QrcodeVC二維碼生成VC源代碼
jin510
2016-4-9 21:44
QrcodeVC二維碼生成VC源代碼
QrcodeVC二維碼生成VC源代碼.rar
(1014.98 KB, 下載次數: 79)
2016-4-9 21:43 上傳
部分程序預覽:
// Qrcode.cpp: implementation of the Qrcode class.
#include "stdafx.h"
#include "QrcodeApp.h"
#include "Qrcode.h"
#include <math.h>
#ifdef _DEBUG
#undef THIS_FILE
static char THIS_FILE[]=__FILE__;
#define new DEBUG_NEW
#endif
#define QRCODE_DATA_PATH "qrcode_data"
// Construction/Destruction
Qrcode::Qrcode()
qrcodeErrorCorrect = 'M';
qrcodeEncodeMode = 'B';
qrcodeVersion = 0;
qrcodeStructureappendN = 0;
qrcodeStructureappendM = 0;
qrcodeStructureappendParity = 0;
qrcodeStructureappendOriginaldata = "";
Qrcode::~Qrcode()
void Qrcode::setQrcodeErrorCorrect(char c)
qrcodeErrorCorrect = c;
char Qrcode::getQrcodeErrorCorrect()
return qrcodeErrorCorrect;
int Qrcode::getQrcodeVersion()
return qrcodeVersion;
void Qrcode::setQrcodeVersion(int i)
if(i >= 0 && i <= 40)
qrcodeVersion = i;
void Qrcode::setQrcodeEncodeMode(char c)
qrcodeEncodeMode = c;
char Qrcode::getQrcodeEncodeMode()
return qrcodeEncodeMode;
void Qrcode::setStructureappend(int i, int j, int k)
if(j > 1 && j <= 16 && i > 0 && i <= 16 && k >= 0 && k <= 255)
qrcodeStructureappendM = i;
qrcodeStructureappendN = j;
qrcodeStructureappendParity = k;
//int Qrcode::calStructureappendParity(char abyte0[],int i)
int Qrcode::calStructureappendParity(char* abyte0,int i)
int j = 0;
int k = 0;
//int i = abyte0.length;
if(i > 1)
k = 0;
for(; j < i; j++)
k ^= abyte0[j] & 255;
} else
k = -1;
return k;
//bool** Qrcode::calQrcode(char abyte0[],int iLen0,int& iLenRet)
bool** Qrcode::calQrcode(char* abyte0,int iLen0,int& iLenRet)
int j = 0;
int n1;
int i = iLen0;
//int ai[] = new int[i + 32];
int* ai = new int[i + 32];
//char abyte1[] = new char[i + 32];
char* abyte1 = new char[i + 32];
memset(abyte1,0,i+32);
if(i <= 0)
bool** aflag=new bool*[1];
aflag[0]=new bool[1];
aflag[0][0]=false;
iLenRet=1;
return aflag;
if(qrcodeStructureappendN > 1)
ai[0] = 3;
abyte1[0] = 4;
ai[1] = qrcodeStructureappendM - 1;
abyte1[1] = 4;
ai[2] = qrcodeStructureappendN - 1;
abyte1[2] = 4;
ai[3] = qrcodeStructureappendParity;
abyte1[3] = 8;
j = 4;
abyte1[j] = 4;
//int* ai1=new int[41];
int ai1[41];
int k;
switch(qrcodeEncodeMode)
case 65: // 'A'
/*ai1 = (new int[] {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
2, 2, 2, 2, 2, 2, 2, 2, 2, 2,
2, 2, 2, 2, 2, 2, 2, 4, 4, 4,
4, 4, 4, 4, 4, 4, 4, 4, 4, 4,
4
for(int ii=0;ii<41;ii++)
if(ii<=9)ai1[ii]=0;
else if(ii<=26)ai1[ii]=2;
else ai1[ii]=4;
ai[j] = 2;
j++;
ai[j] = i;
abyte1[j] = 9;
k = j;
j++;
for(int l = 0; l < i; l++)
char c = (char)abyte0[l];
char byte0 = 0;
if(c >= '0' && c < ':')
byte0 = (char)(c - 48);
if(c >= 'A' && c < '[')
byte0 = (char)(c - 55);
} else
if(c == ' ')
byte0 = 36;
if(c == '
byte0 = 37;
if(c == '%')
byte0 = 38;
if(c == '*')
byte0 = 39;
if(c == '+')
byte0 = 40;
if(c == '-')
byte0 = 41;
if(c == '.')
