˜Ë(bi¨¡o)î}: ÐÂÊÖ×ÔŒW(xu¨¦)ÇóŽÍÖú£¡¶¨•r(sh¨ª)ÖДà’ßÃè¾Øê‡æI±P¡£ [´òÓ¡±¾í“(y¨¨)]
×÷Õß: ÎÒÊÇÐìïw    •r(sh¨ª)ég: 2015-10-15 13:06
ÓÃ†ÎÆ¬™C(j¨©)¶¨•r(sh¨ª)ÖДàÍê³É¾Øê‡æI±PµÄ’ßÃ裬µ«ÊÇ¿‚ÊDz»Œ¦(du¨¬)¡£ÏÂÃæÊÇÎҵijÌÐò¡£Ç󣬸ßÊÖÖ¸×C£¡£¡£¡£¡
£¨æI±PÎÒÖ»ÓÃÁËǰËÄ‚€(g¨¨)£©
#include<reg52.h>
uchar code table[]={
0xfe,0xfd,0xfb,0xf7,0xef,
0xdf,0xbf,0x7f};
sbit dula=P2^6;
sbit wela=P2^7;
void delay(uint z)                 //ÑÓ•r(sh¨ª)º¯”µ(sh¨´)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=114;y>0;y--);
void display(uchar num)
                dula=1;
                P0=table[num];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfe;
                wela=0;
                delay(5);
        uchar num;
        TMOD=0x01;
     TH0=(65536-1000)/256;
     TL0=(65536-1000)%256;
     EA=1;
     ET0=1;
         TR0=1;
                display(num);
void IT_0()interrupt 1
        if((P1&0xf0)!=0xf0)
                uchar temp,key;
                P3=0xfe;
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        if(temp!=0xf0)
                                temp=P3;
                                switch(temp)
                                        case 0xee:
                                                key=0;
                                                break;
                                        case 0xde:
                                                key=1;
                                                break;
                                        case 0xbe:
                                                key=2;
                                                break;
                                        case 0x7e:
                                                key=3;
                                                break;
                                while(temp!=0xf0)
                                        temp=P3;
                                        temp=temp&0xf0;
                        display(key);
×÷Õß: ÎÒÊÇÐìïw    •r(sh¨ª)ég: 2015-10-15 13:07
×Ô¼ºí”һϡ£
×÷Õß: ÎÒÊÇÐìïw    •r(sh¨ª)ég: 2015-10-15 13:14
ÎÒÊÇÐìïw °l(f¨¡)±íÓÚ 2015-10-15 13:07
×Ô¼ºí”һϡ£
Çó½â´ð
×÷Õß: ahshmj    •r(sh¨ª)ég: 2015-10-15 14:40
¶¨•r(sh¨ª)Æ÷ÖДàég¸ôÌ«¶ÌÁË£¬¼Ó´óµ½20000~50000¶¼¿ÉÒÔ¡£
×÷Õß: ÎÒÊÇÐìïw    •r(sh¨ª)ég: 2015-10-15 18:19
ahshmj °l(f¨¡)±íÓÚ 2015-10-15 14:40
Ô‡ÁË£¬²»Ðа¡£¬ÕZ(y¨³)·¨ÉÏÓЛ](m¨¦i)ÓÐʲôåe(cu¨°)Õ`£¿
×÷Õß: ÇàÌO¹û    •r(sh¨ª)ég: 2015-10-16 09:03
ºÇºÇ£¬°´æI³ÌÐò›](m¨¦i)¿´¶®¹þ
Õf(shu¨­)Ò»ÏÂï@ʾ°É£¬Ã¿´Î½oP0ÙxÖµ¶¼‘ª(y¨©ng)Ô“ÑÓßtÒ»¶¨µÄ•r(sh¨ª)ég†Ñ£¬ÎÒ¿´Äã½oP0ËÍÁ˃ɴÎÖµ£¬ÔÚï@ʾµÄµØ·½£¬µ«ÊÇǰһ´Î½oÍêÁËñRÉÏÓÖÔÚ½oÒ»´ÎÁË£¬£¬£¬ß@ÀïÎÒÒ²²»ÖªµÀÄãÒª×öʲô
ÔÙ£¬ÏñÄãß@‚€(g¨¨)³ÌÐò£¬²»ÓÃÔÚÖДàÀïÃæÕ{(di¨¤o)ÓÃdisplay³ÌÐò£¬Äã¿ÉÒÔÔÚ³ÌÐòÀïÃæ¸Ä׃numµÄÖµ¾Í¿ÉÒÔÁË£¬®”(d¨¡ng)È»£¬ NUM‘ª(y¨©ng)Ô“Òª¸Ä³ÉÈ«¾Ö׃Á¿
×÷Õß: ÎÒÊÇÐìïw    •r(sh¨ª)ég: 2015-10-25 18:43
ÇàÌO¹û °l(f¨¡)±íÓÚ 2015-10-16 09:03
Õf(shu¨­)Ò»ÏÂï@ʾ°É£¬Ã¿´Î½oP0ÙxÖµ¶¼‘ª(y¨©ng)Ô“ÑÓßtÒ»¶¨µÄ•r(sh¨ª)ég†Ñ£¬ÎÒ¿´Äã½oP0ËÍÁ˃ɴÎÖµ£¬ÔÚï@ ...
àÅ£¬¸ãºÃÁË
×÷Õß: С¹ÅÔ    •r(sh¨ª)ég: 2015-10-30 19:39
ºÃ°É ÎÒÒ²ÊÇÐÂÈË
šgÓ­¹âÅR (http://m.raoushi.com/bbs/) Powered by Discuz! X3.1
