STC12C2052AD.H頭文件下載 引腳圖 管腳定義封裝及中文資料
songjia
2015-7-8 15:18
STC12C2052AD引腳圖 封裝圖 管腳定義
(41.22 KB, 下載次數(shù): 195)
2015-7-8 15:15 上傳
STC12C2052AD.H頭文件下載 :
http://m.raoushi.com/bbs/dpj-36960-1.html
/* After is STC additional SFR or change */
/* sfr AUXR = 0x8e; */
/* sfr IPH = 0xb7; */
/* Watchdog Timer Register */
sfr WDT_CONTR = 0xe1;
/* ISP_IAP_EEPROM Register */
sfr ISP_DATA = 0xe2;
sfr ISP_ADDRH = 0xe3;
sfr ISP_ADDRL = 0xe4;
sfr ISP_CMD = 0xe5;
sfr ISP_TRIG = 0xe6;
sfr ISP_CONTR = 0xe7;
/* IDLE, Clock Divider */
sfr IDLE_CLK = 0xc7;
/* I_O Port Mode Set Register */
sfr P0M0 = 0x93;
sfr P0M1 = 0x94;
sfr P1M0 = 0x91;
sfr P1M1 = 0x92;
sfr P2M0 = 0x95;
sfr P2M1 = 0x96;
sfr P3M0 = 0xb1;
sfr P3M1 = 0xb2;
/* SPI Register */
sfr SPSTAT = 0x84;
sfr SPCTL = 0x85;
sfr SPDAT = 0x86;
/* ADC Register */
sfr ADC_CONTR = 0xc5;
sfr ADC_DATA = 0xc6;
sfr ADC_LOW2 = 0xbe;
/* PCA SFR */
sfr CCON = 0xD8;
sfr CMOD = 0xD9;
sfr CCAPM0 = 0xDA;
sfr CCAPM1 = 0xDB;
sfr CCAPM2 = 0xDC;
sfr CCAPM3 = 0xDD;
sfr CCAPM4 = 0xDE;
sfr CCAPM5 = 0xDF;
sfr CL = 0xE9;
sfr CCAP0L = 0xEA;
sfr CCAP1L = 0xEB;
sfr CCAP2L = 0xEC;
sfr CCAP3L = 0xED;
sfr CCAP4L = 0xEE;
sfr CCAP5L = 0xEF;
sfr CH = 0xF9;
sfr CCAP0H = 0xFA;
sfr CCAP1H = 0xFB;
sfr CCAP2H = 0xFC;
sfr CCAP3H = 0xFD;
sfr CCAP4H = 0xFE;
sfr CCAP5H = 0xFF;
sfr PCA_PWM0 = 0xF2;
sfr PCA_PWM1 = 0xF3;
sfr PCA_PWM2 = 0xF4;
sfr PCA_PWM3 = 0xF5;
sfr PCA_PWM4 = 0xF6;
sfr PCA_PWM5 = 0xF7;
/* CCON */
sbit CF = CCON^7;
sbit CR = CCON^6;
sbit CCF5 = CCON^5;
sbit CCF4 = CCON^4;
sbit CCF3 = CCON^3;
sbit CCF2 = CCON^2;
sbit CCF1 = CCON^1;
sbit CCF0 = CCON^0;
/* Above is STC additional SFR or change */
REG51F.H
Header file for 8xC31/51, 80C51Fx, 80C51Rx+
Copyright (c) 1988-1999 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
Modification according to DataSheet from April 1999
- SFR's AUXR and AUXR1 added for 80C51Rx+ derivatives
/* BYTE Registers */
sfr P0 = 0x80;
sfr P1 = 0x90;
sfr P2 = 0xA0;
sfr P3 = 0xB0;
sfr PSW = 0xD0;
sfr ACC = 0xE0;
sfr B = 0xF0;
sfr SP = 0x81;
sfr DPL = 0x82;
sfr DPH = 0x83;
sfr PCON = 0x87;
sfr TCON = 0x88;
sfr TMOD = 0x89;
sfr TL0 = 0x8A;
sfr TL1 = 0x8B;
sfr TH0 = 0x8C;
sfr TH1 = 0x8D;
sfr IE = 0xA8;
sfr IP = 0xB8;
sfr SCON = 0x98;
sfr SBUF = 0x99;
/* 80C51Fx/Rx Extensions */
sfr AUXR = 0x8E;
/* sfr AUXR1 = 0xA2; */
sfr SADDR = 0xA9;
sfr IPH = 0xB7;
sfr SADEN = 0xB9;
sfr T2CON = 0xC8;
sfr T2MOD = 0xC9;
sfr RCAP2L = 0xCA;
sfr RCAP2H = 0xCB;
sfr TL2 = 0xCC;
sfr TH2 = 0xCD;
/* BIT Registers */
/* PSW */
sbit CY = PSW^7;
sbit AC = PSW^6;
sbit F0 = PSW^5;
sbit RS1 = PSW^4;
sbit RS0 = PSW^3;
sbit OV = PSW^2;
sbit P = PSW^0;
/* TCON */
sbit TF1 = TCON^7;
sbit TR1 = TCON^6;
sbit TF0 = TCON^5;
sbit TR0 = TCON^4;
sbit IE1 = TCON^3;
sbit IT1 = TCON^2;
sbit IE0 = TCON^1;
sbit IT0 = TCON^0;
/* P3 */
sbit RD = P3^7;
sbit WR = P3^6;
sbit T1 = P3^5;
sbit T0 = P3^4;
sbit INT1 = P3^3;
sbit INT0 = P3^2;
sbit TXD = P3^1;
sbit RXD = P3^0;
/* SCON */
sbit SM0 = SCON^7; // alternatively "FE"
sbit FE = SCON^7;
sbit SM1 = SCON^6;
sbit SM2 = SCON^5;
sbit REN = SCON^4;
sbit TB8 = SCON^3;
sbit RB8 = SCON^2;
sbit TI = SCON^1;
sbit RI = SCON^0;
sbit T2EX = P1^1;
sbit T2 = P1^0;
/* T2CON */
sbit TF2 = T2CON^7;
sbit EXF2 = T2CON^6;
sbit RCLK = T2CON^5;
sbit TCLK = T2CON^4;
sbit EXEN2 = T2CON^3;
sbit TR2 = T2CON^2;
sbit C_T2 = T2CON^1;
sbit CP_RL2= T2CON^0;
/* PCA Pin */
sbit CEX3 = P2^4;
sbit CEX2 = P2^0;
sbit CEX1 = P3^5;
sbit CEX0 = P3^7;
sbit ECI = P3^4;
/* IE */
sbit EA = IE^7;
sbit EPCA_LVD = IE^6;
sbit EADC_SPI = IE^5;
sbit ES = IE^4;
sbit ET1 = IE^3;
sbit EX1 = IE^2;
sbit ET0 = IE^1;
sbit EX0 = IE^0;
/* IP */
sbit PPCA_LVD = IP^6;
sbit PADC_SPI = IP^5;
sbit PS = IP^4;
sbit PT1 = IP^3;
sbit PX1 = IP^2;
sbit PT0 = IP^1;
sbit PX0 = IP^0;
STC12C2052AD中文資料下載鏈接:
STC12C2052AD中文資料.rar
(203 Bytes, 下載次數(shù): 57)
2015-7-8 15:17 上傳
Rod
2017-7-26 15:45
謝謝樓主,正好在學(xué)習(xí)這個
