        write_sfm(0,hour);//每調(diào)節(jié)一次送液晶顯示一下
/*主函數(shù)*/
        dx=0;wx=0;led_cs=0;
        init_1602();
                keyscan();
/*中斷函數(shù)*/
void timer0() interrupt 1//定時器0中斷服務(wù)程序
        TH0=(65536-50000)/256;//再次裝定時器初值
        count++; //中斷次數(shù)累加
        if(count==20) //20次50毫秒為1秒
                count=0;
                sec++;
                if(sec==60)//秒加到60則進位分鐘
                        sec=0;//同時秒數(shù)清零
                        min++;
                        if(min==60)//分鐘加到60則進位小時
                                min=0;//同時分鐘數(shù)清零
                                hour++;
                                if(hour==24)//小時加到24則小時清零
                                        hour=0;
                                write_sfm(0,hour);//小時若變化則重新寫入
                        write_sfm(3,min);//分鐘若變化則重新寫入
                write_sfm(6,sec);//秒若變化則重新寫入
作者: zombie2345    時間: 2016-11-18 16:16
謝謝樓主 學(xué)習(xí)一下