byte0 = 42;
if(c == '/')
byte0 = 43;
if(c == ':')
byte0 = 44;
if(l % 2 == 0)
ai[j] = byte0;
abyte1[j] = 6;
} else
ai[j] = ai[j] * 45 + byte0;
abyte1[j] = 11;
if(l < i - 1)
j++;
j++;
break;
case 78: // 'N'
4
if(ii<=9)ai1[ii]=0;
else ai1[ii]=4;
ai[j] = 1;
j++;
ai[j] = i;
abyte1[j] = 10;
k = j;
j++;
for(int i1 = 0; i1 < i; i1++)
if(i1 % 3 == 0)
ai[j] = abyte0[i1] - 48;
abyte1[j] = 4;
} else
ai[j] = ai[j] * 10 + (abyte0[i1] - 48);
if(i1 % 3 == 1)
abyte1[j] = 7;
} else
abyte1[j] = 10;
if(i1 < i - 1)
j++;
j++;
break;
default:
8, 8, 8, 8, 8, 8, 8, 8, 8, 8,
8
if(ii<=9)ai1[ii]=0;
else ai1[ii]=8;
ai[j] = 4;
j++;
ai[j] = i;
abyte1[j] = 8;
k = j;
j++;
for(int j1 = 0; j1 < i; j1++)
ai[j1 + j] = abyte0[j1] & 255;
abyte1[j1 + j] = 8;
j += i;
break;
int k1 = 0;
for(int l1 = 0; l1 < j; l1++)
k1 += abyte1[l1];
char byte1;
switch(qrcodeErrorCorrect)
case 76: // 'L'
byte1 = 1;
break;
case 81: // 'Q'
byte1 = 3;
break;
case 72: // 'H'
byte1 = 2;
break;
default:
byte1 = 0;
break;
//int ai2[4][41] = {
int ai2[4][41] = {
0, 128, 224, 352, 512, 688, 864, 992, 1232, 1456,
1728, 2032, 2320, 2672, 2920, 3320, 3624, 4056, 4504, 5016,
5352, 5712, 6256, 6880, 7312, 8000, 8496, 9024, 9544, 10136,
10984, 11640, 12328, 13048, 13800, 14496, 15312, 15936, 16816, 17728,
18672
0, 152, 272, 440, 640, 864, 1088, 1248, 1552, 1856,
2192, 2592, 2960, 3424, 3688, 4184, 4712, 5176, 5768, 6360,
6888, 7456, 8048, 8752, 9392, 10208, 10960, 11744, 12248, 13048,
13880, 14744, 15640, 16568, 17528, 18448, 19472, 20528, 21616, 22496,
23648
0, 72, 128, 208, 288, 368, 480, 528, 688, 800,
976, 1120, 1264, 1440, 1576, 1784, 2024, 2264, 2504, 2728,
3080, 3248, 3536, 3712, 4112, 4304, 4768, 5024, 5288, 5608,
5960, 6344, 6760, 7208, 7688, 7888, 8432, 8768, 9136, 9776,
10208
0, 104, 176, 272, 384, 496, 608, 704, 880, 1056,
1232, 1440, 1648, 1952, 2088, 2360, 2600, 2936, 3176, 3560,
3880, 4096, 4544, 4912, 5312, 5744, 6032, 6464, 6968, 7288,
7880, 8264, 8920, 9368, 9848, 10288, 10832, 11408, 12016, 12656,
13328
int i2 = 0;
if(qrcodeVersion == 0)
qrcodeVersion = 1;
for(int j2 = 1; j2 <= 40; j2++)
if(ai2[byte1][j2] >= k1 + ai1[qrcodeVersion])
i2 = ai2[byte1][j2];
break;
qrcodeVersion++;
} else
i2 = ai2[byte1][qrcodeVersion];
k1 += ai1[qrcodeVersion];
abyte1[k] += ai1[qrcodeVersion];
int ai3[] = {
0, 26, 44, 70, 100, 134, 172, 196, 242, 292,
346, 404, 466, 532, 581, 655, 733, 815, 901, 991,
1085, 1156, 1258, 1364, 1474, 1588, 1706, 1828, 1921, 2051,
