M430f149頭文件詳解
18692899115
2016-4-18 23:07
M430f149頭文件詳解
430f149頭文件詳解
#ifndef __msp430x14x
#define __msp430x14x
* STANDARD BITS
#define BIT0 0x0001
#define BIT1 0x0002
#define BIT2 0x0004
#define BIT3 0x0008
#define BIT4 0x0010
#define BIT5 0x0020
#define BIT6 0x0040
#define BIT7 0x0080
#define BIT8 0x0100
#define BIT9 0x0200
#define BITA 0x0400
#define BITB 0x0800
#define BITC 0x1000
#define BITD 0x2000
#define BITE 0x4000
#define BITF 0x8000
* STATUS REGISTER BITS
#define C 0x0001
#define Z 0x0002
#define N 0x0004
#define V 0x0100
#define GIE 0x0008
#define CPUOFF 0x0010
#define OSCOFF 0x0020
#define SCG0 0x0040
#define SCG1 0x0080
/* Low Power Modes coded with Bits 4-7 in SR */
#ifndef __IAR_SYSTEMS_ICC /* Begin #defines for assembler */
#define LPM0 CPUOFF
#define LPM1 SCG0+CPUOFF
#define LPM2 SCG1+CPUOFF
#define LPM3 SCG1+SCG0+CPUOFF
#define LPM4 SCG1+SCG0+OSCOFF+CPUOFF
/* End #defines for assembler */
#else /* Begin #defines for C */
#define LPM0_bits CPUOFF
#define LPM1_bits SCG0+CPUOFF
#define LPM2_bits SCG1+CPUOFF
#define LPM3_bits SCG1+SCG0+CPUOFF
#define LPM4_bits SCG1+SCG0+OSCOFF+CPUOFF
#include <In430.h>
#define LPM0 _BIS_SR(LPM0_bits) /* Enter Low Power Mode 0 */
#define LPM0_EXIT _BIC_SR(LPM0_bits) /* Exit Low Power Mode 0 */
#define LPM1 _BIS_SR(LPM1_bits) /* Enter Low Power Mode 1 */
#define LPM1_EXIT _BIC_SR(LPM1_bits) /* Exit Low Power Mode 1 */
#define LPM2 _BIS_SR(LPM2_bits) /* Enter Low Power Mode 2 */
#define LPM2_EXIT _BIC_SR(LPM2_bits) /* Exit Low Power Mode 2 */
#define LPM3 _BIS_SR(LPM3_bits) /* Enter Low Power Mode 3 */
#define LPM3_EXIT _BIC_SR(LPM3_bits) /* Exit Low Power Mode 3 */
#define LPM4 _BIS_SR(LPM4_bits) /* Enter Low Power Mode 4 */
#define LPM4_EXIT _BIC_SR(LPM4_bits) /* Exit Low Power Mode 4 */
#endif /* End #defines for C */
* PERIPHERAL FILE MAP
* 特殊功能寄存器地址和控制位
/*中斷使能1*/
#define IE1_ 0x0000
sfrb IE1 = IE1_;
#define WDTIE 0x01 /*看門狗中斷使能*/
#define OFIE 0x02 /*外部晶振故障中斷使能*/
#define NMIIE 0x10 /*非屏蔽中斷使能*/
#define ACCVIE 0x20 /*可屏蔽中斷使能/flash寫中斷錯誤*/
#define URXIE0 0x40 /*串口0接收中斷使能*/
#define UTXIE0 0x80 /*串口0發送中斷使能*/
/*中斷標志1*/
#define IFG1_ 0x0002
sfrb IFG1 = IFG1_;
#define WDTIFG 0x01 /*看門狗中斷標志*/
#define OFIFG 0x02 /*外部晶振故障中斷標志*/
#define NMIIFG 0x10 /*非屏蔽中斷標志*/
#define URXIFG0 0x40 /*串口0接收中斷標志*/
#define UTXIFG0 0x80 /*串口0發送中斷標志*/
/* 中斷模式使能1 */
#define ME1_ 0x0004
sfrb ME1 = ME1_;
#define URXE0 0x40 /* 串口0接收中斷模式使能 */
#define USPIE0 0x40 /* 同步中斷模式使能 */
#define UTXE0 0x80 /* 串口0發送中斷模式使能 */
/* 中斷使能2 */
#define IE2_ 0x0001
sfrb IE2 = IE2_;
#define URXIE1 0x10 /* 串口1接收中斷使能 */
#define UTXIE1 0x20 /* 串口1發送中斷使能 */
/* 中斷標志2 */
#define IFG2_ 0x0003
sfrb IFG2 = IFG2_;
#define URXIFG1 0x10 /* 串口1接收中斷標志 */
#define UTXIFG1 0x20 /* 串口1發送中斷標志 */
/* 中斷模式使能2 */
#define ME2_ 0x0005
sfrb ME2 = ME2_;
#define URXE1 0x10 /* 串口1接收中斷模式使能 */
#define USPIE1 0x10 /* 同步中斷模式使能 */
#define UTXE1 0x20 /* 串口1發送中斷模式使能 */
* 看門狗定時器的寄存器定義
#define WDTCTL_ 0x0120
sfrw WDTCTL = WDTCTL_;
#define WDTIS0 0x0001 /*選擇WDTCNT的四個輸出端之一*/
#define WDTIS1 0x0002 /*選擇WDTCNT的四個輸出端之一*/
#define WDTSSEL 0x0004 /*選擇WDTCNT的時鐘源*/
#define WDTCNTCL 0x0008 /*清除WDTCNT端: 為1時 從0開始計數*/
#define WDTTMSEL 0x0010 /*選擇模式 0: 看門狗模式; 1: 定時器模式*/
#define WDTNMI 0x0020 /*選擇NMI/RST 引腳功能 0:為 RST; 1:為NMI*/
#define WDTNMIES 0x0040 /*WDTNMI=1時.選擇觸發延 0:為上升延 1:為下降延*/
#define WDTHOLD 0x0080 /*停止看門狗定時器工作 0:啟動;1:停止*/
#define WDTPW 0x5A00 /* 寫密碼:高八位*/
/* SMCLK= 1MHz定時器模式 */
#define WDT_MDLY_32 WDTPW+WDTTMSEL+WDTCNTCL /* TSMCLK*2POWER15=32ms 復位狀態 */
#define WDT_MDLY_8 WDTPW+WDTTMSEL+WDTCNTCL+WDTIS0 /* TSMCLK*2POWER13=8.192ms " */
#define WDT_MDLY_0_5 WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1 /* TSMCLK*2POWER9=0.512ms " */
#define WDT_MDLY_0_064 WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1+WDTIS0 /* TSMCLK*2POWER6=0.512ms " */
/* ACLK=32.768KHz 定時器模式*/
#define WDT_ADLY_1000 WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL /* TACLK*2POWER15=1000ms " */
#define WDT_ADLY_250 WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS0 /* TACLK*2POWER13=250ms " */
#define WDT_ADLY_16 WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1 /* TACLK*2POWER9=16ms " */
#define WDT_ADLY_1_9 WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0 /* TACLK*2POWER6=1.9ms " */
