標題: 51單片機頻譜顯示 PCB圖+程序源代碼 [打印本頁]
作者: happy112    時間: 2016-6-7 16:19
看到淘寶上有做的頻譜顯示的東西,感覺挺好看,就自己用覆銅板做了一個,然后分享一下資料!音頻線是自己用耳機線剪得,只取了一個聲道,PCB里的電阻用的是0R電阻當跳線,然后后來對圖做了些修改,把直插的改成貼片的,可能程序有些變化,只要把定時器里的掃描函數改了就行
源代碼:
  1. #include<stc12c5a.h>
  2. #include<intrins.h>
  3. #include"basic.h"
  4. typedef unsigned char uint8;
  5. typedef unsigned int uint16;
  6. #define ADC_FLAG    (1<<4)    /*ADC_中斷標志*/
  7. /*放大128倍后的sin整數表(128)*/
  8. code char SIN_TAB[128]={0,6,12,18,24,30,36,42,48,54,59,65,70,75,80,85,89,94,98,102,
  9.                         105,108,112,114,117,119,121,123,124,125,126,126,126,126,126,
  10. 125,124,123,121,119,117,114,112,108,105,102,98,94,89,85,80,75,
  11. 70,65,59,54,48,42,36,30,24,18,12,6,0,-6,-12,-18,-24,-30,-36,-42,
  12. -48,-54,-59,-65,-70,-75,-80,-85,-89,-94,-98,-102,-105,-108,-112,
  13. -114,-117,-119,-121,-123,-124,-125,-126,-126,-126,-126,-126,-125,
  14. -124,-123,-121,-119,-117,-114,-112,-108,-105,-102,-98,-94,-89,-85,
  15. -80,-75,-70,-65,-59,-54,-48,-42,-36,-30,-24,-18,-12,-6
  16.   };
  17. /*放大128倍后的cos整數表(128)*/
  18. code char COS_TAB[128]={127,126,126,125,124,123,121,119,117,114,112,108,105,102,98,94,
  19.                         89,85,80,75,70,65,59,54,48,42,36,30,24,18,12,6,0,-6,-12,-18,-24,
  20. -30,-36,-42,-48,-54,-59,-65,-70,-75,-80,-85,-89,-94,-98,-102,
  21. -105,-108,-112,-114,-117,-119,-121,-123,-124,-125,-126,-126,-126,
  22. -126,-126,-125,-124,-123,-121,-119,-117,-114,-112,-108,-105,-102,
  23. -98,-94,-89,-85,-80,-75,-70,-65,-59,-54,-48,-42,-36,-30,-24,-18,
  24. -12,-6,0,6,12,18,24,30,36,42,48,54,59,65,70,75,80,85,89,94,98,102,
  25. 105,108,112,114,117,119,121,123,124,125,126,126
  26.   };
  27. /*采樣存儲序列表*/
  28. code char LIST_TAB[128] = {0,64,32,96,16,80,48,112,8,72,40,104,24,88,56,120,4,68,36,100,20,84,52,116,
  29.                            12,76,44,108,28,92,60,124,2,66,34,98,18,82,50,114,10,74,42,106,26,90,58,
  30.   122,6,70,38,102,22,86,54,118,14,78,46,110,30,94,62,126,1,65,33,97,17,81,49,
  31.   113,9,73,41,105,25,89,57,121,5,69,37,101,21,85,53,117,13,77,45,109,29,93,61,
  32.   125,3,67,35,99,19,83,51,115,11,75,43,107,27,91,59,123,7,71,39,103,23,87,55,
  33.   119,15,79,47,111,31,95,63,127
  34. };
  35. /*分級量化表*/
  36. uint8 QTY_TAB[] = {0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};
  37. uint8 ADC_Count=0;
  38. uint8 i,j,k,b,p,anum;
  39. uint16 xdata Fft_Real[128];
  40. uint16 xdata Fft_Image[128];               // fft的虛部
  41. uint8 xdata LED_TAB[16]; //記錄紅色柱狀
  42. /********************************************************************
  43. * 名稱 : FFT
  44. * 功能 : 碟型運算轉換
  45. * 輸入 : 無
  46. * 輸出 : 讀出的值
  47. ***********************************************************************/
  48. void FFT()//基2fft
  49. {
  50. uint16 Temp_Real,Temp_Imag,temp;                // 中間臨時變量
  51. uint16 TEMP1 = 0,max=0;
  52. for( i=1; i<=7; i++)                            /* for(1) */
  53. {
  54. b=1;
  55. b <<=(i-1);                                 //碟式運算,用于計算隔多少行計算例如 第一極 1和2行計算
  56. for( j=0; j<=b-1; j++)                      /* for (2) */
  57. {
  58. p=1;
