標題: (分享設計)自做遙控資料 [打印本頁]
作者: haitao4675    時間: 2016-7-14 09:01
標題: (分享設計)自做遙控資料
部分源程序:keydata equ 30h
org 00h
main:
mov keydata,#0
    mov tmod ,#09h
       mov  r7,#0
    mov  r6,#0
    jb p3.2,$
again:
    mov tl0,#0
    mov th0,#0
    setb tr0
    jnb p3.2,$
    jb p3.2,$
    clr tr0
    mov a,th0
    clr c
    subb a,#12
    jc again
    mov a,#14
    clr c
    subb a,th0
        jc again   ;seaching start bit:  3.6ms
nextbit:
    mov tl0,#0
    mov th0,#0
    setb tr0
    jnb p3.2,$
    jb p3.2,$
    clr tr0
    mov a,th0
    clr c
    subb a,#8
    jc next  ;;;;;;;;;;if <2.2ms
    mov a,#10
    clr c
    subb a,th0
    jc again ;;;;;;;if >2.7ms
    mov a,keydata
    setb c          ;bit  = 1
    rrc a
    mov keydata,a
    inc r7
    cjne r7,#8,nextbit
    inc r6
    cjne r6,#2,last8
    sjmp seach
last8:
    mov keydata+1,a
    mov r7,#0
    sjmp nextbit
next:
    mov a,th0
    swap a
    mov r1,a
    anl tl0,#0f0h
    mov a,tl0
    clr c
    rrc a
    rrc a
    rrc a
    rrc a
    add a,r1
    mov r1,a
    subb a,#30
    jc nextbit ; if <0.84ms
    mov a,r1
    clr c
    cjne a,#64,continue
continue:
    jnc nextbit ;  if >1.11ms
    mov a,keydata
    clr c          ;bit  = 0
    rrc a
    mov keydata,a
    inc r7
    cjne r7,#8,nextbit
    inc r6
    cjne r6,#2,last_8
    sjmp seach
last_8:
    mov keydata+1,a
    mov r7,#0
    sjmp nextbit
seach:
    mov r0,#-2  ;pointer
    mov r1,#-1  ;counter
seach1:
        inc r0
seach2:   inc r0
    inc r1
    cjne r1,#29,compare
    sjmp exit0
compare:
    mov a,r0
    mov dptr,#keycode
    movc a,@a+dptr
    cjne a,keydata,seach1
    inc r0
    mov a,r0
    mov dptr,#keycode
    movc a,@a+dptr
    cjne a,keydata+1,seach2
    mov p1,r1         ;output to p1
send:
    mov tmod,#20h     ;   timer 1,mode 2
    mov tl1,#0fdh
    mov th1,#0fdh
    mov scon,#01010000b;9600,8,1,0
    setb tr1
loop_s:
    mov sbuf,r1    ;send to the serial port of computer
    jnb ti,$
    clr ti
exit0:
ljmp main
keycode:
db 11111000b,00000000b,    11111100b,00000000b,    11111001b,11000000b
db 11111100b,11000000b,    11111010b,00000000b,    11111010b,00100000b
db 11111010b,01000000b,    11111010b,01100000b,    11111010b,10000000b
db 11111010b,10100000b,    11111010b,11000000b,    11111010b,11100000b
db 11111011b,00000000b,    11111011b,00100000b,    11111011b,01000000b
db 11111011b,01100000b,    11111111b,01100000b,    11111111b,10100000b
db 10001100b,10001110b,    10001101b,11101110b,    10001100b,10101110b
db 10001101b,11001110b,    11111000b,11100000b,    11111100b,10000000b
db 11111100b,01000000b,    11111001b,10100000b,    11111100b,10100000b
db 11111100b,01100000b
end