2185, 2323, 2465, 2611, 2761, 2876, 3034, 3196, 3362, 3532,
3706
int k2 = ai3[qrcodeVersion];
int l2 = 17 + (qrcodeVersion << 2);
int ai4[] = {
0, 0, 7, 7, 7, 7, 7, 0, 0, 0,
0, 0, 0, 0, 3, 3, 3, 3, 3, 3,
3, 4, 4, 4, 4, 4, 4, 4, 3, 3,
3, 3, 3, 3, 3, 0, 0, 0, 0, 0,
0
int i3 = ai4[qrcodeVersion] + (k2 << 3);
char* abyte2 = new char[i3];
char* abyte3 = new char[i3];
char* abyte4 = new char[i3];
char abyte5[15];
char abyte6[15];
char abyte7[1];
char abyte8[128];
memset(abyte2,0,i3);
memset(abyte3,0,i3);
memset(abyte4,0,i3);
memset(abyte5,0,15);
memset(abyte6,0,15);
memset(abyte7,0,1);
memset(abyte8,0,128);
try
//CString s = "qrcode_data/qrv" + Integer.toString(qrcodeVersion) + "_" + Integer.toString(byte1) + ".dat";
CString s;
s.Format("qrcode_data/qrv%d_%d.dat",qrcodeVersion,byte1);
//CFile f(s, CFile::modeCreate | CFile::modeWrite );
CFile f(s, CFile::modeRead);
try
f.Read(abyte2, i3);
f.Read(abyte3, i3);
f.Read(abyte4, i3);
f.Read(abyte5, 15);
f.Read(abyte6, 15);
f.Read(abyte7, 1);
f.Read(abyte8, 128);
f.Close();
catch(...)
f.Close();
//寫臨時文件
/*InputStream inputstream = (com.swetake.util.Qrcode.class).getResourceAsStream(s);
BufferedInputStream bufferedinputstream = new BufferedInputStream(inputstream);
bufferedinputstream.read(abyte2);
bufferedinputstream.read(abyte3);
bufferedinputstream.read(abyte4);
bufferedinputstream.read(abyte5);
bufferedinputstream.read(abyte6);
bufferedinputstream.read(abyte7);
bufferedinputstream.read(abyte8);
bufferedinputstream.close();
inputstream.close();*/
catch(CException exception)
//AfxMessageBox(exception.)
//exception.printStackTrace();
int j3 = 1;
for(char byte2 = 1; byte2 < 128; byte2++)
if(abyte8[byte2] != 0)
continue;
j3 = byte2;
break;
char* abyte9 = new char[j3+1];
memset(abyte9,0,j3);
memcpy(abyte9,abyte8,j3);
abyte9[j3]=0;
//System.arraycopy(abyte8, 0, abyte9, 0, j3);
char abyte10[15] = {
0, 1, 2, 3, 4, 5, 7, 8, 8, 8,
8, 8, 8, 8, 8
char abyte11[15] = {
8, 8, 8, 8, 8, 8, 8, 8, 7, 5,
4, 3, 2, 1, 0
int k3 = i2 >> 3;
int l3 = 4 * qrcodeVersion + 17;
int i4 = l3 * l3;
char* abyte12 = new char[i4 + l3];
memset(abyte12,0,i4 + l3);
try
//CString s1 = "qrcode_data/qrvfr" + Integer.toString(qrcodeVersion) + ".dat";
CString s1;
s1.Format("qrcode_data/qrvfr%d.dat",qrcodeVersion);
//CFile f1(s1, CFile::modeCreate | CFile::modeWrite );
CFile f1(s1, CFile::modeRead);
try
f1.Read(abyte12, i4 + l3);
f1.Close();
catch(...)
