標(biāo)題: pid控溫程序存在,測了輸出端波形很亂,但變化有一定規(guī)律,pwm波不是方波嗎?怎么.... [打印本頁]
作者: xixi852582    時間: 2015-11-15 17:09
#include<intrins.h>
#include<math.h>
#include<string.h>
struct PID
    unsigned int SetPoint ;
    // 設(shè)定目標(biāo) Desired Value
    unsigned int Proportion ;
    // 比例常數(shù) Proportional Const
    unsigned int Integral ;
    // 積分常數(shù) Integral Const
    unsigned int Derivative ;
    // 微分常數(shù) Derivative Const
    unsigned int LastError ;
    // Error[-1]
    unsigned int PrevError ;
    // Error[-2]
    unsigned int SumError ;
    // Sums of Errors
struct PID spid ;
// PID Control Structure
unsigned int rout ;
// PID Response (Output)
unsigned int rin ;
// PID Feedback (Input)
unsigned int set_temper,temper,s ;
sbit output=P3^4;
unsigned char high_time,low_time,count=0 ;
//占空比調(diào)節(jié)參數(shù)
void PIDInit(struct PID*pp)
    memset(pp,0,sizeof(struct PID)); //PID參數(shù)初始化全部設(shè)置為0
unsigned int PIDCalc(struct PID*pp,unsigned int NextPoint)
    unsigned int dError,Error ;
    Error=pp->SetPoint-NextPoint ;
    // 偏差
    pp->SumError+=Error ;
    // 積分
    dError=pp->LastError-pp->PrevError ;
    // 當(dāng)前微分
    pp->PrevError=pp->LastError ;
    pp->LastError=Error ;
    //比例
    //積分項
    return(pp->Proportion*Error+pp->Integral*pp->SumError+pp->Derivative*dError);
    // 微分項
溫度比較處理子程序
void compare_temper(unsigned int set_temper,unsigned int temper)
    unsigned char i ;
    //EA=0;
    if(set_temper>temper)
        if(set_temper-temper>10)
            high_time=100 ; //大于1°不進(jìn)行PID運算
            low_time=0 ;
        {   //在1°范圍內(nèi)進(jìn)行PID運算
            for(i=0;i<10;i++)
                //get_temper();
                rin=temper;
                // Read Input
                rout=PIDCalc(&spid,rin); //執(zhí)行PID運算
                // Perform PID Interation
            if(high_time<=100) //限制最大值
            high_time=(unsigned char)(rout/800);
            high_time=100;
            low_time=(100-high_time);
    else if(set_temper<=temper) //當(dāng)實際溫度大于設(shè)置溫度時
        if(temper-set_temper>0)//如果實際溫度大于設(shè)定溫度
            high_time=0 ;
            low_time=100 ;
            for(i=0;i<10;i++)
                //get_temper();
                rin=temper;
                // Read Input
            if(high_time<100) //此變量是無符號字符型
            high_time=(unsigned char)(rout/10000);
            high_time=0 ;//限制不輸出負(fù)值
            //EA=1;
T1中斷服務(wù)子程序,用于控制電平的翻轉(zhuǎn) ,40us*100=4ms周期
void serve_T1()interrupt 3 using 1
    if(++count<=(high_time))
         output=0 ;
    else if(count<=100)
        output=1 ;
    count=0 ;
    TH1=0x2f ;
    TL1=0xe0 ;
void PIDBEGIN()
    TH1=0x2f ;
    TL1=0x40 ;
    ET1=1 ;
    TR1=1 ;
    high_time=50 ;
    low_time=50 ;
    PIDInit(&spid);
    // Initialize Structure
    spid.Proportion=10 ;
    // Set PID Coefficients
    spid.Integral=8 ;
    spid.Derivative=6 ;
    spid.SetPoint=100 ;
    // Set PID Setpoint
#endif
main
while(1){
PIDBEGIN();
if(hengwen==0)
  compare_temper(temp4,temp5);
temp4是設(shè)定溫度和temp5時實際溫度,求高人指點,急急急
