引腳號 | 引腳名稱(復位后的功能) | 引腳類型 | I/O結構 | 復用功能 | 附加功能 | 備注 |
1 | VBAT | S | 備用電源 | |||
2 | PC13 | I/O | TC | - | RTC_TAMP1, RTC_TS,RTC_OUT, WKUP2 | (1)(2) |
3 | PC14-OSC32_IN(PC14) | I/O | TC | - | OSC32_IN | (1)(2) |
4 | PC15-OSC32_OUT(PC15) | I/O | TC | - | OSC32_OUT | (1)(2) |
5 | PF0-OSC_IN(PF0) | I/O | FT | - | OSC_IN | |
6 | PF1-OSC_OUT(PF1) | I/O | FT | - | OSC_OUT | |
7 | NRST | I/O | RST | 器件復位輸入 / 內部復位輸出(低電平有效) | ||
8 | VSSA | S | 模擬地 | |||
9 | VDDA | S | 模擬電源 | |||
10 | PA0 | I/O | TTa | USART2_CTS, TIM2_CH1_ETR, COMP1_OUT, TSC_G1_IO1 | ADC_IN0, COMP1_ INM6, RTC_TAMP2, WKUP1 | |
11 | PA1 | I/O | TTa | USART2_RTS, TIM2_CH2, TSC_ G1_IO2, EVENTOUT | ADC_IN1, COMP1_INP | |
12 | PA2 | I/O | TTa | USART2_TX, TIM2_CH3, TIM15_ CH1, COMP2_OUT, TSC_G1_IO3 | ADC_IN2, COMP2_ INM6 | |
13 | PA3 | I/O | TTa | USART2_RX, TIM2_CH4, TIM15_ CH2, TSC_G1_IO4 | ADC_IN3, COMP2_INP | |
14 | PA4 | I/O | TTa | SPI1_NSS/I2S1_WS, USART2_ CK, TIM14_CH1, TSC_G2_IO1 | ADC_IN4, COMP1_ INM4, COMP2_INM4, DAC1_OUT | |
15 | PA5 | I/O | TTa | SPI1_SCK/I2S1_CK, CEC, TIM2_ CH_ETR, TSC_G2_IO2 | ADC_IN5, COMP1_ INM5, COMP2_INM5 | |
16 | PA6 | I/O | TTa | SPI1_MISO/I2S1_MCK, TIM3_ CH1, TIM1_BKIN, TIM16_CH1, COMP1_OUT, TSC_G2_IO3, EVENTOUT | ADC_IN6 | |
17 | PA7 | I/O | TTa | SPI1_MOSI/I2S1_SD, TIM3_ CH2, TIM14_CH1, TIM1_CH1N, TIM17_CH1, COMP2_OUT, TSC_ G2_IO4, EVENTOUT | ADC_IN7 | |
18 | PB0 | I/O | TTa | TIM3_CH3, TIM1_CH2N, TSC_ G3_IO2, EVENTOUT | ADC_IN8 | |
19 | PB1 | I/O | TTa | TIM3_CH4, TIM14_CH1, TIM1_ CH3N, TSC_G3_IO3 | ADC_IN9 | |
20 | PB2 | I/O | FT | TSC_G3_IO4 | - | |
21 | PB10 | I/O | FT | I2C2_SCL, CEC, TIM2_CH3, TSC_SYNC | - | |
22 | PB11 | I/O | FT | I2C2_SDA, TIM2_CH4, TSC_G6_IO1, EVENTOUT | - | |
23 | VSS | S | 數字地 | |||
24 | VDD | S | 數字電源 | |||
25 | PB12 | I/O | FT | SPI2_NSS, TIM1_BKIN, TSC_ G6_IO2, EVENTOUT | - | |
26 | PB13 | I/O | FT | SPI2_SCK, TIM1_CH1N, TSC_ G6_IO3 | - | |
27 | PB14 | I/O | FT | SPI2_MISO, TIM1_CH2N, TIM15_ CH1, TSC_G6_IO | - | |
28 | PB15 | I/O | FT | SPI2_MOSI, TIM1_CH3N, TIM15_ CH1N, TIM15_CH2 | RTC_REFIN | |
29 | PA8 | I/O | FT | USART1_CK, TIM1_CH1, EVENTOUT, MCO | - | |
30 | PA9 | I/O | FT | USART1_TX, TIM1_CH2, TIM15_BKIN, TSC_G4_IO1 | - | |
31 | PA10 | I/O | FT | USART1_RX, TIM1_CH3, TIM17_BKIN, TSC_G4_IO2 | - | |
32 | PA11 | I/O | FT | USART1_CTS, TIM1_CH4, COMP1_OUT, TSC_G4_IO3, EVENTOUT | - | |
33 | PA12 | I/O | FT | USART1_RTS, TIM1_ETR, COMP2_OUT, TSC_G4_IO4, EVENTOUT | - | |
34 | PA13(SWDIO) | I/O | FT | IR_OUT, SWDIO | - | (3) |
35 | PF6 | I/O | FTf | I2C2_SCL | - | |
36 | PF7 | I/O | FTf | I2C2_SDA | - | |
37 | PA14(SWCLK) | I/O | FT | USART2_TX, SWCLK | - | (3) |
38 | PA15 | I/O | FT | SPI1_NSS, I2S1_WS, USART2_RX, TIM2_CH1_ETR, EVENTOUT | - | |
39 | PB3 | I/O | FT | SPI1_SCK, I2S1_CK, TIM2_CH2, TSC_G5_IO1, EVENTOUT | - | |
40 | PB4 | I/O | FT | SPI1_MISO, I2S1_MCK, TIM3_CH1, TSC_G5_IO2, EVENTOUT | - | |
41 | PB5 | I/O | FT | SPI1_MOSI, I2S1_SD, I2C1_SMBA, TIM16_BKIN, TIM3_CH2 | - | |
42 | PB6 | I/O | FTf | I2C1_SCL, USART1_TX, TIM16_CH1N, TSC_G5_IO3 | - | |
43 | PB7 | I/O | FTf | I2C1_SDA, USART1_RX, TIM17_CH1N, TSC_G5_IO4 | - | |
44 | BOOT0 | I | B | Boot memory selection | ||
45 | PB8 | I/O | FTf | I2C1_SCL, CEC, TIM16_CH1, TSC_SYNC | - | (3) |
46 | PB9 | I/O | FTf | I2C1_SDA, IR_OUT, TIM17_CH1, EVENTOUT | - | |
47 | VSS | S | 數字地 | |||
48 | VDD | S | 數字電源 | |||
名稱 | 縮寫 | 定義 | |
引腳名 | 除非在指定的引腳名稱下面有括號說明,在復位期間和之后,引腳作為實際使用的功能與引腳名稱相同。 | ||
引腳類型 | S | 電源引腳 | |
I | 僅是輸入口 | ||
I/O | 輸入/輸出雙向口 | ||
I/O結構 | FT | 5V容忍能力I/O | |
FTf | 5V容忍能力I/O,附加 FM+ 能力 | ||
TTa | 3.3V容忍能力的I/O直接連接到ADC | ||
TC | 標準3.3VI/O | ||
B | 專用BOOT0引腳 | ||
RST | 雙向復位引腳,并嵌入弱上拉電阻 | ||
注釋 | 除非注釋中提到,否則所有I/O口在復位期間和復位后,認為是浮空輸入。 | ||
引腳功能 | 復用功能 | 通過 GPIOx_AFR寄存器選擇的功能 | |
附加功能 | 通過外設寄存器直接選擇/使能的功能 | ||
