標題: 24進制計數器數碼管顯示用VHDl編寫 [打印本頁]
作者: angel_9331 時間: 2016-4-21 17:21
——24進制計數器(數碼管顯示)用VHDl編寫
——樓主用實驗板驗證過滿足計數0~23
頂層文件 led_24
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity led_24 is
port(clk,clr,ena:in std_logic;
cq10_out,cq2_out:out std_logic_vector(3 downto 0)
end led_24;
architecture behav of led_24 is
component led24
cnt10,cnt2:out std_logic_vector(3 downto 0));
end component;
component decoder_10
port(cq10_1:IN STD_LOGIC_VECTOR (3 DOWNTO 0);
cq10_out:OUT STD_LOGIC_VECTOR (6 DOWNTO 0));
end component;
component decoder_2
PORT (cq2_1:IN STD_LOGIC_VECTOR (3 DOWNTO 0);
cq2_out:OUT STD_LOGIC_VECTOR (6 DOWNTO 0));
end component;
signal net1, net2 :std_logic_vector(3 downto 0);
begin
u1 : led24 port map(clk=>clk,clr=>clr,ena=>ena,cnt10=>net1,cnt2=>net2);
u2 : decoder_10 port map(cq10_1=>net1,cq10_out=>cq10_out);
u3 : decoder_2 port map(cq2_1=>net2,cq2_out=>cq2_out);
END architecture behav;
——例化元器件 U1:
——24進制計數器
library ieee;
entity led24 is
end led24 ;
architecture behav of led24 is
begin
process(clk,clr,ena)
variable cq2:std_logic_vector(3 downto 0);
variable cq10:std_logic_vector(3 downto 0);
begin
if clr='1' then
cq2:="0000";
cq10:="0000";
elsif clk'event and clk='0' then
if ena='1' then
if cq10="1001" then
cq10:="0000";
cq2:=cq2+'1';
else cq10:=cq10+'1';
end if;
if cq2="0010" and cq10="0100" then
cq2:="0000";cq10:="0000";
end if;
end if;
end if;
cnt2<=cq2;
cnt10<=cq10;
end process ;
end architecture behav;
——例化元器件u2
——個位數譯碼電路
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY decoder_10 IS
PORT (cq10_1:IN STD_LOGIC_VECTOR (3 DOWNTO 0);
END;
ARCHITECTURE ONE OF decoder_10 IS
BEGIN
PROCESS (cq10_1) BEGIN
CASE cq10_1 IS
WHEN "0000" => cq10_out<= "1000000";
WHEN "0001" => cq10_out<= "1111001";
WHEN "0010" => cq10_out<= "0100100";
WHEN "0011" => cq10_out<= "0110000";
WHEN "0100" => cq10_out<= "0011001";
WHEN "0101" => cq10_out<= "0010010";
WHEN "0110" => cq10_out<= "0000010";
WHEN "0111" => cq10_out<= "1111000";
WHEN "1000" => cq10_out<= "0000000";
WHEN "1001" => cq10_out<= "0010000";
WHEN OTHERS => cq10_out<= "1111111";
END CASE;
END PROCESS;
END architecture ONE;
—— 例化元器件u3
十位數譯碼電路
LIBRARY IEEE;
ENTITY decoder_2 IS
END;
ARCHITECTURE two OF decoder_2 IS
BEGIN
PROCESS (cq2_1) BEGIN
CASE cq2_1 IS
WHEN "0000" => cq2_out<= "1000000";
WHEN "0001" => cq2_out<= "1111001";
WHEN "0010" => cq2_out<= "0100100";
WHEN OTHERS => cq2_out<= "1111111";
END CASE;
END PROCESS;
END architecture two;
波形見附件
2016-4-21 18:12 上傳
RTL圖
2016-4-21 18:12 上傳
file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps7658.tmp.jpg
計數器波形
譯碼之后波形
file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\wps7669.tmp.jpg
——這里有完整的工程
24進制計數器數碼管顯示用VHDl編寫.zip
2016-4-21 17:20 上傳
53.13 KB, 下載次數: 27, 下載積分: 黑幣 -5
24進制計數器
作者: zimiaoxinghan 時間: 2017-11-24 10:02
能不能上傳文件源碼,具體的.VHD文件
