stm32產生spwm波的pwm寄存器配置與教程工具等
hushao
2016-1-4 18:08
有很多種方案可以選擇,我現在你解決的方案是用定時器和DMA來做的,還可以有其他很多方法我還沒有去試,如果有其他方法成功了的期待分享,不多說了,直接上程序:
#include "stm32f10x.h"
#define TIM1_CCR3_Address 0x40012C3C
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
uint16_t SRC_Buffer[3] = {500, 500, 500};
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void DMA_Configuration(void);
int main(void)
RCC_Configuration();
GPIO_Configuration();
DMA_Configuration();
/* TIM1 Peripheral Configuration --------------------------------------------*/
/* Time Base configuration */
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_Period = 1000-1;//72M/x=frq
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 2;
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
/* Channel 3 Configuration in PWM mode */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = 127;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OC3Init(TIM1, &TIM_OCInitStructure);
/* TIM1 Update DMA Request enable */
TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
/* TIM1 counter enable */
TIM_Cmd(TIM1, ENABLE);
/* Main Output Enable */
TIM_CtrlPWMOutputs(TIM1, ENABLE);
while (1)
SystemInit();
/* TIM1, GPIOA and GPIOB clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA |
RCC_APB2Periph_GPIOB, ENABLE);
/* DMA clock enable */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
/* GPIOA Configuration: Channel 3 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* GPIOB Configuration: Channel 3N as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
DMA_InitTypeDef DMA_InitStructure;
/* DMA1 Channel5 Config */
DMA_DeInit(DMA1_Channel5);
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM1_CCR3_Address;
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SRC_Buffer;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = 3;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel5, &DMA_InitStructure);
/* DMA1 Channel5 enable */
DMA_Cmd(DMA1_Channel5, ENABLE);
上面的數組SRC_Buffer[3] = {100, 200, 500};
是作為SPWM波的產生數組,需要自己去取碼表,還有就是用一些軟件取出來的碼表可能有負值,所以需要將這樣的碼表整體抬升成正值。
關鍵的問題來了,就是這數組怎么取出來的這是關鍵的,lz說說你怎么取得數組
本來想在上面說明一下,我以為大家都知道,很簡單,有一個SPWM碼表產生的軟件,網上應該能找到,只是取出來的數應該有負數,所以需要抬升,至于抬升的辦法就看自己了。可以用EXCEL來做,也可以自己寫一個簡單的c程序。上面的SPWM碼表的產生其實也可以自己寫一個簡單的C程序來完成,這就需要自己想一點算法了。
我就好人做到底把SPWM波碼表的產生軟件和我自己寫的一個碼表的抬升程序都上傳了吧。抬升程序解壓之后在碼表抬升軟件文件夾下的debug文件夾下,直接運行daydayup。exe就可以了,第一次提醒輸入抬升的碼表的碼值個數,然后提醒輸入碼表(可以直接粘貼上去),然后會提醒輸入要抬升多少,最后會以一定的格式輸出,自己再復制出來就可以了。
SPWM波產生軟件.rar
(159.56 KB, 下載次數: 83)
2016-1-4 18:07 上傳
只是產生PWM波其實不需要DMA模塊完全可以的,DMA主要是我用來產生SPWM波的。你可以試一下,上個碼表就行了
橘沐希
2016-4-20 17:07
謝謝樓主
橘沐希
2016-4-20 17:08
謝謝樓主
K.S
2017-10-8 16:42
可以可以
jmjack
2018-8-10 16:35
謝謝樓主
