51鬧鐘程序
小瑞
2015-8-17 19:43
51鬧鐘程序
#include<reg52.h>
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit key4=P3^7;
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
sbit led1=P1^0;
sbit led2=P1^1;
sbit led3=P1^2;
sbit led4=P1^3;
sbit led5=P1^4;
sbit led6=P1^5;
sbit led7=P1^6;
sbit led8=P1^7;
char shi,fen,miao,shi0=-1,fen0,miao0=1, shi1,fen1,miao1,
numt0,numt1,numt2,num,num1,num2,num3,i=1,aa,nian,yue=1,ri=1;
char shi2=-1,shi3=-1,fen2,fen3,miao2=2,miao3=3,num4,num5,flag;
uchar code table[]=
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71
void delayms(uint xms) //延時
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void display(char shi,char fen,char miao) //顯示子函數
char shi1,shi2,fen1,fen2,miao1,miao2;
shi1=shi%10;
shi2=shi/10;
fen1=fen%10;
fen2=fen/10;
miao1=miao%10;
miao2=miao/10;
dula=1;
P0=0x80;
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delayms(1);
dula=1;
P0=0x80;
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delayms(1);
dula=1;
P0=table[miao1];
dula=0;
P0=0xff;
wela=1;
P0=0xdf;
wela=0;
delayms(1);
dula=1;
P0=table[miao2];
dula=0;
P0=0xff;
wela=1;
P0=0xef;
wela=0;
delayms(1);
dula=1;
P0=table[fen1];
dula=0;
P0=0xff;
wela=1;
P0=0xf7;
wela=0;
delayms(1);
dula=1;
P0=table[fen2];
dula=0;
P0=0xff;
wela=1;
P0=0xfb;
delayms(1);
dula=1;
P0=table[shi1];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
delayms(1);
dula=1;
P0=table[shi2];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delayms(1);
void tiaoshi() //二十四小時制調時
if(key1==0)
delayms(5);
if(key1==0)
num++;
while(!key1);
if(num==3)
num=0;
void tiaobiao()
if(num==0)
led1=0;led3=1;led2=1;
if(key2==0)
delayms(5);
if(key2==0)
shi++;
shi1++;
while(!key2);
if(shi==24)
shi=0;
if(shi1==13)
shi1=1;
if(key3==0)
delayms(5);
if(key3==0)
shi--;
shi1--;
while(!key3);
if(shi==-1)
shi=23;
if(shi1==0)
shi1=12;
if(num==1)
led2=0;led1=1;led3=1;
if(key2==0)
delayms(5);
if(key2==0)
fen++;
fen1++;
while(!key2);
if(fen==60)
fen=0;
if(fen1==60)
fen1=0;
if(key3==0)
delayms(5);
if(key3==0)
fen--;
fen1--;
while(!key3);
if(fen==-1)
fen=59;
if(fen1==-1)
fen1=59;
if(num==2)
led3=0;led2=1;led1=1;
if(key2==0)
delayms(5);
if(key2==0)
miao++;
miao1++;
while(!key2);
if(miao==60)
miao=0;
if(miao1==60)
miao1=0;
if(key3==0)
delayms(5);
if(key3==0)
miao--;
miao1--;
while(!key3);
if(miao==-1)
miao=59;
if(miao1==-1)
miao1=59;
void moshi() //模式選擇
if(key4==0)
delayms(5);
if(key4==0)
aa++;
if(aa==7)
aa=0;
while(!key4);
void naozhong() //鬧鐘設置
if(key1==0)
delayms(5);
if(key1==0)
num1++;
num4++;
num5++;
if(num1==2)
num1=0;
if(num4==2)
num4=0;
if(num5==2)
num5=0;
while(!key1);
void sznz()
if(num1==0)
led1=0;led2=1;led3=1;
if(key2==0)
delayms(5);
if(key2==0)
shi0++;
if(shi0==24)
shi0=0;
while(!key2);
if(num1==1)
led2=0; led1=1;led3=1;
if(key2==0)
delayms(5);
if(key2==0)
fen0++;
if(fen0==60)
fen0=0;
while(!key2);
if(key3==0)
delayms(5);
if(key3==0)
flag++;
P1=0;
if(flag==2)
flag=0;
while(!key3);
void sznz1()
if(num4==0)
if(key2==0)