/* SMCLK=1MHz看門狗模式 */
#define WDT_MRST_32 WDTPW+WDTCNTCL /* TSMCLK*2POWER15=32ms 復位狀態 */
#define WDT_MRST_8 WDTPW+WDTCNTCL+WDTIS0 /* TSMCLK*2POWER13=8.192ms " */
#define WDT_MRST_0_5 WDTPW+WDTCNTCL+WDTIS1 /* TSMCLK*2POWER9=0.512ms " */
#define WDT_MRST_0_064 WDTPW+WDTCNTCL+WDTIS1+WDTIS0 /* TSMCLK*2POWER6=0.512ms " */
/* ACLK=32KHz看門狗模式 */
#define WDT_ARST_1000 WDTPW+WDTCNTCL+WDTSSEL /* TACLK*2POWER15=1000ms " */
#define WDT_ARST_250 WDTPW+WDTCNTCL+WDTSSEL+WDTIS0 /* TACLK*2POWER13=250ms " */
#define WDT_ARST_16 WDTPW+WDTCNTCL+WDTSSEL+WDTIS1 /* TACLK*2POWER9=16ms " */
#define WDT_ARST_1_9 WDTPW+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0 /* TACLK*2POWER6=1.9ms " */
硬件乘法器的寄存器定義
#define MPY_ 0x0130 /* 無符號乘法 */
sfrw MPY = MPY_;
#define MPYS_ 0x0132 /* 有符號乘法*/
sfrw MPYS = MPYS_;
#define MAC_ 0x0134 /* 無符號乘加 */
sfrw MAC = MAC_;
#define MACS_ 0x0136 /* 有符號乘加 */
sfrw MACS = MACS_;
#define OP2_ 0x0138 /* 第二乘數 */
sfrw OP2 = OP2_;
#define RESLO_ 0x013A /* 低6位結果寄存器 */
sfrw RESLO = RESLO_;
#define RESHI_ 0x013C /* 高6位結果寄存器 */
sfrw RESHI = RESHI_;
#define SUMEXT_ 0x013E /*結果擴展寄存器 */
const sfrw SUMEXT = SUMEXT_;
* DIGITAL I/O Port1/2 寄存器定義 有中斷功能
#define P1IN_ 0x0020 /* P1 輸入寄存器 */
const sfrb P1IN = P1IN_;
#define P1OUT_ 0x0021 /* P1 輸出寄存器 */
sfrb P1OUT = P1OUT_;
#define P1DIR_ 0x0022 /* P1 方向選擇寄存器 */
sfrb P1DIR = P1DIR_;
#define P1IFG_ 0x0023 /* P1 中斷標志寄存器*/
sfrb P1IFG = P1IFG_;
#define P1IES_ 0x0024 /* P1 中斷邊沿選擇寄存器*/
sfrb P1IES = P1IES_;
#define P1IE_ 0x0025 /* P1 中斷使能寄存器 */
sfrb P1IE = P1IE_;
#define P1SEL_ 0x0026 /* P1 功能選擇寄存器*/
sfrb P1SEL = P1SEL_;
#define P2IN_ 0x0028 /* P2 輸入寄存器 */
const sfrb P2IN = P2IN_;
#define P2OUT_ 0x0029 /* P2 輸出寄存器 */
sfrb P2OUT = P2OUT_;
#define P2DIR_ 0x002A /* P2 方向選擇寄存器 */
sfrb P2DIR = P2DIR_;
#define P2IFG_ 0x002B /* P2 中斷標志寄存器 */
sfrb P2IFG = P2IFG_;
#define P2IES_ 0x002C /* P2 中斷邊沿選擇寄存器 */
sfrb P2IES = P2IES_;
#define P2IE_ 0x002D /* P2 中斷使能寄存器 */
sfrb P2IE = P2IE_;
#define P2SEL_ 0x002E /* P2 功能選擇寄存器 */
sfrb P2SEL = P2SEL_;
* DIGITAL I/O Port3/4寄存器定義 無中斷功能
#define P3IN_ 0x0018 /* P3 輸入寄存器 */
const sfrb P3IN = P3IN_;
#define P3OUT_ 0x0019 /* P3 輸出寄存器 */
sfrb P3OUT = P3OUT_;
#define P3DIR_ 0x001A /* P3 方向選擇寄存器 */
sfrb P3DIR = P3DIR_;
#define P3SEL_ 0x001B /* P3 功能選擇寄存器*/
sfrb P3SEL = P3SEL_;
#define P4IN_ 0x001C /* P4 輸入寄存器 */
const sfrb P4IN = P4IN_;
#define P4OUT_ 0x001D /* P4 輸出寄存器 */
sfrb P4OUT = P4OUT_;
#define P4DIR_ 0x001E /* P4 方向選擇寄存器 */
sfrb P4DIR = P4DIR_;
#define P4SEL_ 0x001F /* P4 功能選擇寄存器 */
sfrb P4SEL = P4SEL_;
* DIGITAL I/O Port5/6 I/O口寄存器定義PORT5和6 無中斷功能
#define P5IN_ 0x0030 /* P5 輸入寄存器 */
const sfrb P5IN = P5IN_;
#define P5OUT_ 0x0031 /* P5 輸出寄存器*/
sfrb P5OUT = P5OUT_;
#define P5DIR_ 0x0032 /* P5 方向選擇寄存器*/
sfrb P5DIR = P5DIR_;
#define P5SEL_ 0x0033 /* P5 功能選擇寄存器*/
sfrb P5SEL = P5SEL_;
#define P6IN_ 0x0034 /* P6 輸入寄存器 */
const sfrb P6IN = P6IN_;
#define P6OUT_ 0x0035 /* P6 輸出寄存器*/
sfrb P6OUT = P6OUT_;
#define P6DIR_ 0x0036 /* P6 方向選擇寄存器*/
sfrb P6DIR = P6DIR_;
#define P6SEL_ 0x0037 /* P6 功能選擇寄存器*/
sfrb P6SEL = P6SEL_;
* USART 串口寄存器"UCTL","UTCTL","URCTL"定義的各個位 可串口1 串口2公用
/* UCTL 串口控制寄存器*/
#define PENA 0x80 /*校驗允許位*/
#define PEV 0x40 /*偶校驗 為0時為奇校驗*/
#define SPB 0x20 /*停止位為2 為0時停止位為1*/
#define CHAR 0x10 /*數據位為8位 為0時數據位為7位*/
#define LISTEN 0x08 /*自環模式(發數據同時在把發的數據接收回來)*/
#define SYNC 0x04 /*同步模式 為0異步模式*/
#define MM 0x02 /*為1時地址位多機協議(異步) 主機模式(同步);為0時線路空閑多機協議(異步) 從機模式(同步)*/
#define SWRST 0x01 /*控制位*/
/* UTCTL 串口發送控制寄存器*/
#define CKPH 0x80 /*時鐘相位控制位(只同步方式用)為1時時鐘UCLK延時半個周期*/
#define CKPL 0x40 /*時鐘極性控制位 為1時異步與UCLK相反;同步下降延有效*/
#define SSEL1 0x20 /*時鐘源選擇位:與SSEL0組合為0,1,2,3四種方式*/
#define SSEL0 0x10 /*"0"選擇外部時鐘,"1"選擇輔助時鐘,"2","3"選擇系統子時鐘 */
#define URXSE 0x08 /*接收觸發延控制位(只在異步方式下用)*/
#define TXWAKE 0x04 /*多處理器通信傳送控制位(只在異步方式下用)*/
#define STC 0x02 /*外部引腳STE選擇位 為0時為4線模式 為1時為3線模式*/
#define TXEPT 0x01 /*發送器空標志*/
/* URCTL 串口接收控制寄存器 同步模式下只用兩位:FE和OE*/
#define FE 0x80 /*幀錯標志*/
#define PE 0x40 /*校驗錯標志位*/
#define OE 0x20 /*溢出標志位*/
#define BRK 0x10 /*打斷檢測位*/
#define URXEIE 0x08 /*接收出錯中斷允許位*/
#define URXWIE 0x04 /*接收喚醒中斷允許位*/
#define RXWAKE 0x02 /*接收喚醒檢測位*/
#define RXERR 0x01 /*接收錯誤標志位*/
* USART 0 串口0寄存器定義
#define U0CTL_ 0x0070 /* 串口0基本控制寄存器 */
sfrb U0CTL = U0CTL_;
#define U0TCTL_ 0x0071 /* 串口0發送控制寄存器 */
