標(biāo)題: STM32開發(fā)板GPIO-LED試驗(yàn)程序 [打印本頁(yè)]
作者: cyf111    時(shí)間: 2016-6-6 20:55
  1. /****************************************Copyright (c)***************************************
  2. **-------------------------------------------------------------------------------------------
  3. ** File name:           main.c
  4. ** Last modified Date:  2012-12-28
  5. ** Last Version:        V1.0
  6. ** Descriptions:        紅龍407開發(fā)板 LED測(cè)試
  7. **
  8. **-------------------------------------------------------------------------------------------
  9. ** Created by:          FXL
  10. ** Last modified Date:  2012-12-28
  11. ** Last Version:        V1.00
  12. ** Descriptions:        紅龍407開發(fā)板 LED測(cè)試
  13. **
  14. **-------------------------------------------------------------------------------------------
  15. ** Modified by:
  16. ** Modified date:
  17. ** Version:
  18. ** Descriptions:
  19. **-------------------------------------------------------------------------------------------
  20. ********************************************************************************************/
  21. #include "stm32f4xx.h"
  22. #include "Gpio.h"
  23. void Delay(__IO uint32_t nCount);  //函數(shù)聲明
  24. int main(void)
  25. {
  26.   LEDGpio_Init();                  //GPIO管腳初始化
  27.   while (1)
  28.   {
  29.       LED4_ONOFF(Bit_SET);         //LED4置高(滅燈) 從原理圖可以看出,LED為低電平亮。
  30.       LED1_ONOFF(Bit_RESET);       //LED1置低(開燈)
  31.       Delay(0X3FFFFF);             //延時(shí)
  32.       LED1_ONOFF(Bit_SET);         //以下同上注視
  33.       LED2_ONOFF(Bit_RESET);
  34.       Delay(0X3FFFFF);
  35.       LED2_ONOFF(Bit_SET);
  36.       LED3_ONOFF(Bit_RESET);
  37.       Delay(0X3FFFFF);
  38.       LED3_ONOFF(Bit_SET);
  39.       LED4_ONOFF(Bit_RESET);
  40.       Delay(0X3FFFFF);
  41.   }
  42. }
  43. /********************************************************************************************
  44. *函數(shù)名稱:void Delay(__IO uint32_t nCount)
  45. *
  46. *入口參數(shù):無(wú)
  47. *
  48. *出口參數(shù):無(wú)
  49. *
  50. *功能說(shuō)明:延時(shí)函數(shù)
  51. *******************************************************************************************/
  52. void Delay(__IO uint32_t nCount)
  53. {
  54.   while(nCount--)
  55.   {
  56.   }
  57. }
GPIO-LED.rar (678.37 KB, 下載次數(shù): 9)
