標(biāo)題: NuMicro M0516-PC通訊協(xié)議 [打印本頁]
作者: 51黑黑黑    時(shí)間: 2016-2-21 18:55
main.c
/*                Copyright (c) 2016, 老馬工作室                            */
/*                     All rights reserved.                                 */
/*      Email:pcwebmaster@163.com                                           */
/* 文 件 名:comint.c                                                       */
/* 版    本:Version 1.0                                                    */
/* 描    述:串行口中斷帶通訊協(xié)議測試                                       */
/* 主控芯片:NuMicro M0516*/
/* 晶振頻率:11.0592MHz          */
/* 作    者:pcwebmaster(北極狼)                                            */
/* 函    數(shù):                                                               */
/*         system_init                                                     */
/*         com_send_command                                                */
/*         com_command_receive*/
/*CalCRC16_1021*/
/*command_decoder*/
/*send_command*/
/* 測    試: 發(fā)送:16 16 02 01 02 01 00 35 03 94 BD接收:49 AA 15 */
/* 測試現(xiàn)象:  */
/* 歷史記錄:20016.02.18測試通過                                            */
/* 北極狼          20016-02-18     Creat Inital version. (Version 1.0)      */
#include <stdio.h>
#include "M051Series.h"
#include "comint.h"
#define PLL_CLOCK           50000000
/* Global variables        */
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
//    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));CLK_CLKSEL1_UART_S_HIRC
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HIRC, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
//UART_Open(UART0, 9600);
    /* Enable Interrupt and install the call back function */
    UART_ENABLE_INT(UART0, (UART_IER_RDA_IEN_Msk));// | UART_IER_THRE_IEN_Msk | UART_IER_RTO_IEN_Msk));
    NVIC_EnableIRQ(UART0_IRQn);
//    while(g_bWait);
void Uart0Send(int32_t Bytes)
UART0->THR = Bytes;
while ((UART0->FSR&TX_EMPTY) != 0x00); //檢查發(fā)送FIFO是否為空
/* MAIN function        */
int main(void)
//int8_t  i,j;
    SYS_UnlockReg();/* Unlock protected registers */
    SYS_Init();/* Init System, IP clock and multi-function I/O */
    SYS_LockReg();/* Lock protected registers */
    UART0_Init();/* Init UART0 for printf and testing */
buff_init();
    /* SAMPLE CODE        */
    printf("\n\nCPU @ %dHz\n", SystemCoreClock);
printf("\r\n 世界,你好!\r\n");
printf("\r\n USART0測試正常! \r\n");
com_command_receive();
COMINT.C
/* 函    數(shù):                                                               */
/*         system_init                                                     */
/*CalCRC16_1021*/
/*command_decoder*/
/*send_command*/
/* 測試現(xiàn)象:  */
#include "comint.h"
uint8_t  pint_buf[MAX_RINTL];   /* 串口接收緩沖區(qū)       */
uint8_t  pint_read;             /* 串口緩沖區(qū)讀指針     */
uint8_t  pint_write;            /* 串口緩沖區(qū)寫指針     */
uint8_t  psend_int;             /* 串口發(fā)送允許標(biāo)志     */
uint8_t  serial_flag = 0;       /* 串口接收數(shù)據(jù)標(biāo)志位   */
uint8_t  prec_buf[MAX_COMMAND_LEN];/* 命令接收緩沖區(qū)    */
uint8_t  prec_num;                    /* 命令接收緩沖區(qū)字節(jié)數(shù) */
uint8_t serial_lengthl = 0;           /* 消息命令長度低8位    */
uint16_t  serial_length = 0;          /* 消息命令長度16位     */
uint8_t ADDRESS[2]={ZU,ZHAN};       /* byte0:通訊組地址, byte1:開發(fā)板地址 */
/* 串口發(fā)送一個(gè)字節(jié) */
void com_send_command(uint16_t Data)
UART0->THR = Data;
/* 串口接收數(shù)據(jù)處理 */
void com_command_receive(void)
    uint8_t var1,var4;
    uint16_t crc_data = 0;
    var4 = pint_read;
    if (var4 != pint_write)
        var1 = pint_buf[var4];
        var4 = var4+1;
        if (var4 >= MAX_RINTL)
            var4=0;
        pint_read = var4;
        switch(serial_flag)
            case 0: /*收到起始位*/
                if (var1 == SYN)
                    serial_flag = 1;
//com_send_command(0x01); //測試