  59. p <<= (7-i);
  60. p = p*j;
  61. for( k=j; k<128; k=k+2*b)               /* for (3)  */
  62. {
  63. Temp_Real=Fft_Real[k];
  64. Temp_Imag=Fft_Image[k];
  65. temp=Fft_Real[k+b];
  66. Fft_Real[k]=Fft_Real[k]+((Fft_Real[k+b]*COS_TAB[p])>>7)+((Fft_Image[k+b]*SIN_TAB[p])>>7);
  67. Fft_Image[k]=Fft_Image[k]-((Fft_Real[k+b]*SIN_TAB[p])>>7)+((Fft_Image[k+b]*COS_TAB[p])>>7);
  68. Fft_Real[k+b]=Temp_Real-((Fft_Real[k+b]*COS_TAB[p])>>7)-((Fft_Image[k+b]*SIN_TAB[p])>>7);
  69. Fft_Image[k+b]=Temp_Imag+((temp*SIN_TAB[p])>>7)-((Fft_Image[k+b]*COS_TAB[p])>>7);          // 移位.防止溢出. 結果已經是本值的 1/64
  70. Fft_Real[k] >>= 1;
  71. Fft_Image[k] >>= 1;
  72. Fft_Real[k+b] >>= 1;
  73. Fft_Image[k+b] >>= 1;
  74. }
  75. }
  76. }
  77. for(j=0;j<16;j++)//16分頻
  78. {
  79. TEMP1=((((Fft_Real[j+1]* Fft_Real[j+1]))+((Fft_Image[j+1]*Fft_Image[j+1])))>>1);//求各頻段幅值
  80. if(TEMP1<1)TEMP1=0;
  81. LED_TAB[j]=TEMP1;
  82. if(LED_TAB[j]>max)max=LED_TAB[j];
  83. }
  84. if(max > 16)//分級量化
  85. {
  86. max/=16;
  87. for(j=0;j<16;j++)LED_TAB[j]/=max;
  88. }
  89. }
  90. /********************************************************************
  91. * 名稱 : GPIO_init
  92. * 功能 : GPIO初始化
  93. * 輸入 : 無
  94. * 輸出 : 讀出的值
  95. ***********************************************************************/
  96. void GPIO_init()
  97. {
  98. P0M0 = 1; P0M1 = 0; P0 = 0XFF;    /*列*/
  99. P2M0 = 1; P2M1 = 0; P2 = 0XFF;
  100. P3M0 = 1; P3M1 = 0; P3 = 0XFF;   /*行*/
  101. }
  102. /********************************************************************
  103. * 名稱 : timer_Init
  104. * 功能 : 內部寄存器初始化
  105. * 輸入 : 無
  106. * 輸出 : 無
  107. ***********************************************************************/
  108. void timer_Init()
  109. {
  110. TMOD = 0X12;
  111. TH0 = 0xb0;
  112. TL0 = 0xb0;
  113. ET0 = 1;        //定時器0 打開
  114. TR0 = 0;        //關閉定時器
  115. TH1 = 0xfd;
  116. TL1 = 0Xa8;
  117. ET1  = 1;
  118. TR1  = 1;
  119. EA   = 1;
  120. }
  121. /********************************************************************
  122. * 名稱 : adc_Init
  123. * 功能 : 內部寄存器初始化
  124. * 輸入 : 無
  125. * 輸出 : 無
  126. ***********************************************************************/
  127. void adc_Init()
  128. {
  129. ADC_CONTR = 0x80;             //ADC電源打開
  130. _nop_();_nop_();_nop_();_nop_();
  131. P1ASF = 0x01;                 //0000,0001, 將 P1.0 置成模擬口
  132. AUXR1 &=0xFB;                 //1111,1011, 令 ADRJ=0
  133. ADC_RES = 0x00;               //清零寄存器
  134. ADC_RESL = 0x00;
  135. EADC  = 1;   //AD中斷打開
  136. EA = 1;   //總中斷打開
  137. }
  138. /********************************************************************
  139. * 名稱 : main
  140. * 功能 : 主程序
  141. * 輸入 : 無
  142. * 輸出 : 無
  143. ***********************************************************************/
  144. void main()
  145. {
  146. uint8 i = 0;
  147. GPIO_init();
  148. timer_Init();
  149. adc_Init();
  150. while(1)
  151. {
  152. ADC_Count = 0;
  153. EADC = 1;
  154. TR0  = 1;
  155. while(ADC_Count < 128);       //滿足128點
  156. for(i=0; i<128; i++)   //清除虛部
  157. {
