標(biāo)題: 一個使單片機輸出視頻的庫TVout [打印本頁]
作者: 51黑論壇迷    時間: 2015-12-19 23:58
        一個開源庫,使得單片機可以輸出視頻,可以參考這個(由于是google code 項目,因此不好查看,特地記錄如下):
TVout Library
TVout is a completely interrupt driven library that will output either NTSC or PAL composite.
Hardware Connections
Connect an RCA plug to the arduino according to the following schematic. A 75 OHM resistor may be needed between VID and GND on the RCA plug for a very small subset ofTVs
SYNC is on OCR1A and AUDIO is on OCR2A
