標題: RLC電阻電容電感測量儀Proteus仿真及源程序 [打印本頁]
作者: 51黑ff    時間: 2016-9-25 12:50
下面是RLC電阻電容電感測量儀的仿真原理圖:
仿真工程文件及源程序下載:
RLC測量儀.rar (71.66 KB, 下載次數: 717)
這個簡單的萬用表采用單片機控制,用lcd1602顯示屏來顯示.下面是部分源程序預覽:
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint  unsigned int
  5. sbit RS=P2^6;
  6. sbit RW=P2^5;
  7. sbit E=P2^7;
  8. sbit R=P1^0;
  9. sbit C=P1^1;
  10. sbit L=P1^2;
  11. sbit A1=P1^3;
  12. sbit A0=P1^4;
  13. #define LCD_data  P0
  14. uchar   code  table1[10]={"R=      R"};
  15. uchar   code  table2[10]={"C=      pF"};
  16. uchar   code  table3[10]={"L=      mH"};
  17. uchar code f_table[88]={13,14,15,16,17,        18,        19,        20,        21,        22,        23,        24,        25,        26,        27,        28,        29,        30,        31,        32,        33,        34,        35,        36,        37,        38,        39,        40,        41,        42,        43,        44,        45,        46,        47,        48,        49,        50,        51,        52,        53,        54,        55,        56,        57,        58,        59,        60,        61,        62,        63,        64,        65,        66,        67,        68,        69,        70,        71,        72,        73,        74,        75,        76,        77,        78,        79,        80,        81,        82,        83,        84,        85,        86,        87,        88,        89,        90,        91,        92,        93,        94,        95,        96,        97,        98,        99,        100};
  18. uchar code f_correct[88]={9,10,        11,        12,        12,        12,        13,        14,        15,        16,        17,        18,        18,        18,        19,        20,        21,        21,        22,        23,        24,        25,        25,        26,        26,        27,        28,        29,        29,        30,        30,        31,        32,        33,        33,        34,        35,        35,        36,        37,        38,        38,        39,        40,        41,        41,        42,        42,        43,        44,        45,        45,        46,        47,        48,        49,        49,        50,        51,        51,        52,        53,        54,        54,        55,        55,        56,        57,        57,        58,        59,        60,        60,        62,        62,        63,        64,        64,        65,        66,        66,        67,        67,        68,        69,        70,        71,        71,};
  19. uchar a6,a5,a4,a3,a2,a1;
  20. uchar flag;
  21. unsigned long cnt,cnt1;
  22. uchar f_cnt;
  23. /********************************/
  24. void delay_us(); //18us
  25. void delay_ms(uint);
  26. void lcd_init();
  27. void lcd_write_com(uchar com);
  28. void lcd_write_dat(uchar dat);
  29. void lcd_init();
  30. void lcd_display(uchar add,uchar dat);
  31. /***********************************/
  32. void delay_us()
  33. {
  34.         uchar x;
  35.         for(x=0;x<5;x++);
  36. }
  37. void delay_ms(uint z)
  38. {
  39.         uint x,y;
  40.         for(x=0;x<z;x++)
  41.                 for(y=0;y<123;y++);
  42. }
  43. void lcd_write_com(uchar com)
  44. {
  45.   E=0;
  46.   RS=0;
  47.   RW=0;
  48.   delay_us();
  49.   LCD_data=com;
  50.   E=1;           //高脈沖寫入數據
  51.   delay_us();
  52.   E=0;
  53. }
  54. void lcd_write_dat(uchar dat)
  55. {
  56.   E=0;
  57.   RS=1;
  58.   RW=0;
  59.   delay_us();
  60.   LCD_data=dat;
  61.   E=1;           //高脈沖寫入數據
  62.   delay_us();
  63.   E=0;
  64. }
  65. void lcd_init()                  //lcd初始化
  66. {
  67.         delay_ms(15);
  68.         lcd_write_com(0x38);
  69.         delay_ms(10);
  70.         lcd_write_com(0x0c);
  71.         lcd_write_com(0x06);
  72.         lcd_write_com(0x01);
  73.         delay_ms(2);
  74.
  75.
  76. }
  77. void timer_init(void)  //定時器初始化
  78. {
  79.         TMOD=0X51;
  80.         PT0=1;     /*中斷優先*/
  81.         TH0=0x3c;
  82.         TL0=0xb0;
  83.         TH1=0;
  84.         TL1=0;
  85.         ET0=1;
  86.         ET1=1;
  87.         TR0=1;
  88.         TR1=1;
  89.         EA=1;
  90. }
  91. void lcd_display(uchar add,uchar dat)           //lcd顯示(地址,數據)
  92. {
  93.         lcd_write_com(add);
  94.