f1.Close();
catch(CException exception1)
// exception1.printStackTrace();
if(k1 <= i2 - 4)
ai[j] = 0;
abyte1[j] = 4;
} else
if(k1 < i2)
ai[j] = 0;
abyte1[j] = (char)(i2 - k1);
} else
if(k1 > i2)
TRACE("overflow");
//AfxMessageBox()
// System.out.println("overflow");
int iLret1=0;
char* abyte13 = divideDataBy8Bits(ai, abyte1, k3,i + 32,iLret1);
char* abyte14 = calculateRSECC(abyte13, abyte7[0], abyte9, k3, k2,iLret1,j3);
char** abyte15=new char*[l3];
for( n1 = 0; n1 <l3; n1++)
//abyte15[n1] = new char[l3];
for(int j4 = 0; j4 < l3; j4++)
for(int k4 = 0; k4 < l3; k4++)
abyte15[k4][j4] = 0;
for(int l4 = 0; l4 < k2; l4++)
char byte3 = abyte14[l4];
for(int j5 = 7; j5 >= 0; j5--)
int l5 = l4 * 8 + j5;
//if((abyte2[l5]==0)&&(abyte3[l5]==34)) AfxMessageBox("1");
abyte15[abyte2[l5] & 255][abyte3[l5] & 255] = (char)(255 * (byte3 & 1) ^ abyte4[l5]);
//byte3 = (char)((byte3 & 255) >>> 1);
byte3 = (char)((byte3 & 255) >> 1);
//byte3 = (char)((unsigned char)((byte3 & 255) >> 1));
/*for( j4 = 0; j4 < l3; j4++)
TestMsg(abyte15[j4],l3);
for(int i5 = ai4[qrcodeVersion]; i5 > 0; i5--)
int k5 = (i5 + k2 * 8) - 1;
abyte15[abyte2[k5] & 255][abyte3[k5] & 255] = (char)(255 ^ abyte4[k5]);
char byte4 = selectMask((char**)abyte15, ai4[qrcodeVersion] + k2 * 8,l3);
char byte5 = (char)(1 << byte4);
char byte6 = (char)(byte1 << 3 | byte4);
CString as[32] = {
"101010000010010", "101000100100101", "101111001111100", "101101101001011", "100010111111001", "100000011001110", "100111110010111", "100101010100000", "111011111000100", "111001011110011",
"111110110101010", "111100010011101", "110011000101111", "110001100011000", "110110001000001", "110100101110110", "001011010001001", "001001110111110", "001110011100111", "001100111010000",
"000011101100010", "000001001010101", "000110100001100", "000100000111011", "011010101011111", "011000001101000", "011111100110001", "011101000000110", "010010010110100", "010000110000011",
"010111011011010", "010101111101101"
for(int i6 = 0; i6 < 15; i6++)
char byte7=as[byte6][i6]-48;
abyte15[abyte10[i6] & 255][abyte11[i6] & 255] = (char)(byte7 * 255);
abyte15[abyte5[i6] & 255][abyte6[i6] & 255] = (char)(byte7 * 255);
//boolean [][]aflag1 = new boolean[l3][l3];
bool** aflag1 = new bool*[l3]; //\\\\\\\\\\\
aflag1[n1] = new bool[l3];
int j6 = 0;
for(int k6 = 0; k6 < l3; k6++)
for(int l6 = 0; l6 < l3; l6++)
if((abyte15[l6][k6] & byte5) != 0 || abyte12[j6] == 49)
aflag1[l6][k6] = true;
