標題: startActivityForResult [打印本頁]
作者: 51黑fan    時間: 2016-1-31 02:37
tartActivityForResult :
由Activity1啟動Activity2->執行Activity2->在Activity2中調用setResult和finish方法數據將返回Activity1并觸發onActivityResult函數;
實例:
step1:在Activity1中定義全局標志量
        private static final int REQUEST_CONNECT_DEVICE = 1;
step2:在Activity1中的按鈕事件觸發startActivityForResult
        Intent serverIntent = new Intent(Activity1.this,Activity.class);
        startActivityForResult(serverIntent,REQUEST_CONNECT_DEVICE);
step3:在 Activity2中定義變量名字用于數據回傳到Activity1
        public static String EXTRA_DEVICE_ADDRESS = "device_address";
step4:在Activity2中觸發setResut函數并調用finish方法傳回數據
        Intent intent = new Intent();
        intent.putExtra(EXTRA_DEVICE_ADDRESS, address);
        // Set result and finish this Activity
        setResult(Activity.RESULT_OK, intent);//其中Activity.RESULT_OK是一個標志,用于咋下一步在Activity1的接收中區分是那個setResult發送的數據
        Toast.makeText(SearchDevice.this,info , 1).show();
        finish();//調用finfish方法返回AActivity
step5:完成step4之后會自動進入Activity1中的nActivityResult函數:
        public void onActivityResult(int requestCode, int resultCode, Intent data) {
                       switch (requestCode) {
                                        case REQUEST_CONNECT_DEVICE:
                                                    // When DeviceListActivity returns with a device to connect
                                           if (resultCode == Activity.RESULT_OK) {
                                                // Get the device MAC address
                                                      address = data.getExtras().getString(Activity2.EXTRA_DEVICE_ADDRESS);