sfrb U0TCTL = U0TCTL_;
#define U0RCTL_ 0x0072 /* 串口0接收控制寄存器 */
sfrb U0RCTL = U0RCTL_;
#define U0MCTL_ 0x0073 /* 波特率調整寄存器 */
sfrb U0MCTL = U0MCTL_;
#define U0BR0_ 0x0074 /* 波特率選擇寄存器0 */
sfrb U0BR0 = U0BR0_;
#define U0BR1_ 0x0075 /* 波特率選擇寄存器1 */
sfrb U0BR1 = U0BR1_;
#define U0RXBUF_ 0x0076 /* 接收緩存寄存器 */
const sfrb U0RXBUF = U0RXBUF_;
#define U0TXBUF_ 0x0077 /* 發送緩存寄存器 */
sfrb U0TXBUF = U0TXBUF_;
/* 改變的寄存器名定義 */
#define UCTL0_ 0x0070 /* UART 0 Control */
sfrb UCTL0 = UCTL0_;
#define UTCTL0_ 0x0071 /* UART 0 Transmit Control */
sfrb UTCTL0 = UTCTL0_;
#define URCTL0_ 0x0072 /* UART 0 Receive Control */
sfrb URCTL0 = URCTL0_;
#define UMCTL0_ 0x0073 /* UART 0 Modulation Control */
sfrb UMCTL0 = UMCTL0_;
#define UBR00_ 0x0074 /* UART 0 Baud Rate 0 */
sfrb UBR00 = UBR00_;
#define UBR10_ 0x0075 /* UART 0 Baud Rate 1 */
sfrb UBR10 = UBR10_;
#define RXBUF0_ 0x0076 /* UART 0 Receive Buffer */
const sfrb RXBUF0 = RXBUF0_;
#define TXBUF0_ 0x0077 /* UART 0 Transmit Buffer */
sfrb TXBUF0 = TXBUF0_;
#define UCTL_0_ 0x0070 /* UART 0 Control */
sfrb UCTL_0 = UCTL_0_;
#define UTCTL_0_ 0x0071 /* UART 0 Transmit Control */
sfrb UTCTL_0 = UTCTL_0_;
#define URCTL_0_ 0x0072 /* UART 0 Receive Control */
sfrb URCTL_0 = URCTL_0_;
#define UMCTL_0_ 0x0073 /* UART 0 Modulation Control */
sfrb UMCTL_0 = UMCTL_0_;
#define UBR0_0_ 0x0074 /* UART 0 Baud Rate 0 */
sfrb UBR0_0 = UBR0_0_;
#define UBR1_0_ 0x0075 /* UART 0 Baud Rate 1 */
sfrb UBR1_0 = UBR1_0_;
#define RXBUF_0_ 0x0076 /* UART 0 Receive Buffer */
const sfrb RXBUF_0 = RXBUF_0_;
#define TXBUF_0_ 0x0077 /* UART 0 Transmit Buffer */
sfrb TXBUF_0 = TXBUF_0_;
* USART 1 串口1寄存器定義
#define U1CTL_ 0x0078 /* 串口1基本控制寄存器 */
sfrb U1CTL = U1CTL_;
#define U1TCTL_ 0x0079 /* 串口1發送控制寄存器 */
sfrb U1TCTL = U1TCTL_;
#define U1RCTL_ 0x007A /* 串口1接收控制寄存器 */
sfrb U1RCTL = U1RCTL_;
#define U1MCTL_ 0x007B /* 波特率調整控制寄存器 */
sfrb U1MCTL = U1MCTL_;
#define U1BR0_ 0x007C /* 波特率選擇寄存器0 */
sfrb U1BR0 = U1BR0_;
#define U1BR1_ 0x007D /* 波特率選擇寄存器1 */
sfrb U1BR1 = U1BR1_;
#define U1RXBUF_ 0x007E /* 接收緩存 */
const sfrb U1RXBUF = U1RXBUF_;
#define U1TXBUF_ 0x007F /* 發送緩存 */
sfrb U1TXBUF = U1TXBUF_;
/* 改變的寄存器名定義 */
#define UCTL1_ 0x0078 /* UART 1 Control */
sfrb UCTL1 = UCTL1_;
#define UTCTL1_ 0x0079 /* UART 1 Transmit Control */
sfrb UTCTL1 = UTCTL1_;
#define URCTL1_ 0x007A /* UART 1 Receive Control */
sfrb URCTL1 = URCTL1_;
#define UMCTL1_ 0x007B /* UART 1 Modulation Control */
sfrb UMCTL1 = UMCTL1_;
#define UBR01_ 0x007C /* UART 1 Baud Rate 0 */
sfrb UBR01 = UBR01_;
#define UBR11_ 0x007D /* UART 1 Baud Rate 1 */
sfrb UBR11 = UBR11_;
#define RXBUF1_ 0x007E /* UART 1 Receive Buffer */
const sfrb RXBUF1 = RXBUF1_;
#define TXBUF1_ 0x007F /* UART 1 Transmit Buffer */
sfrb TXBUF1 = TXBUF1_;
#define UCTL_1_ 0x0078 /* UART 1 Control */
sfrb UCTL_1 = UCTL_1_;
#define UTCTL_1_ 0x0079 /* UART 1 Transmit Control */
sfrb UTCTL_1 = UTCTL_1_;
#define URCTL_1_ 0x007A /* UART 1 Receive Control */
sfrb URCTL_1 = URCTL_1_;
#define UMCTL_1_ 0x007B /* UART 1 Modulation Control */
sfrb UMCTL_1 = UMCTL_1_;
#define UBR0_1_ 0x007C /* UART 1 Baud Rate 0 */
sfrb UBR0_1 = UBR0_1_;
#define UBR1_1_ 0x007D /* UART 1 Baud Rate 1 */
sfrb UBR1_1 = UBR1_1_;
#define RXBUF_1_ 0x007E /* UART 1 Receive Buffer */
const sfrb RXBUF_1 = RXBUF_1_;
#define TXBUF_1_ 0x007F /* UART 1 Transmit Buffer */
sfrb TXBUF_1 = TXBUF_1_;
* Timer A 定時器A寄存器定義
#define TAIV_ 0x012E /* Timer A 中斷向量寄存器 */
sfrw TAIV = TAIV_;
#define TACTL_ 0x0160 /* Timer A 控制寄存器 */
sfrw TACTL = TACTL_;
#define TACCTL0_ 0x0162 /* Timer A 捕獲/比較控制寄存器0 */
sfrw TACCTL0 = TACCTL0_;
#define TACCTL1_ 0x0164 /* Timer A 捕獲/比較控制寄存器1 */
sfrw TACCTL1 = TACCTL1_;
#define TACCTL2_ 0x0166 /* Timer A 捕獲/比較控制寄存器2 */
sfrw TACCTL2 = TACCTL2_;
#define TAR_ 0x0170 /* Timer A 16位計數器內容*/
sfrw TAR = TAR_;
#define TACCR0_ 0x0172 /* Timer A 捕獲/比較寄存器0 */
sfrw TACCR0 = TACCR0_;
#define TACCR1_ 0x0174 /* Timer A 捕獲/比較寄存器1 */
sfrw TACCR1 = TACCR1_;
#define TACCR2_ 0x0176 /* Timer A 捕獲/比較寄存器2 */
sfrw TACCR2 = TACCR2_;
/* 改變的寄存器名定義 */
#define CCTL0_ 0x0162 /* Timer A Capture/Compare Control 0 */
sfrw CCTL0 = CCTL0_;
#define CCTL1_ 0x0164 /* Timer A Capture/Compare Control 1 */
sfrw CCTL1 = CCTL1_;
#define CCTL2_ 0x0166 /* Timer A Capture/Compare Control 2 */
sfrw CCTL2 = CCTL2_;