aflag1[l6][k6] = false;
j6++;
j6++;
//delete[] aflag1;
iLenRet=l3;
/* 刪除new 變量 */
delete []ai;
delete []abyte1;
delete []abyte2;
delete []abyte3;
delete []abyte4;
delete []abyte9;
delete []abyte12;
delete []abyte13;
delete []abyte14;
delete []abyte15[n1];
delete[] abyte15;
return aflag1;
//char* Qrcode::divideDataBy8Bits(int ai[], char abyte0[],
char* Qrcode::divideDataBy8Bits(int* ai, char* abyte0,
int i,int iLen,int& iLRet)//int i,int j)
//int iLen = abyte0.length; iLenAi=ai..length
int j=iLen;
int l = 0;
int i1 = 8;
int j1 = 0;
//if(j == ai.length);
for(int i2 = 0; i2 < j; i2++)
j1 += abyte0[i2];
int k = (j1 - 1) / 8 + 1;
char* abyte1 = new char[i];
memset(abyte1,0,i);
for(int j2 = 0; j2 < k; j2++)
abyte1[j2] = 0;
for(int k2 = 0; k2 < j; k2++)
int k1 = ai[k2];
int l1 = abyte0[k2];
bool flag = true;
if(l1 == 0)
break;
while(flag)
if(i1 > l1)
abyte1[l] = (char)(abyte1[l] << l1 | k1);
i1 -= l1;
flag = false;
} else
l1 -= i1;
abyte1[l] = (char)(abyte1[l] << i1 | k1 >> l1);
if(l1 == 0)
flag = false;
} else
k1 &= (1 << l1) - 1;
flag = true;
l++;
i1 = 8;
if(i1 != 8)
abyte1[l] = (char)(abyte1[l] << i1);
l--;
if(l < i - 1)
for(bool flag1 = true; l < i - 1; flag1 = !flag1)
l++;
if(flag1)
abyte1[l] = -20;
abyte1[l] = 17;
iLRet=i;
return abyte1;
//private
//char* Qrcode::calculateRSECC(char abyte0[], char byte0, char abyte1[], int i, int j,
char* Qrcode::calculateRSECC(char* abyte0, char byte0, char* abyte1, int i, int j,
int iLen0,int iLen1)
//iLen1 abyte1.length ; iLen0 abyte0.length
char** abyte2 = new char*[256];
//char abyte2[][] = new char[256][byte0];
int n1;
for(n1=0;n1<256;n1++){
abyte2[n1]=new char[byte0];
memset(abyte2[n1],0,byte0);
try
CString s;
s.Format("qrcode_data/rsc%d.dat" ,byte0);
CFile f1(s, CFile::modeRead);
try
//for(int i2 = 0; i2 < 256; i2++) bufferedinputstream.read(abyte2[i2]);
f1.Read(abyte2[i2], byte0);
f1.Close();
catch(...)
f1.Close();
bool flag = false;
int i1 = 0;
int k1 = 0;
char** abyte3 = new char*[iLen1];
char* abyte4 = new char[j];
memset(abyte4,0,j);
memcpy(abyte4, abyte0, iLen0);
int ab3Length=0;
for(int k = 0; k < iLen1; k++){
ab3Length= (abyte1[k] & 255) - byte0;
abyte3[k] = new char[(abyte1[k] & 255) - byte0];
memset(abyte3[k],0,(abyte1[k] & 255) - byte0);
abyte3[k1][i1] = abyte0[l];
if(++i1 >= (abyte1[k1] & 255) - byte0)
i1 = 0;
k1++;
/* for(int kkk=0;kkk<ab3Length;kkk++)
FILE *fp=NULL;
fp=fopen("C:\\test.txt","at+");