  95.         lcd_write_dat(dat);
  96.         delay_us();
  97. }
  98. void real_display(void)
  99. {
  100.             if(!R)
  101.                          {
  102. //                         while(!R);
  103.                          A1=A0=0;
  104.                         lcd_display(0x80,table1[0]);
  105.                         lcd_display(0x80+1,table1[1]);
  106.                         lcd_display(0x80+8,table1[8]);
  107.                         lcd_display(0x80+9,table1[9]);
  108.                           }
  109.                         else if(!C)
  110.                         {
  111.                         A0=0;A1=1;
  112.                         lcd_display(0x80,table2[0]);
  113.                         lcd_display(0x80+1,table2[1]);
  114.                         lcd_display(0x80+8,table2[8]);
  115.                         lcd_display(0x80+9,table2[9]);
  116.                         }
  117.                         else if(!L)
  118.                         {
  119.                         A0=1;A1=0;
  120.                         lcd_display(0x80,table3[0]);
  121.                         lcd_display(0x80+1,table3[1]);
  122.                         lcd_display(0x80+8,table3[8]);
  123.                         lcd_display(0x80+9,table3[9]);
  124.                         }
  125.                         if(a6)
  126.                           lcd_display(0x80+2,0x30+a6);
  127.                         else
  128.                         lcd_display(0x80+2,' ');
  129.                         if(a6||a5)
  130.                         lcd_display(0x80+3,0x30+a5);
  131.                         else
  132.                                  lcd_display(0x80+3,' ');
  133.                         if(a6||a5||a4)
  134.                         lcd_display(0x80+4,0x30+a4);
  135.                         else
  136.                    lcd_display(0x80+4,' ');
  137.                         if(a6||a5||a4||a3)
  138.                         lcd_display(0x80+5,0x30+a3);
  139.                         else
  140.                     lcd_display(0x80+5,' ');
  141.                         if(a6||a5||a4||a3||a2)
  142.                         lcd_display(0x80+6,0x30+a2);
  143.                         else
  144.                         lcd_display(0x80+6,' ');
  145.
  146.                         lcd_display(0x80+7,0x30+a1);
  147.
  148. }
  149. void correct(void)                        //誤差修正函數
  150. {
  151.         uchar i,k;
  152.         unsigned long wucha;
  153.         if(cnt<100000)                   //100KHz以內的修正
  154.         {
  155.                 if(cnt>980&&cnt<2100)     cnt-=1;
  156.                 if(cnt>=2100&&cnt<3900)   cnt-=2;
  157.                 if(cnt>=3900&&cnt<4800)   cnt-=3;
  158.                 if(cnt>=4800&&cnt<5700)   cnt-=4;
  159.                 if(cnt>=5700&&cnt<8000)   cnt-=5;
  160.                 if(cnt>=8000&&cnt<9100)          cnt-=6;
  161.                 if(cnt>=9100&&cnt<10900)  cnt-=7;
  162.                 if(cnt>=10900&&cnt<11900) cnt-=8;
  163.                 if(cnt>=11900&&cnt<13000) cnt-=9;
  164.                 if(cnt>=13000&&cnt<=100000)
  165.                 {
  166.                         k=cnt/1000;
  167.                         for(i=0;i<88;i++)
  168.                         {
  169.                                 if(k==f_table[i])
  170.                                 {
  171.                                         cnt-=f_correct[i];
  172.                                 }
  173.                         }
  174.                 }
  175.
  176.
  177.         }
  178.         if(cnt>100000)
  179.         {
  180.                 wucha=(cnt/1000)*73065/100000;
  181.                 cnt-=wucha;
  182.         }
  183. }
  184. void main()
  185. {
  186.     timer_init();
  187.         lcd_init();
  188.         while(1)
  189.         {
  190.                    if(flag==1)
  191.                    {
  192.                         real_display();
  193.                         flag=0;
  194.                         }
  195.
  196.
  197.         }
  198.
  199. }
  200. void timer0() interrupt 1
  201. {
  202.         uchar timer0;
  203.
  204.         TH0=0x3c;          //50ms
  205.         TL0=0xb0;
  206.         timer0++;
  207.         if(timer0==20)
  208.         {
  209.                 TR1=0;          //關閉的計數器
  210.                 EA=0;
  211.                 cnt=TL1+TH1*256+f_cnt*65536;
  212.                 correct();
  213.             //cnt1=(1e+9)/(2*0.693 *cnt)-20000/2;
  214.                 if(!R)
  215.                 {
  216. //                while(!R);
  217.                 cnt1=1000000/(0.2*0.693*cnt)-165;
  218.                 }
  219.                 else if(!C)
  220.                 {
  221.                 cnt1=1000000000/(0.693*3*510*cnt);
  222.                 }
  223.                 else if(!L)
  224.                 {
  225.                  cnt1=(1e+9)/(4*3.14*3.14*cnt*cnt*0.05);
  226.                 }
  227.                 timer0=0;
  228.