#define CCR0_ 0x0172 /* Timer A Capture/Compare 0 */
sfrw CCR0 = CCR0_;
#define CCR1_ 0x0174 /* Timer A Capture/Compare 1 */
sfrw CCR1 = CCR1_;
#define CCR2_ 0x0176 /* Timer A Capture/Compare 2 */
sfrw CCR2 = CCR2_;
/*TACTL 控制寄存器 16個位寄存器定義*/
#define TASSEL2 0x0400 /* 未用 */
#define TASSEL1 0x0200 /* 時鐘輸入源控制位1 */
#define TASSEL0 0x0100 /* 時鐘輸入源控制位0 */
#define ID1 0x0080 /* 分頻系數選擇位1 */
#define ID0 0x0040 /* 分頻系數選擇位0 */
#define MC1 0x0020 /* 計數模式控制位1 */
#define MC0 0x0010 /* 計數模式控制位0 */
#define TACLR 0x0004 /* 置1位清除定時器 */
#define TAIE 0x0002 /* 定時器中斷允許 */
#define TAIFG 0x0001 /* 定時器中斷標志 */
#define MC_0 00*0x10 /* 停止模式 */
#define MC_1 01*0x10 /* 增計數模式 */
#define MC_2 02*0x10 /* 連續計數模式 */
#define MC_3 03*0x10 /* 增/減計數模式 */
#define ID_0 00*0x40 /* 直通 */
#define ID_1 01*0x40 /* 2分頻 */
#define ID_2 02*0x40 /* 4分頻 */
#define ID_3 03*0x40 /* 8分頻 */
#define TASSEL_0 00*0x100 /* 時鐘源為 TACLK */
#define TASSEL_1 01*0x100 /* 時鐘源為ACLK */
#define TASSEL_2 02*0x100 /* 時鐘源為SMCLK */
#define TASSEL_3 03*0x100 /* 時鐘源為INCLK */
/* Timer A ,Timer B 可公用 捕獲/比較控制寄存器X */
#define CM1 0x8000 /* 捕獲模式選擇位1 */
#define CM0 0x4000 /* 捕獲模式選擇位0 */
#define CCIS1 0x2000 /* 捕獲輸入信號源選擇位1 */
#define CCIS0 0x1000 /* 捕獲輸入信號源選擇位0 */
#define SCS 0x0800 /* 信號同步位 0:異步捕獲;1:同步捕獲 */
#define SCCI 0x0400 /* 鎖存輸入信號 */
#define CAP 0x0100 /* 模式選擇: 0:比較模式;1:捕獲模式 */
#define OUTMOD2 0x0080 /* 輸出模式選擇位2 */
#define OUTMOD1 0x0040 /* 輸出模式選擇位1 */
#define OUTMOD0 0x0020 /* 輸出模式選擇位0 */
#define CCIE 0x0010 /* 中斷允許位 */
#define CCI 0x0008 /* 讀出輸入信號源位ccis0\1 */
#define OUT 0x0004 /* 輸出信號(選擇輸出模式0) */
#define COV 0x0002 /* 捕獲溢出標志 */
#define CCIFG 0x0001 /* 中斷標志 */
#define OUTMOD_0 0*0x20 /* 輸出模式 */
#define OUTMOD_1 1*0x20 /* 置位模式 */
#define OUTMOD_2 2*0x20 /* 翻轉/復位模式 */
#define OUTMOD_3 3*0x20 /* 置位/復位模式 */
#define OUTMOD_4 4*0x20 /* 翻轉模式 */
#define OUTMOD_5 5*0x20 /* 復位模式 */
#define OUTMOD_6 6*0x20 /* 翻轉/置位模式 */
#define OUTMOD_7 7*0x20 /* 復位/置位模式*/
#define CCIS_0 0*0x1000 /* 選擇CCIXA為捕獲事件的輸入信號源 */
#define CCIS_1 1*0x1000 /* 選擇CCIXB為捕獲事件的輸入信號源 */
#define CCIS_2 2*0x1000 /* 選擇GND為捕獲事件的輸入信號源 */
#define CCIS_3 3*0x1000 /* 選擇VCC為捕獲事件的輸入信號源 */
#define CM_0 0*0x4000 /* 禁止捕獲模式 */
#define CM_1 1*0x4000 /* 上升延捕獲模式 */
#define CM_2 2*0x4000 /* 下降沿捕獲模式 */
#define CM_3 3*0x4000 /* 上升沿和下降沿都捕獲模式 */
* Timer B 定時器B寄存器定義
#define TBIV_ 0x011E /* 中斷向量寄存器:BIT1-BIT3有效 */
sfrw TBIV = TBIV_;
#define TBCTL_ 0x0180 /* 定時器B控制寄存器:全部控制都集中在這 */
sfrw TBCTL = TBCTL_;
#define TBCCTL0_ 0x0182 /* 定時器B捕獲/比較控制寄存器0*/
sfrw TBCCTL0 = TBCCTL0_;
#define TBCCTL1_ 0x0184 /* 定時器B捕獲/比較控制寄存器1 */
sfrw TBCCTL1 = TBCCTL1_;
#define TBCCTL2_ 0x0186 /* 定時器B捕獲/比較控制寄存器2 */
sfrw TBCCTL2 = TBCCTL2_;
#define TBCCTL3_ 0x0188 /* 定時器B捕獲/比較控制寄存器3 */
sfrw TBCCTL3 = TBCCTL3_;
#define TBCCTL4_ 0x018A /* 定時器B捕獲/比較控制寄存器4 */
sfrw TBCCTL4 = TBCCTL4_;
#define TBCCTL5_ 0x018C /* 定時器B捕獲/比較控制寄存器5 */
sfrw TBCCTL5 = TBCCTL5_;
#define TBCCTL6_ 0x018E /* 定時器B捕獲/比較控制寄存器6 */
sfrw TBCCTL6 = TBCCTL6_;
#define TBR_ 0x0190 /* 計數器 */
sfrw TBR = TBR_;
#define TBCCR0_ 0x0192 /* 定時器B捕獲/比較寄存器0 */
sfrw TBCCR0 = TBCCR0_;
#define TBCCR1_ 0x0194 /* 定時器B捕獲/比較寄存器1 */
sfrw TBCCR1 = TBCCR1_;
#define TBCCR2_ 0x0196 /* 定時器B捕獲/比較寄存器2 */
sfrw TBCCR2 = TBCCR2_;
#define TBCCR3_ 0x0198 /* 定時器B捕獲/比較寄存器3 */
sfrw TBCCR3 = TBCCR3_;
#define TBCCR4_ 0x019A /* 定時器B捕獲/比較寄存器4 */
sfrw TBCCR4 = TBCCR4_;
#define TBCCR5_ 0x019C /* 定時器B捕獲/比較寄存器5 */
sfrw TBCCR5 = TBCCR5_;
#define TBCCR6_ 0x019E /* 定時器B捕獲/比較寄存器6 */
sfrw TBCCR6 = TBCCR6_;
#define SHR1 0x4000 /* 裝載比較鎖存器控制位1 :受TBCCTLx中的CCLDx位控制 */
#define SHR0 0x2000 /* 裝載比較鎖存器控制位0 :受TBCCTLx中的CCLDx位控制*/
#define TBCLGRP1 0x4000 /* 裝載比較鎖存器控制位1 :受TBCCTLx中的CCLDx位控制*/
#define TBCLGRP0 0x2000 /* 裝載比較鎖存器控制位0 :受TBCCTLx中的CCLDx位控制*/
#define CNTL1 0x1000 /* 定時器位數長度控制位1 */
#define CNTL0 0x0800 /* 定時器位數長度控制位0 */
#define TBSSEL2 0x0400 /* 未用 */
#define TBSSEL1 0x0200 /* 時鐘輸入源控制位1 */
#define TBSSEL0 0x0100 /* 時鐘輸入源控制位0 */
#define TBCLR 0x0004 /* 置1清除定時器 */
#define TBIE 0x0002 /* 中斷允許 */
#define TBIFG 0x0001 /* 中斷標志 */
#define TBSSEL_0 0*0x0100 /* 時鐘源為:TBCLK */
#define TBSSEL_1 1*0x0100 /* 時鐘源為: ACLK */
#define TBSSEL_2 2*0x0100 /* 時鐘源為:SMCLK */
#define TBSSEL_3 3*0x0100 /* 時鐘源為:INCLK */
#define CNTL_0 0*0x0800 /* 16 位計數模式*/
#define CNTL_1 1*0x0800 /* 12 位計數模式*/
#define CNTL_2 2*0x0800 /* 10 位計數模式 */