fprintf(fp,"%d: %d\r\n",kkk,abyte3[3][kkk]);
fclose(fp);
//for(int l1 = 0; l1 < abyte1.length; l1++)
for(int l1 = 0; l1 < iLen1; l1++)
//char abyte5[] = (char[])abyte3[l1].clone();
int iLen5=(abyte1[l1] & 255) - byte0;
char* abyte5=new char[iLen5];
memset(abyte5,0,iLen5);
for (n1=0;n1<iLen5;n1++)
abyte5[n1]=abyte3[l1][n1];
//char* abyte5 = abyte3[l1];
int j2 = abyte1[l1] & 255;
int k2 = j2 - byte0;
for(int j1 = k2; j1 > 0; j1--)
char byte1 = abyte5[0];
if(byte1 != 0)
//char abyte6[] = new char[abyte5.length - 1];
char* abyte6 = new char[iLen5];
memcpy(abyte6,abyte5+1,iLen5-1);
abyte6[iLen5-1]=0;
//System.arraycopy(abyte5, 1, abyte6, 0, iLen5 - 1);
//char abyte9[] = abyte2[byte1 & 255];
char* abyte9 = abyte2[byte1 & 255];
int iLret1;
abyte5 = calculateByteArrayBits(abyte6, abyte9, "xor",iLen5-1,byte0,iLret1);
//abyte5[iLen5-1]=0;
delete [] abyte6;
} else
if(byte0 < iLen5)
//char abyte7[] = new char[abyte5.length - 1];
char* abyte7 = new char[iLen5 - 1];
memcpy(abyte7,abyte5+1,iLen5-1);
for(n1=0;n1<iLen5-1;n1++)
abyte5[n1]=abyte7[n1];
//abyte5 = abyte7;
delete []abyte7;
} else
//char abyte8[] = new char[byte0];
char* abyte8 = new char[byte0];
memcpy(abyte8,abyte5+1,iLen5-1);
// abyte8[byte0 - 1] = 0;
for(n1=0;n1<byte0;n1++)
abyte5[n1]=abyte8[n1];
//abyte5 = abyte8;
delete []abyte8;
memcpy(abyte4+iLen0+l1*byte0,abyte5,byte0);
delete []abyte5;
delete []abyte2[n1];
delete []abyte2;
for(n1=0;n1<iLen1;n1++){
delete []abyte3[n1];
delete []abyte3;
return abyte4;
//private
char* Qrcode::calculateByteArrayBits(char* abyte0, char* abyte1, CString s,
int iLen0,int iLen1,int& iLRet)
char* abyte3;//
char* abyte4;
int i,j,n1;
if(iLen0 > iLen1)
i=iLen0;
j=iLen1;
abyte3=new char[i+1];
abyte4=new char[j+1];
memset(abyte3,0,i+1);
for (n1=0;n1<i;n1++){
abyte3[n1]=abyte0[n1];
memset(abyte4,0,j+1);
for (n1=0;n1<j;n1++)
abyte4[n1]=abyte1[n1];
} else
i=iLen1;
j=iLen0;
abyte3[n1]=abyte1[n1];
abyte4[n1]=abyte0[n1];
char* abyte2 = new char[i+1];
memset(abyte2,0,i+1);
for(int k = 0; k < i; k++){
if(k < j)
if(s == "xor")
abyte2[k] = (char)(abyte3[k] ^ abyte4[k]);
abyte2[k] = (char)(abyte3[k] | abyte4[k]);
} else
abyte2[k] = abyte3[k];
delete []abyte3;
delete []abyte4;
return abyte2;
void Qrcode::TestMsg(char* myStr,int length)
//int kkk = strlen(myStr);
for(int iii=0;iii<length;iii++)
FILE *fp=NULL;
fprintf(fp,"%d: %d\r\n",iii,myStr[iii]);
fclose(fp);
char Qrcode::selectMask(char** abyte0, int i,int iLen0)
