315Mhz無線模塊接收程序
電子黑
2016-6-27 22:08
315Mhz無線模塊接收程序
# include<reg52.h>
# define uint unsigned int
# define uchar unsigned char
sbit DATA=P3^2;
sbit rs=P2^6; //1602引腳定義
sbit rw=P2^5;
sbit e=P2^7;
uchar dat,num;
uchar code table[]="0123456789ABCDEF";
uchar code table1[]="Receive:"; //液晶固定部分顯示
uchar code table2[]="Re_data:0x";
void write_data (uchar dat); //1602寫數據
void write_com (uchar com); //1602寫命令
unsigned char pow(unsigned char n,unsigned char m); //n的m次方函數
uchar receive(void); //接收處理函數
void gd(); //液晶固定部分顯示
void delay (uint xms) //1602延時
uint i,j;
for (i = xms; i > 0; i--)
for (j = 110; j > 0; j--);
void delay1(unsigned char t)//延時程序
unsigned char n;
for(;t>0;t--)
for(n=40;n>0;n--);
unsigned char pow(unsigned char n,unsigned char m)//n的m次方函數
unsigned char t,result=1;
for(t=0;t<m;t++){result=n*result;}
return result;
void init_1602()
e = 0; //1602初始化
write_com (0x38);
write_com (0x0c);
write_com (0x06);
write_com (0x01);
gd();
/*1602液晶代碼部分 ------------------------------ */
void write_com (uchar com) //寫命令
rs = 0;
rw = 0;
P0 = com;
delay (5);
e = 1;
delay (5);
e = 0;
void write_data (uchar dat) //寫數據
rs = 1;
rw = 0;
P0 = dat;
delay (5);
e = 1;
delay (5);
e = 0;
void gd() //液晶固定部分顯示
write_com(0x80);
for(num=0;num<8;num++)
write_data(table1[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<10;num++)
write_data(table2[num]);
delay(5);
uchar receive(void)//接收處理函數
unsigned char guid=0,result[12],i,key=0,res=0,t,time=0;
while(1)//捕獲前導命令
while(DATA==1){t++;if(t>=90){delay1(100);return 0;}}//防止錯誤數據導致的死循環
if(t>=60&&t<95){t=0;key++;time=0;if(key>3)break;}//獲得前導命令跳出循環,清除計時信號
else if(time>100){delay1(100);return 0;}//長0,錯誤信號返回0
else {t=0;time++;}//計時壘加,清除t
t=0;
time=0;
for(i=1;i<13;) //校驗碼及數據的接收共12位數據
while(DATA==1){t++;if(t>=95){delay1(100);return 0;}}//防止錯誤信號導致的死循環
if(t>=60&&t<95){t=0;i=1;time=0;}//去除多余的前導命令
else if(t>=28&&t<60){result[i-1]=1;i++;time=0;}//捕獲數據1
else if(t>0&&t<27){result[i-1]=0;i++;time=0;}//捕獲數據0
if(time>100)return 0; //消除長0的干擾確保數據正確
t=0; //清零
time++;//計時
if(result[0]==1&&result[1]==0&&result[2]==1&&result[3]==0)//判斷校驗碼
for(i=0;i<8;i++){res+=pow(2,i)*result[11-i];}//將結果轉換為十進制數據
return res;//返回得到的結果
void display(uchar dat) //液晶數據顯示
uchar a,b;
a=dat/16;
b=dat%16;
if(a>9)
a=a+0;
if(b>9)
b=b+0;
write_com(0x80+0x4A);
write_data(table[a]);delay(5);
write_data(table[b]);delay(5);
init_1602(); //1602初始化
dat=receive();
if(dat) //顯示
write_com(0x80+0x08);
write_data('O');delay(5);
write_data('K');delay(5);
write_data('!');delay(5);
display(dat);
write_data('N');delay(5);
write_data(' ');delay(5);
wushi6
2018-3-26 08:27
捕獲器解調有么
fengche1915
2026-3-4 11:25
定時器都沒有用到啊