#define CNTL_3 3*0x0800 /* 8 位計數模式 */
#define SHR_0 0*0x2000 /* 單獨裝載(初始值) */
#define SHR_1 1*0x2000 /* 分三組裝載: 1 - 3 groups (1-2, 3-4, 5-6) */
#define SHR_2 2*0x2000 /* 分二組裝載: 2 - 2 groups (1-3, 4-6)*/
#define SHR_3 3*0x2000 /* 不分組裝載: 3 - 1 group (all) */
#define TBCLGRP_0 0*0x2000 /* 單獨裝載(初始值) */
#define TBCLGRP_1 1*0x2000 /* 分三組裝載: 1 - 3 groups (1-2, 3-4, 5-6) */
#define TBCLGRP_2 2*0x2000 /* 分二組裝載: 2 - 2 groups (1-3, 4-6)*/
#define TBCLGRP_3 3*0x2000 /* 不分組裝載: 3 - 1 group (all) */
/* Additional Timer B Control Register bits are defined in Timer A */
#define SLSHR1 0x0400 /* Compare latch load source 1 */
#define SLSHR0 0x0200 /* Compare latch load source 0 */
#define CLLD1 0x0400 /* 定義比較鎖存器TBCLx的裝載方式控制位1 */
#define CLLD0 0x0200 /* 定義比較鎖存器TBCLx的裝載方式控制位0 */
#define SLSHR_0 0*0x0200 /* 立即裝載 */
#define SLSHR_1 1*0x0200 /* TBR 計數到0時裝載 */
#define SLSHR_2 2*0x0200 /* 在增減模式下,計數到TBCLx或0時裝載; 在連續計數模式下,計數到0時裝載 */
#define SLSHR_3 3*0x0200 /* 當計數到TBCL0時裝載*/
#define CLLD_0 0*0x0200 /* 立即裝載 */
#define CLLD_1 1*0x0200 /* TBR 計數到0時裝載 */
#define CLLD_2 2*0x0200 /* 在增減模式下,計數到TBCLx或0時裝載; 在連續計數模式下,計數到0時裝載 */
#define CLLD_3 3*0x0200 /* 當計數到TBCL0時裝載 */
* Basic Clock Module
#define DCOCTL_ 0x0056 /* DCO 時鐘頻率控制寄存器 :復位后的值位060h*/
sfrb DCOCTL = DCOCTL_;
#define BCSCTL1_ 0x0057 /* 系統時鐘控制寄存器1 :復位后的值位084h*/
sfrb BCSCTL1 = BCSCTL1_;
#define BCSCTL2_ 0x0058 /* 系統時鐘控制寄存器2 :復位后的值位000h*/
sfrb BCSCTL2 = BCSCTL2_;
/* DCO 時鐘頻率控制寄存器 */
#define MOD0 0x01 /* DCO插入周期控制位0 */
#define MOD1 0x02 /* DCO插入周期控制位1 */
#define MOD2 0x04 /* DCO插入周期控制位2 */
#define MOD3 0x08 /* DCO插入周期控制位3 */
#define MOD4 0x10 /* DCO插入周期控制位4 */
#define DCO0 0x20 /* 8種頻率控制位0 */
#define DCO1 0x40 /* 8種頻率控制位1 */
#define DCO2 0x80 /* 8種頻率控制位2 */
#define RSEL0 0x01 /* 選擇內部電阻控制位0 */
#define RSEL1 0x02 /* 選擇內部電阻控制位1 */
#define RSEL2 0x04 /* 選擇內部電阻控制位2 */
#define XT5V 0x08 /* 必須為0*/
#define DIVA0 0x10 /* ACLK分頻系數控制位0*/
#define DIVA1 0x20 /* ACLK分頻系數控制位1 */
#define XTS 0x40 /* LFXT1工作模式控制位 0:低頻模式. / 1: 高頻模式. */
#define XT2OFF 0x80 /* XT2CLK 使能控制位 0:開啟; 1:關閉 */
#define DIVA_0 0x00 /* ACLK分頻系數為: 1 */
#define DIVA_1 0x10 /* ACLK分頻系數為: 2 */
#define DIVA_2 0x20 /* ACLK分頻系數為: 4 */
#define DIVA_3 0x30 /* ACLK分頻系數為: 8 */
#define DCOR 0x01 /* 內外電阻選擇控制位 */
#define DIVS0 0x02 /* SMCLK分頻控制位0*/
#define DIVS1 0x04 /* SMCLK分頻控制位1 */
#define SELS 0x08 /* SMCLK 時鐘源選擇位t 0:DCOCLK / 1:XT2CLK/LFXTCLK */
#define DIVM0 0x10 /* MCLK分頻控制位0 */
#define DIVM1 0x20 /* MCLK分頻控制位1 */
#define SELM0 0x40 /* MCLK 時鐘輸入源選擇位0 */
#define SELM1 0x80 /* MCLK 時鐘輸入源選擇位1 */
#define DIVS_0 0x00 /* SMCLK 分頻系數為: 1 */
#define DIVS_1 0x02 /* SMCLK 分頻系數為: 2 */
#define DIVS_2 0x04 /* SMCLK 分頻系數為: 4 */
#define DIVS_3 0x06 /* SMCLK 分頻系數為: 8 */
#define DIVM_0 0x00 /* MCLK 分頻系數為: 1 */
#define DIVM_1 0x10 /* MCLK 分頻系數為: 2 */
#define DIVM_2 0x20 /* MCLK 分頻系數為: 4 */
#define DIVM_3 0x30 /* MCLK 分頻系數為: 8 */
#define SELM_0 0x00 /* MCLK 時鐘輸入源: DCOCLK */
#define SELM_1 0x40 /* MCLK 時鐘輸入源: DCOCLK */
#define SELM_2 0x80 /* MCLK 時鐘輸入源: XT2CLK/LFXTCLK */
#define SELM_3 0xC0 /* MCLK 時鐘輸入源: LFXTCLK */
* Flash Memory FLASH操作寄存器定義
#define FCTL1_ 0x0128 /* FLASH控制寄存器1:控制編程、擦除 */
sfrw FCTL1 = FCTL1_;
#define FCTL2_ 0x012A /* FLASH 控制寄存器2 :控制時鐘分頻*/
sfrw FCTL2 = FCTL2_;
#define FCTL3_ 0x012C /* FLASH 控制寄存器3: 狀態標志 */
sfrw FCTL3 = FCTL3_;
#define FRKEY 0x9600 /* 讀FLASH 密碼 */
#define FWKEY 0xA500 /* 寫FLASH 密碼 */
#define FXKEY 0x3300 /* for use with XOR instruction */
#define ERASE 0x0002 /* 擦除段使能 */
#define MERAS 0x0004 /* 主存擦除使能 */
#define WRT 0x0040 /* 編程使能 */
#define BLKWRT 0x0080 /* 段編程使能 */
#define FN_0 0x0000 /*直通 */
#define FN_1 0x0001 /*2分頻 */
#define FN_2 0x0002 /*3分頻*/
#define FN_3 0x0003 /*4分頻 */
#define FN_4 0x0004 /*5分頻 */
#define FN_5 0x0005 /*6分頻*/
#define FN_6 0x0006 /*7分頻 */
#define FN_7 0x0007 /*8分頻*/
#define FN_8 0x0008 /*9分頻 */
#define FN_9 0x0009 /*10分頻 */
#define FN_10 0x000A /*11分頻*/
#define FN_11 0x000B /*12分頻 */
#define FN_12 0x000C /*13分頻*/
#define FN_13 0x000D /*14分頻 */
#define FN_14 0x000E /*15分頻 */
#define FN_15 0x000F /*16分頻*/
#define FN_16 0x0010 /*17分頻 */
#define FN_17 0x0011 /*18分頻*/
#define FN_18 0x0012 /*19分頻 */
#define FN_19 0x0013 /*20分頻 */
#define FN_20 0x0014 /*21分頻*/
#define FN_21 0x0015 /*22分頻 */
#define FN_22 0x0016 /*23分頻*/