  229.                 a6=cnt1%10000000/100000;
  230.                 a5=cnt1%100000/10000;
  231.                 a4=cnt1%10000/1000;
  232.                 a3=cnt1%1000/100;
  233.                 a2=cnt1%100/10;
  234.                 a1=cnt1%10;
  235.                 flag=1;
  236.                      TH1=0;
  237.                 TL1=0;
  238.                 TH0=0x3c;
  239.                      TL0=0xb0;
  240.                 cnt=0;
  241.                 f_cnt=0;
  242.                 EA=1;
  243.                 TR1=1;           //打開計數器
  244.
  245.
  246.         }
  247.
  248. }
  249. void int1() interrupt 3
  250. {
  251.          f_cnt++;
  252. }
作者: 真愛    時間: 2016-12-1 19:25
支持一下,希望做出成品.大家分享
作者: ChrisMerlin    時間: 2016-12-5 15:55
做得很好,支持一下
作者: a89163930    時間: 2016-12-9 17:52
樓主您這個測量儀那個測量端口是哪兩個。
作者: 騎馬趕上我老婆    時間: 2017-3-1 22:24
樓主的代碼寫的很好看
作者: chengfgc    時間: 2017-3-7 09:47
學習下,不知道精度如何?
作者: zqy181818    時間: 2017-3-18 13:07
不錯!感謝分享,我有時間也做下。
作者: 花瓣    時間: 2017-3-21 21:31
學習中
作者: dradolee    時間: 2017-4-10 15:58
樓主,你的測量電感的電路里面有一個電容是0.1F,實際電容沒有這么大的呀
作者: jljtwkn    時間: 2017-4-22 18:09
支持一下,學習學習
作者: a877429929    時間: 2017-4-28 18:20
回復收藏一撥
作者: zmc419    時間: 2017-4-28 21:32
dradolee 發表于 2017-4-10 15:58
應該是微法
作者: 洛冥genes    時間: 2017-5-18 22:33
為啥我調試著電感誤差非常大……
作者: 冬日紅葉    時間: 2017-5-19 17:49
樓主有沒有詳細的介紹說明啊
作者: 羅松松    時間: 2017-5-29 21:10
怎么測量啊?看不懂,求大神告知,畢業論文要用。
作者: hxyhly123    時間: 2017-6-13 09:10
支持一下,學習學習
作者: zhnagrui95    時間: 2017-6-13 11:27
這代碼很感人
作者: jdic256    時間: 2017-6-13 12:07
了解。。。。。。。。。。。
作者: Mr.Haovia    時間: 2017-9-28 17:00
看不懂啊,大神可以詳細點嘛
作者: Mr.Haovia    時間: 2017-10-1 10:54
大神,請問你這個施密特觸發器74132只是單純的起切換的作用嗎?那我可以取消這個嗎
作者: skl123    時間: 2017-12-1 19:38
原理能說下嗎
作者: 少年夢境    時間: 2017-12-29 11:30
不錯的
作者: songxia8013    時間: 2017-12-29 21:47
100mH的測出來是84mH,這個誤差可以??
作者: skiiim    時間: 2018-5-30 19:44
中間那個真的是74LS132嗎?怎么看著不像呢
作者: zhangluwen    時間: 2018-11-30 16:59
學習中 謝謝樓主分享
作者: 學弱的努力    時間: 2018-12-9 13:20
電感誤差巨大
作者: 694859836    時間: 2019-3-30 17:09
樓主的代碼寫的很好看
作者: 51HHEI66    時間: 2019-5-3 11:04
下載。。。看看
作者: GTT2    時間: 2019-5-9 13:21
厲害的樓主,GOOD!!
作者: 小小時光    時間: 2019-5-9 18:58
求詳細功能介紹
作者: 1036610254    時間: 2019-7-12 15:11
厲害,加油啊
作者: luoyua    時間: 2019-7-30 21:23
非常的不錯
作者: 寒梅梅    時間: 2019-8-7 08:43
感謝樓主
作者: l782664136    時間: 2019-12-3 18:05
用的什么元件可以告訴一下么。
作者: maguilong    時間: 2019-12-3 18:19
感謝樓主
作者: 未來研究人員    時間: 2019-12-6 20:49
電感誤差太大了
作者: maguilong    時間: 2019-12-9 21:01
樓主有沒有只測電感的代碼
作者: 我i是大哥    時間: 2019-12-10 09:44
有實物圖嗎?我想看看電路怎么焊接的?
作者: 撒大蘇打安德森    時間: 2019-12-10 14:50
對我幫助很大,謝謝。
作者: wangjinlongd    時間: 2020-3-4 21:06
學習中 謝謝樓主分享
作者: flc    時間: 2020-4-20 18:10
怎么晶振和復位電路沒有
作者: hb-l    時間: 2020-4-21 10:53
樓主,沒仿真文件了呀
作者: xiaofeng12138    時間: 2020-5-20 09:43
洛冥genes 發表于 2017-5-18 22:33
**** 作者被禁止或刪除 內容自動屏蔽 ****
我也是,而且10和以下就不顯示什么鬼
作者: xllin    時間: 2020-5-20 10:30
電感誤差太大了
作者: tureno    時間: 2025-9-12 19:09
非常感謝分享.