  158. Fft_Image[i] = 0;
  159. }
  160. FFT();                        //FFT運算并轉換為各頻段幅值
  161. }
  162. }
  163. /********************************************************************
  164. * 名稱 : ADC_Finish
  165. * 功能 : ADC轉換完成中斷服務
  166. * 輸入 : 無
  167. * 輸出 : 無
  168. ***********************************************************************/
  169. void ADC_Finish() interrupt 5
  170. {
  171. Fft_Real[LIST_TAB[ADC_Count]] = (int)(((ADC_RES)<<1)+(ADC_RESL>>1)*2)>>3;    /*按LIST_TAB表順序,進行存儲采樣值*/
  172. if(ADC_Count <= 127)
  173. {
  174. ADC_Count++;           /*自動增量控制*/
  175. ADC_CONTR &= !ADC_FLAG;
  176. }
  177. else
  178. {
  179. EADC = 0;
  180. TR0  = 0;
  181. }
  182. }
  183. /********************************************************************
  184. * 名稱 : interrupt_timer1
  185. * 功能 : 顯示屏幕刷新中斷服務
  186. * 輸入 : 無
  187. * 輸出 : 無
  188. ***********************************************************************/
  189. void interrupt_timer1() interrupt 3
  190. {
  191. static uint8 rec = 0;
  192. TH1 = 0xfd;
  193. TL1 = 0Xa8;
  194. switch(rec)      //往點陣屏填充一列的數據
  195. {
  196. case 0: P0 = QTY_TAB[LED_TAB[0]]; P2 = 0;break;
  197. case 1: P0 = QTY_TAB[LED_TAB[1]]; P2 = 1;break;
  198. case 2: P0 = QTY_TAB[LED_TAB[2]]; P2 = 2;break;
  199. case 3: P0 = QTY_TAB[LED_TAB[3]]; P2 = 3;break;
  200. case 4: P0 = QTY_TAB[LED_TAB[4]]; P2 = 4;break;
  201. case 5: P0 = QTY_TAB[LED_TAB[5]]; P2 = 5;break;
  202. case 6: P0 = QTY_TAB[LED_TAB[6]]; P2 = 6;break;
  203. case 7: P0 = QTY_TAB[LED_TAB[7]]; P2 = 7;break;
  204. case 8: P0 = QTY_TAB[LED_TAB[8]]; P2 = 8;break;
  205. case 9: P0 = QTY_TAB[LED_TAB[9]]; P2 = 9;break;
  206. case 10: P0 = QTY_TAB[LED_TAB[10]]; P2 = 10;break;
  207. case 11: P0 = QTY_TAB[LED_TAB[11]]; P2 = 11;break;
  208. case 12: P0 = QTY_TAB[LED_TAB[12]]; P2 = 12;break;
  209. case 13: P0 = QTY_TAB[LED_TAB[13]]; P2 = 13;break;
  210. case 14: P0 = QTY_TAB[LED_TAB[14]]; P2 = 14;break;
  211. case 15: P0 = QTY_TAB[LED_TAB[15]]; P2 = 15;break;
  212. default:break;
  213. }
  214. rec++;
  215. if(rec > 15)
  216. {
  217. rec = 0;
  218. }
  219. }
  220. /********************************************************************
  221. * 名稱 : Ad_Control
  222. * 功能 : 控制采樣率
  223. * 輸入 : 無
  224. * 輸出 : 無
  225. ***********************************************************************/
  226. void Ad_Control() interrupt 1
  227. {
  228. ADC_CONTR = 0xe8;       //開始AD采集
  229. _nop_();_nop_();_nop_();_nop_();
  230. }
全部資料(壓縮包)下載:
DIY音樂頻譜顯示源代碼.rar
125.06 KB, 下載次數: 129, 下載積分: 黑幣 -5
pinaf.rar
2.93 KB, 下載次數: 90, 下載積分: 黑幣 -5
頻譜.rar
2.5 KB, 下載次數: 96, 下載積分: 黑幣 -5
board.rar
1004.33 KB, 下載次數: 91, 下載積分: 黑幣 -5
作者: JUNIC    時間: 2017-6-26 20:04
下載下來看看,最近在研究這個
作者: bayga456    時間: 2017-11-8 15:08
學習學習,感謝。
作者: 3478污鈔    時間: 2018-5-25 20:40
下載看看
作者: darkLee    時間: 2018-5-25 22:15
看起來很好看,值得學習,有空做一個
作者: liujia520    時間: 2018-9-19 11:55
在嗎?能加個扣詳細聊一下不,硬件電路咋連。
作者: mcu_mpu    時間: 2019-7-9 13:44
好東西,學習下。
作者: zh68a11    時間: 2019-9-3 18:53
學習學習,感謝。
作者: woxinhengda    時間: 2020-1-2 15:19
學習學習 感謝分享
作者: 2396872568    時間: 2020-1-29 11:41
不錯,很有用