#define FN_23 0x0017 /*24分頻 */
#define FN_24 0x0018 /*25分頻 */
#define FN_25 0x0019 /*26分頻*/
#define FN_26 0x001A /*27分頻 */
#define FN_27 0x001B /*28分頻*/
#define FN_28 0x001C /*29分頻 */
#define FN_29 0x001D /*30分頻 */
#define FN_30 0x001E /*31分頻*/
#define FN_31 0x001F /*32分頻 */
#define FN_32 0x0020 /*33分頻*/
#define FN_33 0x0021 /*34分頻 */
#define FN_34 0x0022 /*35分頻 */
#define FN_35 0x0023 /*36分頻*/
#define FN_36 0x0024 /*37分頻 */
#define FN_37 0x0025 /*38分頻*/
#define FN_38 0x0026 /*39分頻 */
#define FN_39 0x0027 /*40分頻 */
#define FN_40 0x0028 /*41分頻*/
#define FN_41 0x0029 /*42分頻 */
#define FN_42 0x002A /*43分頻*/
#define FN_43 0x002B /*44分頻 */
#define FN_44 0x002C /*45分頻 */
#define FN_45 0x002D /*46分頻*/
#define FN_46 0x002E /*47分頻 */
#define FN_47 0x002F /*48分頻*/
#define FN_48 0x0030 /*49分頻 */
#define FN_49 0x0031 /*50分頻 */
#define FN_50 0x0032 /*51分頻*/
#define FN_51 0x0033 /*52分頻 */
#define FN_52 0x0034 /*53分頻*/
#define FN_53 0x0035 /*54分頻 */
#define FN_54 0x0036 /*55分頻 */
#define FN_55 0x0037 /*56分頻*/
#define FN_56 0x0038 /*57分頻 */
#define FN_57 0x0039 /*58分頻*/
#define FN_58 0x003A /*59分頻 */
#define FN_59 0x003B /*60分頻 */
#define FN_60 0x003C /*61分頻*/
#define FN_61 0x003D /*62分頻 */
#define FN_62 0x003E /*63分頻*/
#define FN_63 0x003F /*64分頻 */
#define FSSEL_0 0x0000 /* Flash時鐘選擇: ACLK */
#define FSSEL_1 0x0040 /* Flash時鐘選擇: MCLK */
#define FSSEL_2 0x0080 /* Flash時鐘選擇: SMCLK */
#define FSSEL_3 0x00C0 /* Flash時鐘選擇: SMCLK */
#define BUSY 0x0001 /* Flash忙標志*/
#define KEYV 0x0002 /* Flash安全鍵值出錯標志 */
#define ACCVIFG 0x0004 /* Flash非法訪問中斷標志*/
#define WAIT 0x0008 /* 等待指示信號位*/
#define LOCK 0x0010 /* 鎖定位 */
#define EMEX 0x0020 /* 緊急退出位 */
* Comparator A 比較器A寄存器定義
#define CACTL1_ 0x0059 /* 比較器A控制寄存器1 */
sfrb CACTL1 = CACTL1_;
#define CACTL2_ 0x005A /* 比較器A控制寄存器2 */
sfrb CACTL2 = CACTL2_;
#define CAPD_ 0x005B /*比較器A端口禁止寄存器*/
sfrb CAPD = CAPD_;
/* 比較器A控制寄存器1 */
#define CAIFG 0x01 /*比較器A中斷標志*/
#define CAIE 0x02 /* 比較器A中斷使能 */
#define CAIES 0x04 /* 比較器A中斷邊沿觸發選擇 0:上升延 1:下降延 */
#define CAON 0x08 /* 比較器電源開關*/
#define CAREF0 0x10 /* 選擇參考源位0 */
#define CAREF1 0x20 /* 選擇參考源位1 */
#define CARSEL 0x40 /* 選擇內部參考源加到比較器的正端或負端 */
#define CAEX 0x80 /* 交換比較器的輸入端 */
#define CAREF_0 0x00 /* 選擇參考源0 : Off 使用外部參考源*/
#define CAREF_1 0x10 /* 選擇參考源1 : 0.25*Vcc為參考源 */
#define CAREF_2 0x20 /* 選擇參考源2 : 0.5*Vcc為參考源 */
#define CAREF_3 0x30 /* 選擇參考源3 : Vt*/
/* 比較器A控制寄存器2 */
#define CAOUT 0x01 /* 比較器輸出 */
#define CAF 0x02 /* 選擇比較器是否經過RC低通濾波器 */
#define P2CA0 0x04 /* 外部引腳信號連接到比較器A的CA0 */
#define P2CA1 0x08 /* 外部引腳信號連接到比較器A的CA1 */
#define CACTL24 0x10
#define CACTL25 0x20
#define CACTL26 0x40
#define CACTL27 0x80
#define CAPD0 0x01 /* Comp. A Disable Input Buffer of Port Register .0 */
#define CAPD1 0x02 /* Comp. A Disable Input Buffer of Port Register .1 */
#define CAPD2 0x04 /* Comp. A Disable Input Buffer of Port Register .2 */
#define CAPD3 0x08 /* Comp. A Disable Input Buffer of Port Register .3 */
#define CAPD4 0x10 /* Comp. A Disable Input Buffer of Port Register .4 */
#define CAPD5 0x20 /* Comp. A Disable Input Buffer of Port Register .5 */
#define CAPD6 0x40 /* Comp. A Disable Input Buffer of Port Register .6 */
#define CAPD7 0x80 /* Comp. A Disable Input Buffer of Port Register .7 */
* ADC12 A/D采樣寄存器定義
/*ADC12轉換控制類寄存器*/
#define ADC12CTL0_ 0x0;' /* ADC12 Control 0 */
sfrw ADC12CTL0 = ADC12CTL0_;
#define ADC12CTL1_ 0x01A2 /* ADC12 Control 1 */
sfrw ADC12CTL1 = ADC12CTL1_;
/*ADC12中斷控制類寄存器*/
#define ADC12IFG_ 0x01A4 /* ADC12 Interrupt Flag */
sfrw ADC12IFG = ADC12IFG_;
#define ADC12IE_ 0x01A6 /* ADC12 Interrupt Enable */
sfrw ADC12IE = ADC12IE_;
#define ADC12IV_ 0x01A8 /* ADC12 Interrupt Vector Word */
sfrw ADC12IV = ADC12IV_;
/*ADC12存貯器類寄存器*/
#define ADC12MEM_ 0x0140 /* ADC12 Conversion Memory */
#define ADC12MEM ADC12MEM_ /* ADC12 Conversion Memory (for assembler) */
#else
#define ADC12MEM ((int*) ADC12MEM_) /* ADC12 Conversion Memory (for C) */
#endif
#define ADC12MEM0_ ADC12MEM_ /* ADC12 Conversion Memory 0 */
sfrw ADC12MEM0 = ADC12MEM0_;
#define ADC12MEM1_ 0x0142 /* ADC12 Conversion Memory 1 */
sfrw ADC12MEM1 = ADC12MEM1_;
#define ADC12MEM2_ 0x0144 /* ADC12 Conversion Memory 2 */
sfrw ADC12MEM2 = ADC12MEM2_;
#define ADC12MEM3_ 0x0146 /* ADC12 Conversion Memory 3 */
