˜Ëî}:
Çólm324ºÍl298³¬Â•²¨¼tÍâ±ÜÕÏÖÇÄÜ܇³ÌÐò
[´òÓ¡±¾í“]
×÷Õß:
45555mkkl
•rég:
2016-1-14 09:06
˜Ëî}:
ÓЛ]ÓÐÓÃlm324ºÍl298³¬Â•²¨¼tÍâ±ÜÕÏÖÇÄÜ܇³ÌÐò£¿£¿£¿£¿£¡£¡£¡
×÷Õß:
init
•rég:
2016-1-14 10:43
Ë{Èç.........
×÷Õß:
45555mkkl
•rég:
2016-1-14 10:45
init °l±íÓÚ 2016-1-14 10:43
Ë{Èç.........
ÕÒÏ÷......
×÷Õß:
init
•rég:
2016-1-14 10:46
Äãß@ô6ѽ........
×÷Õß:
@@22##33
•rég:
2016-1-14 18:26
ß@ôÁï°¡¡¢¡¢¡¢
×÷Õß:
rhptt928
•rég:
2019-11-13 17:24
ÎÒÒ²ÏëÒªl298nƒÉ‚€Ý†×ÓÒ»‚€ÈfÏò݆£¬ÓõÄ51ºÍ¼tÍ⣬˜ÇÖ÷·½±ã·ÖÏí†á
×÷Õß:
È~´º°¡
•rég:
2020-12-25 19:26
#include<reg52.h>
sbit IN1=P0^1;
sbit IN2=P0^2;
sbit IN3=P0^3;
sbit IN4=P0^4;
sbit ENB=P0^0;
sbit ENA=P0^5;
sbit hw1=P1^0;
sbit hw2=P1^1;
sbit hw3=P1^2;
//sbit hw4=P1^3;
uchar PWM1=0 ; //**ÓÒ߅늙CµÄÕ¼¿Õ±È**//
uchar PWM2=0 ; //**×ó߅늙CµÄÕ¼¿Õ±È**//
//uchar num=0; //**¶¨•rÆ÷ÖДàÓ‹”µÆ÷**//
uchar flag;
void init()
TMOD=0x01;
TH0=(65536-50)/256;
TL0=(65536-50)%256;
EA=1;
ET0=1;
TR0=1;
IN1=0;
IN2=0;
IN3=0;
IN4=0;
init();
if(hw1||hw2||hw3)//Èç¹û™zœyµ½ÐÅÌ–
ENA=1; // üS1223
ENB=1; // üS1223
/* if(hw1&&hw2&&hw3/*&&hw4*///) */
ENA=1;
ENB=1;
if(hw1&&hw2&&!hw3) //
IN1=1;
IN2=1;
IN3=1;
IN4=0;
PWM1=0;
PWM2=10;
flag=1;
if(hw1&&!hw2&&hw3/*&&!hw4*/)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=10;
PWM2=5;
flag=2;
if(!hw1&&hw2&&hw3/*&&!hw4*/)
IN1=1;
IN2=0;
IN3=1;
IN4=1;
PWM1=5;
PWM2=0;
flag=3;
if(!hw1&&!hw2&&!hw3/*&&hw4*/)
IN1=1;
IN2=1;
IN3=1;
IN4=1;
PWM1=10;
PWM2=0;
flag=4;
else //Èç¹û™zœy²»µ½ÐÅÌ–
IN1=1;
IN2=1;
IN3=1;
IN4=1; //üS1221¼Ó
} break;
/*switch(flag)
case 1:
// IN1=1;
// IN2=0;
// IN3=1;
// IN4=0;
// PWM1=10;
// PWM2=5;
IN1=0;
IN2=1;
IN3=1;
IN4=0;
PWM1=12;
PWM2=12;
//flag=0;
} break;
case 2:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=8;
PWM2=8;
flag=0;
} break;
case 3:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=8;
PWM2=8;
flag=0;
} break;
case 4:
IN1=1;
IN2=0;
IN3=0;
IN4=1;
PWM1=12;
PWM2=12;
// flag=0;
} break;
default:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=12;
PWM2=12;
/*void timer0() interrupt 1
TH0=(65536-50)/256;
TL0=(65536-50)%256;
num++;
if(num>=40)num=0;
if(num<PWM1)ENA=1;
else ENA=0;
if(num<PWM2)ENB=1;
else ENB=0;
šgÓ¹âÅR (http://m.raoushi.com/bbs/)
