2個io口驅動1602 電路圖和程序
古人古人
2016-5-14 12:06
2個io口驅動1602 電路圖和程序
這是基于avr的,希望有大神能移植成51的。
(32.26 KB, 下載次數: 153)
2016-5-15 19:13 上傳
// Drive a LCD1602 with 2 wire
//ICC-AVR application builder : 2010-10-3 19:30:02
// Target : M16
// Crystal: 4.0000Mhz
#include <iom16v.h>
#include <macros.h>
#define Set_E PORTB|=2
#define Clr_E PORTB&=~2
#define Set_D PORTB|=1
#define Clr_D PORTB&=~1
#define Set_xy(y,x) Send(0,(y<<6)|(x&15)|0x80)
void init_devices(void)
{ CLI(); //disable all interrupts
DDRB = 0x03;
MCUCR = 0x00;
GICR = 0x00;
SEI(); //re-enable interrupts
void Delay(unsigned int i)
while(i--);
void Send(unsigned char RS, unsigned char dat)
unsigned char i;
for (i = 2; i > 0; i--)
if (dat & 0x80) Set_D; else Clr_D;
Delay(10608);//14520us
if (RS) Set_E;
if (dat & 0x40) Set_D; else Clr_D;
Delay(462); //660us
if (dat & 0x20) Set_D; else Clr_D;
Delay(18); //30us
Set_E;
if (dat & 0x10) Set_D; else Clr_D;
_NOP(); //0.5us < t < 1.36us
Clr_E;
dat <<= 4;
void init_1602(void)
unsigned char i = 3;
Clr_D;
Clr_E;
Delay(10608);
do{
Clr_D;
Delay(462);
Set_D;
Set_E;
Delay(18);
if (i == 0) Clr_D;
_NOP();_NOP();_NOP();
Clr_E;
}while(i--);
Send(0,0x28);
Send(0,0x01);
Send(0,0x0f);
void Send_S(unsigned char *p)
while(*p) Send(1,*p++);
void main(void)
unsigned char i;
init_devices();
init_1602();
Set_xy(0,2);
Send_S("Hello world!");
Set_xy(1,3);
Send_S("I'm COWBOY.");
for (i=0;i<255;i++) Delay(10000);
Send(0,0x01);
Set_xy(0,3);
Send_S("Welcome to");
Set_xy(1,1);
Send_S("www*ourdev*cn");
while(1);
仿真文件和全部代碼下載:
1602-2.zip
(7.64 KB, 下載次數: 24)
2016-5-14 12:06 上傳
liang118038
2018-3-11 01:01
貨不對版,代碼明明是AVR的,仿真畫面卻是AT89C51