sfrw ADC12MEM3 = ADC12MEM3_;
#define ADC12MEM4_ 0x0148 /* ADC12 Conversion Memory 4 */
sfrw ADC12MEM4 = ADC12MEM4_;
#define ADC12MEM5_ 0x014A /* ADC12 Conversion Memory 5 */
sfrw ADC12MEM5 = ADC12MEM5_;
#define ADC12MEM6_ 0x014C /* ADC12 Conversion Memory 6 */
sfrw ADC12MEM6 = ADC12MEM6_;
#define ADC12MEM7_ 0x014E /* ADC12 Conversion Memory 7 */
sfrw ADC12MEM7 = ADC12MEM7_;
#define ADC12MEM8_ 0x0150 /* ADC12 Conversion Memory 8 */
sfrw ADC12MEM8 = ADC12MEM8_;
#define ADC12MEM9_ 0x0152 /* ADC12 Conversion Memory 9 */
sfrw ADC12MEM9 = ADC12MEM9_;
#define ADC12MEM10_ 0x0154 /* ADC12 Conversion Memory 10 */
sfrw ADC12MEM10 = ADC12MEM10_;
#define ADC12MEM11_ 0x0156 /* ADC12 Conversion Memory 11 */
sfrw ADC12MEM11 = ADC12MEM11_;
#define ADC12MEM12_ 0x0158 /* ADC12 Conversion Memory 12 */
sfrw ADC12MEM12 = ADC12MEM12_;
#define ADC12MEM13_ 0x015A /* ADC12 Conversion Memory 13 */
sfrw ADC12MEM13 = ADC12MEM13_;
#define ADC12MEM14_ 0x015C /* ADC12 Conversion Memory 14 */
sfrw ADC12MEM14 = ADC12MEM14_;
#define ADC12MEM15_ 0x015E /* ADC12 Conversion Memory 15 */
sfrw ADC12MEM15 = ADC12MEM15_;
/*ADC12存貯控制類寄存器*/
#define ADC12MCTL_ 0x0080 /* ADC12 Memory Control */
#define ADC12MCTL ADC12MCTL_ /* ADC12 Memory Control (for assembler) */
#else
#define ADC12MCTL ((char*) ADC12MCTL_) /* ADC12 Memory Control (for C) */
#endif
#define ADC12MCTL0_ ADC12MCTL_ /* ADC12 Memory Control 0 */
sfrb ADC12MCTL0 = ADC12MCTL0_;
#define ADC12MCTL1_ 0x0081 /* ADC12 Memory Control 1 */
sfrb ADC12MCTL1 = ADC12MCTL1_;
#define ADC12MCTL2_ 0x0082 /* ADC12 Memory Control 2 */
sfrb ADC12MCTL2 = ADC12MCTL2_;
#define ADC12MCTL3_ 0x0083 /* ADC12 Memory Control 3 */
sfrb ADC12MCTL3 = ADC12MCTL3_;
#define ADC12MCTL4_ 0x0084 /* ADC12 Memory Control 4 */
sfrb ADC12MCTL4 = ADC12MCTL4_;
#define ADC12MCTL5_ 0x0085 /* ADC12 Memory Control 5 */
sfrb ADC12MCTL5 = ADC12MCTL5_;
#define ADC12MCTL6_ 0x0086 /* ADC12 Memory Control 6 */
sfrb ADC12MCTL6 = ADC12MCTL6_;
#define ADC12MCTL7_ 0x0087 /* ADC12 Memory Control 7 */
sfrb ADC12MCTL7 = ADC12MCTL7_;
#define ADC12MCTL8_ 0x0088 /* ADC12 Memory Control 8 */
sfrb ADC12MCTL8 = ADC12MCTL8_;
#define ADC12MCTL9_ 0x0089 /* ADC12 Memory Control 9 */
sfrb ADC12MCTL9 = ADC12MCTL9_;
#define ADC12MCTL10_ 0x008A /* ADC12 Memory Control 10 */
sfrb ADC12MCTL10 = ADC12MCTL10_;
#define ADC12MCTL11_ 0x008B /* ADC12 Memory Control 11 */
sfrb ADC12MCTL11 = ADC12MCTL11_;
#define ADC12MCTL12_ 0x008C /* ADC12 Memory Control 12 */
sfrb ADC12MCTL12 = ADC12MCTL12_;
#define ADC12MCTL13_ 0x008D /* ADC12 Memory Control 13 */
sfrb ADC12MCTL13 = ADC12MCTL13_;
#define ADC12MCTL14_ 0x008E /* ADC12 Memory Control 14 */
sfrb ADC12MCTL14 = ADC12MCTL14_;
#define ADC12MCTL15_ 0x008F /* ADC12 Memory Control 15 */
sfrb ADC12MCTL15 = ADC12MCTL15_;
/* ADC12CTL0 內16位控制寄存器位*/
#define ADC12SC 0x001 /*采樣/轉換控制位*/
#define ENC 0x002 /* 轉換允許位*/
#define ADC12TOVIE 0x004 /*轉換時間溢出中斷允許位*/
#define ADC12OVIE 0x008 /*溢出中斷允許位*/
#define ADC12ON 0x010 /*ADC12內核控制位*/
#define REFON 0x020 /*參考電壓控制位*/
#define REF2_5V 0x040 /*內部參考電壓的電壓值選擇位 '0'為1.5V; '1'為2.5V*/
#define MSH 0x080 /*多次采樣/轉換位*/
#define MSC 0x080 /*多次采樣/轉換位*/
/*SHT0 采樣保持定時器0 控制ADC12的結果存貯器MEM0~MEM7的采樣周期*/
#define SHT0_0 0*0x100 /*采樣周期=TADC12CLK*4 */
#define SHT0_1 1*0x100 /*采樣周期=TADC12CLK*8 */
#define SHT0_2 2*0x100 /*采樣周期=TADC12CLK*16 */
#define SHT0_3 3*0x100 /*采樣周期=TADC12CLK*32 */
#define SHT0_4 4*0x100 /*采樣周期=TADC12CLK*64 */
#define SHT0_5 5*0x100 /*采樣周期=TADC12CLK*96 */
#define SHT0_6 6*0x100 /*采樣周期=TADC12CLK*128 */
#define SHT0_7 7*0x100 /*采樣周期=TADC12CLK*192 */
#define SHT0_8 8*0x100 /*采樣周期=TADC12CLK*256 */
#define SHT0_9 9*0x100 /*采樣周期=TADC12CLK*384 */
#define SHT0_10 10*0x100 /*采樣周期=TADC12CLK*512 */
#define SHT0_11 11*0x100 /*采樣周期=TADC12CLK*768 */
#define SHT0_12 12*0x100 /*采樣周期=TADC12CLK*1024 */
#define SHT0_13 13*0x100 /*采樣周期=TADC12CLK*1024 */
#define SHT0_14 14*0x100 /*采樣周期=TADC12CLK*1024 */
#define SHT0_15 15*0x100 /*采樣周期=TADC12CLK*1024 */
/*SHT1 采樣保持定時器1 控制ADC12的結果存貯器MEM8~MEM15的采樣周期*/
#define SHT1_0 0*0x100 /*采樣周期=TADC12CLK*4 */
#define SHT1_1 1*0x100 /*采樣周期=TADC12CLK*8 */
#define SHT1_2 2*0x100 /*采樣周期=TADC12CLK*16 */
#define SHT1_3 3*0x100 /*采樣周期=TADC12CLK*32 */
#define SHT1_4 4*0x100 /*采樣周期=TADC12CLK*64 */
#define SHT1_5 5*0x100 /*采樣周期=TADC12CLK*96 */