                    serial_flag = 0;
                break;
            case 1:/*收到起始位*/
                if (var1 == SYN)
                    serial_flag = 2;
//com_send_command(0x02); //測試
                    serial_flag = 0;
                break;
            case 2:/*收到同步位*/
                if (var1 == STX)
                    serial_flag = 3;
//com_send_command(0x03);//測試
                    serial_flag = 0;
                break;
            case 3: /*收到組地址*/
                if (var1 == ADDRESS[0])
                    serial_flag = 4;
                    prec_num = 1;
                    prec_buf[0] = var1;
//com_send_command(0x04); //測試
                    serial_flag = 0;
                break;
            case 4:/*收到本機(jī)地址或者廣播地址*/
                if ( (var1 == ADDRESS[1]) || (var1 == 0) )
                    prec_num = 2;
                    prec_buf[1] = var1;
                    serial_flag = 5;
//com_send_command(0x05); //測試
                    serial_flag = 0;
                break;
            case 5:/*數(shù)據(jù)長度*/
                prec_num = 3;
                prec_buf[2] = var1;
                serial_lengthl = var1;
                serial_flag = 6;
//com_send_command(0x06);//測試
                break;
            case 6:
                prec_num = 4;
                prec_buf[3] = var1;
                serial_length |= var1;
                serial_length = ( (serial_length << 8) & 0xff00 ) + serial_lengthl + 3;
                serial_flag = 7;
//com_send_command(0x07);//測試
                break;
            case 7:
                prec_buf[prec_num] = var1;
                prec_num++;
                serial_length--;
                if (serial_length == 0)
                    crc_data = CalCRC16_1021(prec_buf, prec_num - 2); /* 計(jì)算crc校驗(yàn)和(從組地址開始到ETX )*/
                    if ( ( (crc_data & 0x00ff) == prec_buf[prec_num - 2]) && ( ( (crc_data >>8) & 0x00ff) == prec_buf[prec_num - 1]) ) /* 校驗(yàn)和正確 */
                        prec_num = 1;
                        var1 = 0;
                        if ( (prec_buf[4] >= 0x31) && (prec_buf[4] <= 0x3b) ) /* 命令有效 */
                            if (prec_buf[1] != 0x00) /* 如果不是廣播地址則回應(yīng)ACK*/
com_send_command(0x49);//測試                                 msg_last_push(MSG_ACK,0);
//send_command(ACK); //測試
                            command_decoder(); /* 如果校驗(yàn)和正確,則進(jìn)行命令解碼 */
send_command(NAK); //測試
                    serial_flag = 0;
                    prec_num = 1;
                break;
            default:
                serial_flag = 0;
                prec_num = 1;
                break;
/* 命令解碼子程序 */
void command_decoder(void)
//    uint8_t i = 0;
    if (prec_buf[4] == 0x31)       /* 設(shè)置報(bào)警閾值   */
com_send_command(0x11);//測試
        return;
    else if (prec_buf[4] == 0x32)  /* 請求報(bào)警閾值 */
com_send_command(0x12);//測試?
        return;
    else if (prec_buf[4] == 0x33)  /* 修改當(dāng)前時(shí)間 */
com_send_command(0x13);//測試
        return;
    else if (prec_buf[4] == 0x34)  /* 請求當(dāng)前時(shí)間 */
com_send_command(0x14);//測試
        return;
    else if (prec_buf[4] == 0x35)  /* 請求當(dāng)前數(shù)據(jù) */
com_send_command(0xAA);//測試
//__nop();
com_send_command(0x15);//測試
        return;
    else if (prec_buf[4] == 0x36)  /* 請求看門狗信息*/
com_send_command(0x16);//測試
        return;
    else if (prec_buf[4] == 0x37)  /* 請求報(bào)警情況 */
com_send_command(0x17);//測試
        return;
    else if (prec_buf[4] == 0x38)  /* 配置設(shè)備地址 */
        ADDRESS[0] = prec_buf[5];  /* 通訊組地址   */
        ADDRESS[1] = prec_buf[6];  /* 開發(fā)板地址   */
com_send_command(0x181);//測試
        return;
    else if (prec_buf[4] == 0x39)  /* 請求設(shè)備地址 */
com_send_command(0x19);//測試
        return;
    else if (prec_buf[4] == 0x3a)  /* 控制模擬量輸出 */
com_send_command(0x1A);//測試?
