標題: 簡單的單片機矩陣鍵盤程序 [打印本頁]
作者: 983684119    時間: 2016-1-8 21:04
標題: 簡單的單片機矩陣鍵盤程序
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
sbit KEY1 = P2^4;
sbit KEY2 = P2^5;
sbit KEY3 = P2^6;
sbit KEY4 = P2^7;
unsigned char code LedChar[] = {  //數碼管顯示字符轉換表
    0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07,
    0x7f, 0x6f, 0x77, 0x7c, 0x39, 0x5e, 0x79, 0x71
void delay();
    bit keybuf = 1;  //按鍵值暫存,臨時保存按鍵的掃描值
    bit backup = 1;  //按鍵值備份,保存前一次的掃描值
    unsigned char cnt = 0;  //按鍵計數,記錄按鍵按下的次數
    ADDR3 = 1;
    ADDR2 = 0;
    ADDR1 = 0;
    ADDR0 = 0;
    P2 = 0xf7;   //P2.3置0,即KeyOut1輸出低電平
    P0 = LedChar[cnt];   //顯示按鍵次數初值
        while (1)
        keybuf = KEY4;            //把當前掃描值暫存
        if (keybuf != backup)     //當前值與前次值不相等說明此時按鍵有動作
           delay();              //延時大約10ms
            if (keybuf == KEY4)   //判斷掃描值有沒有發生改變,即按鍵抖動
                if (backup == 0)  //如果前次值為0,則說明當前是彈起動作
                    cnt++;        //按鍵次數+1
                    if (cnt >= 10)
                    {             //只用1個數碼管顯示,所以加到10就清零重新開始
                        cnt = 0;
                    P0 = LedChar[cnt];  //計數值顯示到數碼管上
                backup = keybuf;  //更新備份為當前值,以備進行下次比較
/* 軟件延時函數,延時約10ms */
void delay()
    unsigned int i = 1000;
    while (i--);