#define SHT1_6 6*0x100 /*采樣周期=TADC12CLK*128 */
#define SHT1_7 7*0x100 /*采樣周期=TADC12CLK*192 */
#define SHT1_8 8*0x100 /*采樣周期=TADC12CLK*256 */
#define SHT1_9 9*0x100 /*采樣周期=TADC12CLK*384 */
#define SHT1_10 10*0x100 /*采樣周期=TADC12CLK*512 */
#define SHT1_11 11*0x100 /*采樣周期=TADC12CLK*768 */
#define SHT1_12 12*0x100 /*采樣周期=TADC12CLK*1024 */
#define SHT1_13 13*0x100 /*采樣周期=TADC12CLK*1024 */
#define SHT1_14 14*0x100 /*采樣周期=TADC12CLK*1024 */
#define SHT1_15 15*0x100 /*采樣周期=TADC12CLK*1024 */
/* ADC12CTL1 內16位控制寄存器位*/
#define ADC12BUSY 0x0001 /*ADC12忙標志位*/
#define CONSEQ_0 0*2 /*單通道單次轉換*/
#define CONSEQ_1 1*2 /*序列通道單次轉換*/
#define CONSEQ_2 2*2 /*單通道多次轉換*/
#define CONSEQ_3 3*2 /*序列通道多次轉換*/
#define ADC12SSEL_0 0*8 /*ADC12內部時鐘源*/
#define ADC12SSEL_1 1*8 /*ACLK*/
#define ADC12SSEL_2 2*8 /*MCLK*/
#define ADC12SSEL_3 3*8 /*SCLK*/
#define ADC12DIV_0 0*0x20 /*1分頻*/
#define ADC12DIV_1 1*0x20 /*2分頻*/
#define ADC12DIV_2 2*0x20 /*3分頻*/
#define ADC12DIV_3 3*0x20 /*4分頻*/
#define ADC12DIV_4 4*0x20 /*5分頻*/
#define ADC12DIV_5 5*0x20 /*6分頻*/
#define ADC12DIV_6 6*0x20 /*7分頻*/
#define ADC12DIV_7 7*0x20 /*8分頻*/
#define ISSH 0x0100 /*采樣輸入信號反向與否控制位*/
#define SHP 0x0200 /*采樣信號(SAMPCON)選擇控制位*/
#define SHS_0 0*0x400 /*采樣信號輸入源選擇控制位 ADC12SC*/
#define SHS_1 1*0x400 /*采樣信號輸入源選擇控制位 TIMER_A.OUT1*/
#define SHS_2 2*0x400 /*采樣信號輸入源選擇控制位 TIMER_B.OUT0*/
#define SHS_3 3*0x400 /*采樣信號輸入源選擇控制位 TIMER_B.OUT1*/
/*轉換存貯器地址定義位*/
#define CSTARTADD_0 0*0x1000 /*選擇MEM0首地址*/
#define CSTARTADD_1 1*0x1000 /*選擇MEM1首地址*/
#define CSTARTADD_2 2*0x1000 /*選擇MEM2首地址*/
#define CSTARTADD_3 3*0x1000 /*選擇MEM3首地址*/
#define CSTARTADD_4 4*0x1000 /*選擇MEM4首地址*/
#define CSTARTADD_5 5*0x1000 /*選擇MEM5首地址*/
#define CSTARTADD_6 6*0x1000 /*選擇MEM6首地址*/
#define CSTARTADD_7 7*0x1000 /*選擇MEM7首地址*/
#define CSTARTADD_8 8*0x1000 /*選擇MEM8首地址*/
#define CSTARTADD_9 9*0x1000 /*選擇MEM9首地址*/
#define CSTARTADD_10 10*0x1000 /*選擇MEM10首地址*/
#define CSTARTADD_11 11*0x1000 /*選擇MEM11首地址*/
#define CSTARTADD_12 12*0x1000 /*選擇MEM12首地址*/
#define CSTARTADD_13 13*0x1000 /*選擇MEM13首地址*/
#define CSTARTADD_14 14*0x1000 /*選擇MEM14首地址*/
#define CSTARTADD_15 15*0x1000 /*選擇MEM15首地址*/
/* ADC12MCTLx */
#define INCH_0 0 /*選擇模擬量通道0 A0 */
#define INCH_1 1 /*選擇模擬量通道0 A1*/
#define INCH_2 2 /*選擇模擬量通道0 A2*/
#define INCH_3 3 /*選擇模擬量通道0 A3*/
#define INCH_4 4 /*選擇模擬量通道0 A4*/
#define INCH_5 5 /*選擇模擬量通道0 A5*/
#define INCH_6 6 /*選擇模擬量通道0 A6*/
#define INCH_7 7 /*選擇模擬量通道0 A7*/
#define INCH_8 8 /*VEREF+*/
#define INCH_9 9 /*VEREF-*/
#define INCH_10 10 /*片內溫度傳感器的輸出*/
#define INCH_11 11 /*(AVCC-AVSS)/2*/
#define INCH_12 12 /*(AVCC-AVSS)/2*/
#define INCH_13 13 /*(AVCC-AVSS)/2*/
#define INCH_14 14 /*(AVCC-AVSS)/2*/
#define INCH_15 15 /*(AVCC-AVSS)/2*/
/*參考電壓源選擇位*/
#define SREF_0 0*0x10 /*VR+ = AVCC; VR- = AVSS*/
#define SREF_1 1*0x10 /*VR+ = VREF+; VR- = AVSS*/
#define SREF_2 2*0x10 /*VR+ = VEREF+; VR- = AVSS*/
#define SREF_3 3*0x10 /*VR+ = VEREF+; VR- = AVSS*/
#define SREF_4 4*0x10 /*VR+ = AVCC; VR- = VREF-*/
#define SREF_5 5*0x10 /*VR+ = VREF+; VR- = VREF-*/
#define SREF_6 6*0x10 /*VR+ = VEREF+; VR- = VREF-*/
#define SREF_7 7*0x10 /*VR+ = VEREF+; VR- = VREF-*/
#define EOS 0x80 /*序列結束選擇位*/
* Interrupt Vectors (offset from 0xFFE0) 16個中斷矢量定義
//#define BASICTIMER_VECTOR 0 * 2 /* 0xFFE0 Basic Timer MSP430F149 沒有*/
#define PORT2_VECTOR 1 * 2 /* 0xFFE2 Port 2 */
#define UART1TX_VECTOR 2 * 2 /* 0xFFE4 UART 1 Transmit */
#define UART1RX_VECTOR 3 * 2 /* 0xFFE6 UART 1 Receive */
#define PORT1_VECTOR 4 * 2 /* 0xFFE8 Port 1 */
#define TIMERA1_VECTOR 5 * 2 /* 0xFFEA Timer A CC1-2, TA */
#define TIMERA0_VECTOR 6 * 2 /* 0xFFEC Timer A CC0 */
#define ADC_VECTOR 7 * 2 /* 0xFFEE ADC */
#define UART0TX_VECTOR 8 * 2 /* 0xFFF0 UART 0 Transmit */
#define UART0RX_VECTOR 9 * 2 /* 0xFFF2 UART 0 Receive */
#define WDT_VECTOR 10 * 2 /* 0xFFF4 Watchdog Timer */
#define COMPARATORA_VECTOR 11 * 2 /* 0xFFF6 Comparator A */
#define TIMERB1_VECTOR 12 * 2 /* 0xFFF8 Timer B 1-6 */
#define TIMERB0_VECTOR 13 * 2 /* 0xFFFA Timer B 0 */
#define NMI_VECTOR 14 * 2 /* 0xFFFC Non-maskable */
#define RESET_VECTOR 15 * 2 /* 0xFFFE Reset [Highest Priority] */
* End of Modules
#endif /* #ifndef __msp430x44x */
430f149頭文件詳解.zip
2016-4-18 23:05 上傳
10.47 KB, 下載次數: 19, 下載積分: 黑幣 -5
aardvark911
2016-6-26 16:08
新手正需要學習
