標(biāo)題: apt 更新錯(cuò)誤。 [打印本頁(yè)]
作者: 51黑tt    時(shí)間: 2016-3-6 16:01
There are many problem due to which this issue has come. Some of then are :
So for both of them there are different solution, if you didn't know the exact problem then follow following steps:
