標題: 基于stc89c51的示波器制作 程序,仿真,原理圖分享 [打印本頁]
作者: 滔滔貓    時間: 2015-10-25 22:09
基于stc89c51的示波器制作,自己剛剛做出來的,程序,仿真,原理圖
部分程序代碼預覽(完整版本請下載本帖最后的附件)
  1. #include "lcd12864.h"
  2. #include "osc.h"
  3. #include "common.h"
  4. #include "dots.h"
  5. unsigned char val_vdiv=2; //Y軸電壓標度索引0~5
  6. unsigned char val_tdiv=0; //X軸時間標度索引0~5
  7. unsigned char acdc_flag=0; //交流直流檔切換
  8. unsigned char run_flag=0;  //運行停止切換
  9. unsigned char pointxA;
  10. unsigned char pointxB;
  11. unsigned char pointyA;
  12. unsigned char pointyB;
  13. unsigned char xdata da_buffer[DATA_SIZE];
  14. unsigned char da_finish;
  15. char movx=0; //水平移動
  16. char movy=0; //垂直移動
  17. unsigned char code vdiv [] = {1,2,5,10,20,50};//電壓標度索引是0到5,實際是0.1到5.0
  18. unsigned char code tdiv [] = {8,10,20,50,100};//掃描時間標度索引是0到5
  19. void disp_ypoint(void)
  20. {
  21.         unsigned char dat[ALL_LINE];
  22.         unsigned char j,i;
  23.         for(j=0;j<3;j++) {
  24.                 for(i=0;i<7;i++) dat[i] = 0;
  25.                 if(j==0) {
  26.                         dat[(pointyA-2)/8] |= 0x01<<((pointyA-2)%8);
  27.                         dat[(pointyA-1)/8] |= 0x01<<((pointyA-1)%8);
  28.                         dat[(pointyA  )/8] |= 0x01<<((pointyA  )%8);
  29.                         dat[(pointyA+1)/8] |= 0x01<<((pointyA+1)%8);
  30.                         dat[(pointyA+2)/8] |= 0x01<<((pointyA+2)%8);
  31.
  32.                         dat[(pointyB-2)/8] |= 0x01<<((pointyB-2)%8);
  33.                         dat[(pointyB-1)/8] |= 0x01<<((pointyB-1)%8);
  34.                         dat[(pointyB  )/8] |= 0x01<<((pointyB  )%8);
  35.                         dat[(pointyB+1)/8] |= 0x01<<((pointyB+1)%8);
  36.                         dat[(pointyB+2)/8] |= 0x01<<((pointyB+2)%8);
  37.
  38.                         /*上下平移標志*/
  39.                         if(movy== (HEIGHT/2)) {
  40.                                 dat[(HEIGHT/2+4-movy)/8] |= 0x01<<((HEIGHT/2+4-movy)%8);
  41.                                 dat[(HEIGHT/2+5-movy)/8] |= 0x01<<((HEIGHT/2+5-movy)%8);
  42.                         }
  43.                         else if(movy==-(HEIGHT/2)) {
  44.                                 dat[(HEIGHT/2+5-movy)/8] |= 0x01<<((HEIGHT/2+5-movy)%8);
  45.                                 dat[(HEIGHT/2+6-movy)/8] |= 0x01<<((HEIGHT/2+6-movy)%8);
  46.                         }
  47.                         else {
  48.                                 dat[(HEIGHT/2+5-movy)/8] |= 0x01<<((HEIGHT/2+5-movy)%8);
  49.                         }
  50.                         /*寫LCD,刷新顯示*/
  51.                         for(i=0;i<ALL_LINE;i++) {
  52.                                 lcd_cmd_wr(SETY+i,0);
  53.                                 lcd_cmd_wr(SETX+ZEROX-4,0);
  54.                                 lcd_data_wr(dat[i],0);
  55.                         }
  56.                 }
  57.                 else if(j==1){
  58.                         dat[(pointyA-1)/8] |= 0x01<<((pointyA-1)%8);
  59.                         dat[(pointyA  )/8] |= 0x01<<((pointyA  )%8);
  60.                         dat[(pointyA+1)/8] |= 0x01<<((pointyA+1)%8);
  61.                         dat[(pointyB-1)/8] |= 0x01<<((pointyB-1)%8);
  62.                         dat[(pointyB  )/8] |= 0x01<<((pointyB  )%8);
  63.                         dat[(pointyB+1)/8] |= 0x01<<((pointyB+1)%8);
  64.
  65.                         /*上下平移標志*/
  66.                         dat[(HEIGHT/2+4-movy)/8] |= 0x01<<((HEIGHT/2+4-movy)%8);
  67.                         dat[(HEIGHT/2+5-movy)/8] |= 0x01<<((HEIGHT/2+5-movy)%8);
  68.                         dat[(HEIGHT/2+6-movy)/8] |= 0x01<<((HEIGHT/2+6-movy)%8);
  69.
  70.                         /*寫LCD,刷新顯示*/
  71.                                 for(i=0;i<ALL_LINE;i++) {
  72.                                 lcd_cmd_wr(SETY+i,0);
  73.                                 lcd_cmd_wr(SETX+ZEROX-3,0);
  74.                                 lcd_data_wr(dat[i],0);
  75.                         }
  76.                 }
  77.                 else {
  78.                         dat[(pointyA)/8] |= 0x01<<((pointyA)%8);
  79.                         dat[(pointyB)/8] |= 0x01<<((pointyB)%8);
  80.
  81.                         /*上下平移標志*/
  82.                         if(movy==(HEIGHT/2)) {
  83.                                 dat[(HEIGHT/2+4-movy)/8] |= 0x01<<((HEIGHT/2+4-movy)%8);
  84.                                 dat[(HEIGHT/2+5-movy)/8] |= 0x01<<((HEIGHT/2+5-movy)%8);
  85.                         }
  86.                         else if(movy==-(HEIGHT/2)) {
  87.                                 dat[(HEIGHT/2+5-movy)/8] |= 0x01<<((HEIGHT/2+5-movy)%8);
  88.                                 dat[(HEIGHT/2+6-movy)/8] |= 0x01<<((HEIGHT/2+6-movy)%8);
  89.                         }
  90.                         else {
  91.                                 dat[(HEIGHT/2+5-movy)/8] |= 0x01<<((HEIGHT/2+5-movy)%8);
  92.                         }
  93.
  94.                         /*寫LCD,刷新顯示*/
  95.                         for(i=0;i<ALL_LINE;i++) {
  96.                                 lcd_cmd_wr(SETY+i,0);
  97.                                 lcd_cmd_wr(SETX+ZEROX-2,0);
  98.                                 lcd_data_wr(dat[i],0);
  99.                         }
  100.                 }
  101.         }
  102. }
  103. //LCD波形顯示區
  104. void disp(unsigned char x,unsigned char y,char l)
  105. {
  106.         unsigned char dat[ALL_LINE],j,k;
  107.         x += ZEROX;
  108.         y = ZEROY-1-y;//1是修正1行空白行
  109.         dat[0] = 0x10;
  110.         dat[1] = 0x0;
  111.         dat[2] = 0x0;
  112.         dat[3] = 0x0;
  113.         dat[4] = 0x0;
  114.         dat[5] = 0x0;
  115.         dat[6] = 0x40;
  116.
  117.         if((x+1)%5==0) {
  118.                 dat[3] |= 0x20;        /*水平中心線*/
  119.                 dat[pointyA/8] |= 0x01<<pointyA%8;        /*水平測量線A*/
  120.                 dat[pointyB/8] |= 0x01<<pointyB%8;        /*水平測量線B*/
  121.         }
  122.         /*上下邊框格點*/
  123.         //if(((x-ZEROX) ==WIDTH/2-1)||((x-ZEROX)%5==0)||((x-ZEROX) == WIDTH/2+1)) {
  124.         if((x-ZEROX)%5==0) {
  125.                 dat[0] |= 0x20;dat[ALL_LINE-1] |= 0x20;
  126.         }
  127.         /*垂直測量線格點和垂直中心線*/
  128.         if(((x-ZEROX) == pointxA)||((x-ZEROX) == pointxB)||((x-ZEROX) == WIDTH/2)) {
  129.                 dat[0] |= 0x10;
  130.                 dat[1] |= 0x42;
  131.                 dat[2] |= 0x08;
  132.                 dat[3] |= 0x21;
  133.                 dat[4] |= 0x84;
  134.                 dat[5] |= 0x10;
  135.                 dat[6] |= 0x42;
  136.         }
  137.         /*頂端測量線三角符號*/
  138.         if(x-ZEROX==(pointxA-2)) dat[0] |= 0x01;
  139.         if(x-ZEROX==(pointxA-1)) dat[0] |= 0x03;
  140.         if(x-ZEROX==(pointxA  )) dat[0] |= 0x07;
  141.         if(x-ZEROX==(pointxA+1)) dat[0] |= 0x03;
  142.         if(x-ZEROX==(pointxA+2)) dat[0] |= 0x01;
  143.         if(x-ZEROX==(pointxB-2)) dat[0] |= 0x01;
  144.         if(x-ZEROX==(pointxB-1)) dat[0] |= 0x03;
  145.         if(x-ZEROX==(pointxB  )) dat[0] |= 0x07;
  146.         if(x-ZEROX==(pointxB+1)) dat[0] |= 0x03;
  147.         if(x-ZEROX==(pointxB+2)) dat[0] |= 0x01;
  148.         /*頂端中點左右平移標志*/
  149.         if(movx == (WIDTH/2-1)) {
  150.                 if(x-ZEROX==WIDTH/2-movx-1) dat[0] |= 0x07;
  151.                 if(x-ZEROX==WIDTH/2-movx  ) dat[0] |= 0x07;
  152.                 if(x-ZEROX==WIDTH/2-movx+1) dat[0] |= 0x02;
  153.         }
  154.         else if(movx==-(WIDTH/2-1)) {
  155.                 if(x-ZEROX==WIDTH/2-movx-1) dat[0] |= 0x02;
  156.                 if(x-ZEROX==WIDTH/2-movx  ) dat[0] |= 0x07;
  157.                 if(x-ZEROX==WIDTH/2-movx+1) dat[0] |= 0x07;
  158.         }
  159.         else {
  160.                 if(x-ZEROX==WIDTH/2-movx-1) dat[0] |= 0x02;
  161.                 if(x-ZEROX==WIDTH/2-movx) dat[0] |= 0x07;
  162.                 if(x-ZEROX==WIDTH/2-movx+1) dat[0] |= 0x02;
  163.         }
  164.         /*左邊框*/
  165.         if(x==ZEROX) {
  166.                 dat[0] = 0xf0;
  167.                 dat[1] = 0xff;
  168.                 dat[2] = 0xff;
  169.                 dat[3] = 0xff;
  170.                 dat[4] = 0xff;
  171.                 dat[5] = 0xff;
  172.                 dat[6] = 0x7f;
  173.         }
  174.         /*左邊框上格點*/
  175.         if(x==ZEROX+1) {
  176.                 dat[0] |= 0x10;
  177.                 dat[1] |= 0x42;
  178.                 dat[2] |= 0x08;
  179.                 dat[3] |= 0x21;
  180.                 dat[4] |= 0x84;
  181.                 dat[5] |= 0x10;
  182.                 dat[6] |= 0x42;
  183.         }
  184.         /*右邊框*/
  185.         if(x==ZEROX+WIDTH-1) {
  186.                 dat[0] = 0xf0;
  187.                 dat[1] = 0xff;
  188.                 dat[2] = 0xff;
  189.                 dat[3] = 0xff;
  190.                 dat[4] = 0xff;
  191.                 dat[5] = 0xff;
  192.                 dat[6] = 0x7f;
  193.         }
  194.         /*右邊框格點*/
  195.         if(x==ZEROX+WIDTH-2) {
  196.                 dat[0] |= 0x10;
  197.                 dat[1] |= 0x42;
  198.                 dat[2] |= 0x08;
  199.                 dat[3] |= 0x21;
  200.                 dat[4] |= 0x84;
  201.                 dat[5] |= 0x10;
  202.                 dat[6] |= 0x42;
  203.         }
  204.         /*波形描點*/
  205.         if(l==0) dat[(y)/8] |= 0x01<<((y)%8);
  206.         else if(l>0) {
  207.                 for(j=0;j<l+1;j++) { //+1多描1點,波形更粗壯
  208.                         k=((y+j)/8);
  209.                         if(k>6) k=6;
  210.                         if(k==0) dat[0] |= (0x01<<((y+j)%8))&0xe0;
  211.                         else if(k==6) dat[6] |= (0x01<<((y+j)%8))&0x3f;
  212.                         else dat[k] |= 0x01<<((y+j)%8);
  213.                 }
  214.         }
  215.         else for(j=0;j<(-l)+1;j++) {
  216.                 k=((y-j)/8);
  217.                 if(k>6) k=6;
  218.                 if(k==0) dat[0] |= (0x01<<((y-j)%8))&0xf0;
  219.                 else if(k==6) dat[6] |= (0x01<<((y-j)%8))&0x3f;
  220.                 else dat[k] |= 0x01<<((y-j)%8);
  221.         }
  222.         /*寫入LCD*/
  223.         if(x<64) {
  224.                 for(j=0;j<ALL_LINE;j++) {
  225.                         lcd_cmd_wr(SETY+j,0);
  226.                         lcd_cmd_wr(SETX+x,0);
  227.                         lcd_data_wr(dat[j],0);
  228.                 }
  229.         }
  230.         else {
  231.                 x-=64;
  232.                 for(j=0;j<ALL_LINE;j++) {
  233.                         lcd_cmd_wr(SETY+j,1);
  234.                         lcd_cmd_wr(SETX+x,1);
  235.                         lcd_data_wr(dat[j],1);
  236.                 }
  237.         }
  238. }
  239. void disp_vdiv(void)
  240. {
  241.         unsigned int tmp;
  242.
  243.         tmp = vdiv[val_vdiv];
  244.         /*y軸電壓標度*/
  245.         lcd12864_put_xystr(0,7,4,Num+(tmp/10)*4);
  246.         lcd12864_put_xystr(5,7,1,Num+10*4);
  247.         lcd12864_put_xystr(7,7,4,Num+(tmp%10)*4);
  248.         tmp = tdiv[val_tdiv];
  249.         /*x軸時間標度*/
  250.         if(tmp<100) {
  251.                 lcd12864_put_clr(23,7,8);
  252.                 lcd12864_put_xystr(23,7,4,Num+(tmp/10)*4);
  253.                 lcd12864_put_xystr(28,7,1,Num+10*4);
  254.                 lcd12864_put_xystr(30,7,4,Num+(tmp%10)*4);
  255.         }
  256.         else {
  257.                 lcd12864_put_clr(23,7,8);
  258.                 lcd12864_put_xystr(25,7,4,Num+1*4);
  259.                 lcd12864_put_xystr(30,7,4,Num+0*4);
  260.         }
  261.         /*AC,DC標識*/
  262.         lcd12864_put_xystr(47,7,12,ac_dc+acdc_flag*12);//0=ac,1=dc
  263.         /*RUN,PAUSE標識*/
  264.         lcd12864_put_xystr(60,7,17,run_paus+run_flag*17);//0=run,1=paus
  265.
  266.         tmp=(pointyB-pointyA)*vdiv[val_vdiv];
  267.         tmp/=5;
  268.         if(tmp < 100) {
  269.                 /*測量電壓*/
  270.                 lcd12864_put_clr(79,7,11);
  271.                 lcd12864_put_xystr(79,7,4,Num + (tmp/10)*4);
  272.                 lcd12864_put_xystr(84,7,1,Num + 10*4);
  273.                 lcd12864_put_xystr(86,7,4,Num + (tmp%10)*4);
  274.         }
  275.         else {
  276.                 lcd12864_put_clr(79,7,11);
  277.                 lcd12864_put_xystr(79,7,4,Num+ (tmp/100)*4);
  278.                 lcd12864_put_xystr(85,7,4,Num+ (tmp/10 %10)*4);
  279.         }
  280.
  281.         tmp=50000/(pointxB-pointxA)/tdiv[val_tdiv];
  282.         /*測量頻率*/
  283.         lcd12864_put_clr(99,7,20);
  284.         if(tmp<10) {
  285.                 lcd12864_put_xystr(114,7,4,Num+ (tmp%10)*4);
  286.         }
  287.         else if(tmp <100) {
  288.                 lcd12864_put_xystr(109,7,4,Num+ (tmp/10%10)*4);
  289.                 lcd12864_put_xystr(114,7,4,Num+ (tmp%10)*4);
  290.         } else if(tmp <1000) {
  291.                 lcd12864_put_xystr(104,7,4,Num+ (tmp/100)*4);
  292.                 lcd12864_put_xystr(109,7,4,Num+ (tmp/10%10)*4);
  293.                 lcd12864_put_xystr(114,7,4,Num+ (tmp%10)*4);
  294.         }
  295.         else {
  296.                 lcd12864_put_xystr(99,7,4,Num+ (tmp/1000)*4);
  297.                 lcd12864_put_xystr(104,7,4,Num+ (tmp/100%10)*4);
  298.                 lcd12864_put_xystr(109,7,4,Num+ (tmp/10%10)*4);
  299.                 lcd12864_put_xystr(114,7,4,Num+ (tmp%10)*4);
  300.         }
  301. }
基于STC89C52單片機數字示波器.zip
145.47 KB, 下載次數: 759, 下載積分: 黑幣 -5
作者: 騰飛的龍    時間: 2015-10-26 12:37
這么強的啊,尊敬!51黑有你更精彩!!!
作者: 快樂516    時間: 2015-10-26 20:54
沒有圖嗎?
作者: 滔滔貓    時間: 2015-10-27 16:01
快樂516 發表于 2015-10-26 20:54
沒有圖嗎?
你是要什么圖?實物圖嗎?
作者: qwa1234    時間: 2015-10-27 18:39
額,,至少來點介紹內容吧
作者: loam    時間: 2015-10-28 11:17
謝謝分享,下來看看
作者: AOP    時間: 2015-10-28 21:50
51單片機做的!強
作者: wangwo    時間: 2015-12-10 16:36
樓主發帖辛苦了,謝謝分享!!!!!!!!
作者: caidance    時間: 2015-12-13 00:54
太強了搞不懂.
作者: xsynet    時間: 2015-12-19 08:16
贊,51hei有你更精彩
作者: xsynet    時間: 2015-12-19 08:17
有具體內容介紹嗎?
作者: 撫你柔發的風    時間: 2016-2-25 19:43
我要做一個基于單片機與PC的虛擬示波器,在PC上用vb做一個示波器界面,用單片機測量收集電壓數據傳送給PC建立數據庫,vb做的界面讀取數據庫顯示電壓波形,想你教我怎么在你這個上改,求回復
作者: zdmjjp    時間: 2016-2-28 17:09
謝謝分享!下來看看
作者: bubu    時間: 2016-3-2 23:21
高手!先下來看看。謝謝!
作者: 小白111    時間: 2016-4-4 17:56
bubu 發表于 2016-3-2 23:21
高手!先下來看看。謝謝!
高手,下載來學習學習,謝謝
作者: yjx189    時間: 2016-4-5 16:49
撫你柔發的風 發表于 2016-2-25 19:43
我要做一個基于單片機與PC的虛擬示波器,在PC上用vb做一個示波器界面,用單片機測量收集電壓數據傳送給PC建 ...
想法不錯,要是能把帶寬做到100M,那就更好了!
作者: 追夢人    時間: 2016-5-4 14:01
現在很需要有關示波器方面的資料
作者: 122884558    時間: 2016-5-5 13:01
謝謝分享,下來看看
作者: baoshu2006    時間: 2016-5-5 21:42
x下來看看11!!!!!!!!
作者: 豆豆丨君    時間: 2016-5-6 20:28
受益匪淺 頂! 這種帖子才是精華
作者: 一只風箏    時間: 2016-5-15 12:04
謝謝分享,51黑有你分享更精彩
作者: 545078887    時間: 2016-7-10 15:25
謝謝分享,下來看看
作者: 1684242519    時間: 2016-7-21 15:51
這個太強悍了,只能膜拜!
作者: 智能想    時間: 2016-7-24 21:51
大神啊,敬慕
作者: zheng_wei339    時間: 2016-7-27 08:01
希望樓主將參數寫出來,相比PIC18F2550做的有什么區別
作者: 薯條    時間: 2016-8-20 22:39
一直在找,這個不錯試試怎么樣。
作者: stabox    時間: 2016-8-28 22:37
謝謝分享,在找這方面的資料
作者: 雙贏電子    時間: 2016-8-31 23:52
51做的很有才下載一份學習一下,謝謝分享
作者: yaojl    時間: 2016-9-1 10:14
樓主高手啊!
作者: youchuang    時間: 2016-9-1 10:30
我在學單片機,正好用的上,收藏了。
作者: youchuang    時間: 2016-9-1 10:31
我在學單片機,正好用的上,收藏了。
作者: 新鄉家電維修    時間: 2016-9-1 11:51
圖不管用啊,99SE打不開
作者: 親愛的h    時間: 2016-9-6 22:55
這個真不錯,樓主厲害
作者: 邰夏留    時間: 2016-10-12 08:36
下載下來參考下。。
作者: alphax86    時間: 2016-10-15 15:07
謝謝分享,樓主辛苦了
作者: zlkj    時間: 2016-11-17 19:00
謝謝分享!
作者: fdgdfgfdshfhg    時間: 2016-11-26 11:31
仿真不能用呀
作者: 445646    時間: 2016-12-11 21:20
154646464163456
作者: 七彩繽紛    時間: 2016-12-15 01:21
下載學習下
作者: 張紀元    時間: 2016-12-15 14:31
感謝樓主分享
作者: opop1988    時間: 2016-12-19 18:18
感謝樓主分享
作者: dgvt1218    時間: 2017-1-6 23:02
支持一下
作者: sogeam    時間: 2017-1-8 10:52
支持一下
作者: onepcb    時間: 2017-1-13 18:31
正在學習,多交流!
作者: liuzx66    時間: 2017-1-20 15:59
感謝樓主分享
作者: YYloveTM    時間: 2017-2-22 12:53
不錯哦~
作者: sxsndhl    時間: 2017-4-14 12:59
很好的資料,簡單易做,多謝分享。
作者: 18463580323    時間: 2017-4-23 11:48
發現程序和仿真程序不一樣啊
作者: zkj2003    時間: 2017-4-23 18:30
好厲害!膜拜!
作者: SingleYork2017    時間: 2017-6-14 14:09
哎呀,可惜積分不夠,下載不了
作者: prrank    時間: 2017-6-16 10:37
非常好的學習資料
作者: bg5taq    時間: 2017-6-22 20:32
謝謝分享,下來看看
作者: 我是柔情劍客    時間: 2017-7-17 19:52
路過,學習一下。
作者: easee    時間: 2017-7-22 10:20
很好的參考資料
作者: bi7jvw    時間: 2017-8-10 20:12
謝謝樓主,最近就想搞個示波器來玩
作者: 名TinANI    時間: 2017-11-7 16:18
好資源 謝謝分享........
作者: mektecfego    時間: 2017-11-18 13:51
雖然下載不了,但是還要先贊一個!