        return;
    else if (prec_buf[4] == 0x3b)  /* 控制開關(guān)量輸出 */
com_send_command(0x1B);//測試
        return;
//if (prec_buf[4] == 0x00)       /* 如果是廣播地址  */
//com_send_command(SYN);
//com_send_command(0x00);
//        return;
/* 向PC主機(jī)發(fā)送消息幀,入口參數(shù):消息類型 */
void send_command(uint8_t command)
    switch (command)
        case ACK:
            com_send_command(ACK);
            break;
        case NAK:
            com_send_command(NAK);
            break;
        default:
            break;
void buff_init(void)
    uint8_t loop;
    loop = UART0->RBR;   /* 清串口緩沖區(qū)   */
    for (loop=0; loop<MAX_RINTL; loop++)
        pint_buf[loop] = 0;
/*計(jì)算CRC校驗(yàn)和使用MTT(0X1021)
參數(shù):
pBuff 為需計(jì)算CRC的緩沖區(qū)的頭指針
BufferLen 緩沖區(qū)長度(以字節(jié)計(jì))
u_short CalCRC16_1021(uint8_t x[], u_short BufferLen)
    u_short i;
    uint8_t  j;
    u_short crc16 = 0;
    u_short mask = 0x1021;
    uint8_t *pByteBuffer;
    uint8_t tmpbyte;
    u_short calval;
    pByteBuffer = &x[0];
    for (i = 0; i < BufferLen; i++)
        tmpbyte = *pByteBuffer;
        calval = tmpbyte << 8;
        for (j = 0; j < 8; j++)
            if ((crc16 ^ calval) & 0x8000)
                crc16 = (crc16 << 1) ^ mask;
                crc16 <<= 1;
            calval <<= 1;
        pByteBuffer++;
    return crc16;
/* ISR to handle UART Channel 0 interrupt event                                                            */
void UART0_IRQHandler(void)
    uint8_t temp;
    uint8_t temp1;
if(UART0->ISR & RDA_INT) //檢查是否接收數(shù)據(jù)中斷
while(UART0->ISR & RDA_IF)  //獲取所有接收到的數(shù)據(jù)
while (UART0->FSR & RX_EMPTY); //檢查接收FIFO是否為空
temp1 = UART0->RBR; //讀取數(shù)據(jù)
temp  = pint_write + 1; /* 判斷是否可以寫入 */
if (temp == MAX_RINTL)
temp=0;
if (temp != pint_read)
pint_buf[pint_write] = temp1; /* 讀取數(shù)據(jù) */
pint_write = temp;
COMINT.h
#ifndef __COMINT_H__
#define __COMINT_H__
#include <stdio.h>
#define RXBUFSIZE 8//1024
#define TX_EMPTY(1<<22)
#define RX_EMPTY(1<<14)
#define RDA_INT(1<<8)
#define RDA_IF(1<<0)
typedefunsigned shortu_short;
#define ZU0x01 /*組地址*///通訊地址修改這兩項(xiàng)
#define ZHAN0x02 /*站地址*///通訊地址修改這兩項(xiàng)
#define MAX_RINTL       16   /* 串口接收緩沖區(qū)長度   */
#define SYN           0x16   /* 通訊同步位*/
#define STX           0x02   /* 通訊起始位*/
#define ETX           0x03   /* 通訊結(jié)束位*/
#define ACK           0x06
#define NAK           0x15
#define MSG_ACK          2    /* 正確應(yīng)答信息         */
#define MSG_NAK          3    /* 錯(cuò)誤應(yīng)答信息         */
#define MAX_COMMAND_LEN  16   /* 串口接受命令長度     */
extern char str_test[25]  ;
extern uint8_t  pint_read;             // 串口緩沖區(qū)讀指針     */
extern uint8_t  pint_write;            // 串口緩沖區(qū)寫指針
//extern uint8_t  data  psend_int;             // 串口發(fā)送允許標(biāo)志
extern uint8_t  pint_buf[MAX_RINTL];   // 串口接收緩沖區(qū)
extern uint8_t serial_flag;              /* 串口接收數(shù)據(jù)標(biāo)志位   */
extern uint8_t  prec_buf[MAX_COMMAND_LEN];/* 命令接收緩沖區(qū) */
extern void com_send_command(uint16_t Data);
extern void com_command_receive(void);
/* 串口接收初始化 */
extern void buff_init(void);
///* 串口接收一字節(jié)數(shù)據(jù) */
//unsigned char UartReadChar(void); //reentrant
參數(shù):
u_short CalCRC16_1021(uint8_t x[], u_short BufferLen);
/* 命令解碼子程序 */
void command_decoder(void);
/* 向主機(jī)發(fā)送消息幀,入口參數(shù):消息類型 */
void send_command(uint8_t command);
#endif
作者: luochen6688    時(shí)間: 2018-4-14 08:38
你好,我也是用11.0592M晶振,可是串口波特率一直不對,已經(jīng)改了
#define __HXT       (11059200UL)    /*!< External Crystal Clock Frequency     */
還有其他的需要修改的地方嗎?