delayms(5);
if(key2==0)
shi2++;
if(shi2==24)
shi2=0;
while(!key2);
if(num4==1)
if(key2==0)
delayms(5);
if(key2==0)
fen2++;
if(fen2==60)
fen2=0;
while(!key2);
if(key3==0)
delayms(5);
if(key3==0)
flag++;
P1=0;
if(flag==2)
flag=0;
while(!key3);
void sznz2()
if(num5==0)
if(key2==0)
delayms(5);
if(key2==0)
shi3++;
if(shi3==24)
shi3=0;
while(!key2);
if(num1==1)
if(key2==0)
delayms(5);
if(key2==0)
fen3++;
if(fen3==60)
fen3=0;
while(!key2);
if(key3==0)
delayms(5);
if(key3==0)
flag++;
P1=0;
if(flag==2)
flag=0;
while(!key3);
void riqi() //調日期
if(key1==0)
delayms(5);
if(key1==0)
num2++;
if(num2==3)
num2=0;
while(!key1);
void xgrq()
if(num2==0)
if(key2==0)
delayms(5);
if(key2==0)
nian++;
while(!key2);
if(key3==0)
delayms(5);
if(key3==0)
nian--;
while(!key3);
if(num2==1)
if(key2==0)
delayms(5);
if(key2==0)
yue++;
if(yue==13)
yue=1;
while(!key2);
if(key3==0)
delayms(5);
if(key3==0)
yue--;
if(yue==0)
yue=12;
while(!key3);
if(num2==2)
led3=0; led2=1;led1=1;
if(key2==0)
delayms(5);
if(key2==0)
ri++;
if(ri==32)
ri=1;
while(!key2);
if(key3==0)
delayms(5);
if(key3==0)
ri--;
if(ri==0)
ri=31;
while(!key3);
void init()
TMOD=0x11;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
TH1=(65536-45872)/256;
TL1=(65536-45872)%256;
EA=1;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
init();
moshi();
if(aa==0) //時鐘24小時制
display(shi,fen,miao);
tiaobiao();
tiaoshi();
if(aa==1) //時鐘12小時制
display(shi1,fen1,miao1);
tiaobiao();
tiaoshi();
if(aa==2) //日期
display(nian,yue,ri);
riqi();
xgrq();
if(aa==3) //鬧鐘 1
display(shi0,fen0,miao0);
naozhong();
sznz();
if(aa==4) //鬧鐘 2
display(shi2,fen2,miao2);
naozhong();
sznz1();
if(aa==5) //鬧鐘 3
display(shi3,fen3,miao3);
naozhong();
sznz2();
if(aa==6)
if(key1==0)
delayms(5);
if(key1==0)
TR1=~TR1;
beep=1;
P0=0xf7;
while(!key1);
if(key2==0)
delayms(5);
if(key2==0)
beep=1;
delayms(10000);
beep=0;
delayms(5000);
void T0_time() interrupt 1
numt0++;
if(numt0==20)
numt0=0;
miao++; //二十四小時制
if(miao==60)
miao=0;fen++;
if(fen==60)
fen=0;shi++;
if(shi==24)
shi=0 ;
ri++;
if(
(ri==32&&yue==1)||(ri==30&&yue==2)||(ri==32&&yue==3)||(ri==31&&yue==4)||
(ri==32&&yue==5)||(ri==31&&yue==6)||(ri==32&&yue==7)||(ri==32&&yue==8)||
(ri==31&&yue==9)||(ri==32&&yue==10)||(ri==31&&yue==11)||(ri==32&&yue==12)
ri=1;
yue++;
if(yue==13)
yue=1;
nian++;
miao1++;
if(miao1==60) //十二小時制
miao1=0;
fen1++;
if(fen1==60)
fen1=0;
shi1++;
if(shi1==13)
i++;
if(i%2==0)
led8=0;
led7=1;
if(i%2!=0)
led8=1;
led7=0;
shi1=1;
void T1_time() interrupt 3
numt1++;
if(flag==0)
if(numt1==20)
numt1=0;
if(
(shi0==shi&&fen0==fen&&miao<10)||
(shi2==shi&&fen2==fen&&miao<10)|| //鬧鐘響
(shi3==shi&&fen3==fen&&miao<10)
beep=0;
beep=1;
if(flag==1)
{ beep=1;
if(numt1==20)
numt1=0;
if(
(shi0==shi&&fen0==fen&&miao<12)||
(shi2==shi&&fen2==fen&&miao<12)|| //鬧鐘響
(shi3==shi&&fen3==fen&&miao<12)
beep=0;
GUOPK
2015-8-18 09:07
實踐成功??有沒有電路圖。
南天白云
2015-8-18 17:56
樓主:你用51單片機定時與實際時間相差多少?不過你思路可以,玩玩還是可以的,拿來做成實際東西可能不能吧?
wangxiaomi
2015-11-1 19:53
要是有圖就好了