作者: aaaa_7777    時間: 2017-11-18 17:30
贊一個!
作者: 792245610a    時間: 2017-11-19 23:12
很好,學習學習
作者: xxbgwxz    時間: 2017-11-20 09:14
示波器感覺太強大了 佩服學習!
作者: sunbbk    時間: 2018-2-5 11:52
太好了 下載學習一下
作者: qjzyx    時間: 2018-2-5 15:51
謝謝分享
作者: lizhendong    時間: 2018-2-5 21:14
太好了,支持支持,學習學習
作者: tieq1952    時間: 2018-2-7 08:01
高手,學習了。
作者: 呵呵的    時間: 2018-3-21 20:21
是不是缺少了mini51b.c,運行keil是一直是target not created
作者: rueidingele    時間: 2018-4-16 13:12
厲害了大牛...
作者: liyangtop    時間: 2018-4-16 15:20
不錯呀! 高手
作者: baobeishuma    時間: 2018-4-18 09:39
感謝樓主分享!
作者: 全方科技    時間: 2018-4-18 16:12
單片機應用學習資料之一。
作者: 酷酷酷    時間: 2018-6-14 22:01
程序編譯不了,我按原理圖做了pcb調不出波形,求解啊
作者: 酷酷酷    時間: 2018-6-14 22:50
呵呵的 發表于 2018-3-21 20:21
你解決了嗎?同問
作者: dongfang08    時間: 2018-6-18 05:49
謝謝分享
作者: 橘子醬    時間: 2018-10-30 13:57
666666666666
作者: ihoyrtsm    時間: 2018-10-30 16:09
下載學習下
作者: 張懷震    時間: 2018-10-30 17:11
真的很不錯
作者: 張懷震    時間: 2018-10-30 17:12
這這個網站真好   謝謝站長提供這么好的信息交流平臺,謝謝
作者: 快樂眼淚    時間: 2018-10-30 19:14
新手能做成功嗎?
作者: ywylc    時間: 2018-12-30 09:50
贊贊,資料很好用
作者: 鄉下人    時間: 2018-12-30 11:05
作者: 快樂眼淚    時間: 2019-1-1 20:47
有誰做成功了嗎?
作者: myhuang027    時間: 2019-1-3 19:16
牛人!正好需要找這方面的資料!
作者: lhrlhr    時間: 2019-3-16 13:41
作者: zsq12    時間: 2019-3-16 16:32
大佬,太厲害了
作者: 老王包子    時間: 2019-3-24 08:18
**** 作者被禁止或刪除 內容自動屏蔽 ****
你好,請問您做的這個還在嗎
作者: zpz181818    時間: 2019-3-25 12:06
非常好的資料。
作者: ZSS    時間: 2019-4-27 17:38
學習了,謝謝
作者: 孫景月    時間: 2019-4-27 19:42
強,怎么能下載全部程序?
作者: 西瓜不懂檸檬    時間: 2019-4-27 22:50
這個挺好
作者: 18046717467    時間: 2019-5-9 15:42
資源很好,值得一看
作者: 八稚女    時間: 2019-8-19 19:40
為什么把程序文件夾的main.c文件放進仿真圖文件里面不顯示?把仿真文件夾的main.c文件又可以成功?兩個文件夾的main.c文件有什么不同?
作者: 728378409    時間: 2019-11-26 23:05
這個用的是什么仿真
作者: HSCCSH    時間: 2019-12-21 13:32
僅僅是仿真嗎?實物做成功過,帶寬達到多少兆赫?
作者: chweji123    時間: 2019-12-27 20:14
謝謝分享!!!!!!!
作者: wyk1237    時間: 2019-12-31 16:19
很實用,學習學習。
作者: 1029487496    時間: 2020-4-20 14:52
仿真不能用
作者: myd    時間: 2020-4-21 16:29
仿真漂亮,感謝分享
作者: lfq3779    時間: 2022-3-20 15:24
今天修好一個開關電源,隨手用之前做的示波器測了下494的波形
