ADC0832模數(shù)轉換采集電壓上位機和下位機單片機程序源碼
heicc
2016-6-17 01:15
(9.26 KB, 下載次數(shù): 110)
2016-6-17 01:13 上傳
ADC0832電壓采集上位機程序,51黑附件中可下載vc++源碼
下面是單片機做的下位機程序:
#include<reg52.h>
#include "intrins.h"
sbit ADCS =P2^3; //ADC0832 chip seclect
sbit ADDI =P2^2; //ADC0832 k in
sbit ADDO =P2^1; //ADC0832 k out
sbit ADCLK =P2^0; //ADC0832 clock signal
sbit cs=P2^2;
sbit wr=P2^3;
unsigned char dispbitcode[8]={0xf7,0xfb,0xfd}; //位掃描
unsigned char dispcode[11]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff};
unsigned char dispbuf[3];
unsigned char table[9]={0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
uint temp,adc=0;
uchar getdata; //獲取ADC轉換回來的值
uchar flag,a;
void delayms(void) //12mhz delay 1.01ms
unsigned char x,y;
x=10;
while(x--)
y=4;
while(y--);
void display(void) //數(shù)碼管顯示函數(shù)
char k;
for(k=0;k<3;k++)
P1 = dispbitcode[k];
P0 = dispcode[dispbuf[k]];
delayms();
if(k==0) //加上數(shù)碼管的dp小數(shù)點
P0&=0x7f;
delayms();
P1=0xff;
//采集并返回
unsigned int Adc0832(unsigned char channel) //AD轉換,返回結果
uchar i=0;
uchar j;
uint dat=0;
uchar ndat=0;
if(channel==0)channel=2;
if(channel==1)channel=3;
ADDI=1;
_nop_();
_nop_();
ADCS=0;//拉低CS端
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿1
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=channel&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿2
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=(channel>>1)&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿3
ADDI=1;//控制命令結束
_nop_();
_nop_();
dat=0;
for(i=0;i<8;i++)
dat|=ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
ADCLK=0;//形成一次時鐘脈沖
_nop_();
_nop_();
dat<<=1;
if(i==7)dat|=ADDO;
for(i=0;i<8;i++)
j=0;
j=j|ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
ADCLK=0;//形成一次時鐘脈沖
_nop_();
_nop_();
j=j<<7;
ndat=ndat|j;
if(i<7)ndat>>=1;
ADCS=1;//拉低CS端
ADCLK=0;//拉低CLK端
ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
dat<<=8;
dat|=ndat;
return(dat); //return ad k
{ P0=0XFF;
TMOD=0x20;
TH1=0xfd;
TL1=0xfd;
TR1=1;
REN=1;
SM0=0;
SM1=1;
EA=1;
ES=1;
{ if(flag==1)
ES=0;
flag=0;
SBUF=getdata;
while(!TI);
TI=0;
ES=1;
getdata=Adc0832(1);
temp=getdata*1.0/255*500; //電壓值轉換,5V做為參考電壓,分成256份。
dispbuf[2]=temp%10; //個位
dispbuf[1]=temp/10%10; //十位
dispbuf[0]=temp/100; //百位
display();
void ckzd() interrupt 4
RI=0;
a=SBUF;
switch(a)
case 'a':
flag=1; break;
case 'b':
P0=adc; break;
case 'c':
P0=adc; break;
default:
P1=0xFF;
break;
(61.43 KB, 下載次數(shù): 99)
2016-6-17 01:13 上傳
ADC0832模數(shù)轉換測試程序,帶上位機源程序和下位機源程序,將adc0832采集的電壓值送給上位機顯示,本人親測
上位機和下位機ADC0832upanddown.rar
(5.72 MB, 下載次數(shù): 139)
2016-6-17 01:15 上傳
lizhi2412979180
2018-5-14 19:44
是用什么軟件做的啊
aking991
2018-9-27 13:21
才0-5V,上位機也才那樣,功能太簡單了,測量范圍也太小了,還有ADC才8位,精度太差
lqsgg
2018-10-19 21:55
謝謝分享!學習學習!
965591772
2019-3-22 10:02
這個_nop_是什么意思?延時的意思嗎
lzb1989666
2020-5-10 12:28
挺好O,感謝分享
wengjiamin
2021-1-8 22:37
這個_nop_是什么意思?延時的意思嗎
是的 ,相當于匯編的nop指令