//iLen0 abyte0.GetLength();
//int j = abyte0.GetLength();
int j = iLen0;
int ai[] = {
int ai1[] = {
int ai2[] = {
int ai3[] = {
int k = 0;
int l = 0;
int ai4[] = {
for(int i1 = 0; i1 < j; i1++)
int ai5[] = {
int ai6[] = {
bool aflag[] = {
false, false, false, false, false, false, false, false
bool aflag1[] = {
if(l1 > 0 && i1 > 0)
k = abyte0[l1][i1] & abyte0[l1 - 1][i1] & abyte0[l1][i1 - 1] & abyte0[l1 - 1][i1 - 1] & 255;
l = abyte0[l1][i1] & 255 | abyte0[l1 - 1][i1] & 255 | abyte0[l1][i1 - 1] & 255 | abyte0[l1 - 1][i1 - 1] & 255;
for(int j2 = 0; j2 < 8; j2++)
// ai5[j2] = (ai5[j2] & 63) << 1 | (abyte0[l1][i1] & 255) >>> j2 & 1;
// ai6[j2] = (ai6[j2] & 63) << 1 | (abyte0[i1][l1] & 255) >>> j2 & 1;//高位自動補零
int n=abyte0[l1][i1] & 255;
int x=j2;
ai5[j2] = (ai5[j2] & 63) << 1 |(n>>x)&((int)pow(2,32-x)-1) & 1;
ai6[j2] = (ai6[j2] & 63) << 1 |(n>>x)&((int)pow(2,32-x)-1) & 1;
//ai5[j2] = (ai5[j2] & 63) << 1 |((abyte0[l1][i1] & 255))>> j2 & 1;
//ai6[j2] = (ai6[j2] & 63) << 1 |((abyte0[i1][l1] & 255))>> j2 & 1;
// ai5[j2] = (ai5[j2] & 63) << 1 | (abyte0[l1][i1] & 255) >> j2 & 1;
// ai6[j2] = (ai6[j2] & 63) << 1 | (abyte0[i1][l1] & 255) >> j2 & 1;//高位自動補零
if((abyte0[l1][i1] & 1 << j2) != 0)
ai4[j2]++;
if(ai5[j2] == 93)
ai2[j2] += 40;
if(ai6[j2] == 93)
ai2[j2] += 40;
if((k & 1) != 0 || (l & 1) == 0)
ai1[j2] += 3;
k >>= 1;
l >>= 1;
if((ai5[j2] & 31) == 0 || (ai5[j2] & 31) == 31)
if(l1 > 3)
if(aflag[j2])
ai[j2]++;
} else
ai[j2] += 3;
aflag[j2] = true;
} else
aflag[j2] = false;
if((ai6[j2] & 31) == 0 || (ai6[j2] & 31) == 31)
if(l1 > 3)
if(aflag1[j2])
ai[j2]++;
} else
ai[j2] += 3;
aflag1[j2] = true;
} else
aflag1[j2] = false;
int j1 = 0;
char byte0 = 0;
int ai7[] = {
90, 80, 70, 60, 50, 40, 30, 20, 10, 0,
0, 10, 20, 30, 40, 50, 60, 70, 80, 90,
90
for(int k1 = 0; k1 < 8; k1++)
ai3[k1] = ai7[(20 * ai4[k1]) / i];
int i2 = ai[k1] + ai1[k1] + ai2[k1] + ai3[k1];
if(i2 < j1 || k1 == 0)
byte0 = (char)k1;
j1 = i2;
return byte0;
cauzx
2016-10-30 22:49
正在學習二維碼,正是我需要的
huac82
2017-3-15 19:58
VC的二維碼真心是少,希望這個對我有參考價值
nmlnj
2017-3-25 16:31
最近在處理QR碼打印的工作。沒有思路了。。。
z17173
2017-3-26 13:19
初學者的好資料,51黑有你更精彩
chtctc
2017-8-16 10:02
chtctc
2017-8-16 10:13
初來乍到,看看這個能不能用
xiongbo
2017-11-6 12:39
謝謝分享,剛剛開始要做一個二維碼的程序
羽Love墨
2017-11-19 16:17
點擊生成是會提示如下錯誤,暫時尚未找到原因。
(20.61 KB, 下載次數: 54)
運行錯誤
2017-11-19 16:16 上傳
reg1998
2018-6-8 20:24
能不能用啊
jwp2008
2019-12-19 15:18
正在找這個資料,希望有幫助
frank_tw
2021-11-7 14:48
Very Good Thanks!
