標題: 單片機51神器三季:點陣字幕—用單片機寫漢字 [打印本頁]
作者: hongniu    時間: 2015-6-24 01:00
*                  LED點陣實驗(流動顯示1 2 3 4 5 6 7 8 9)         *
* 說明 通過P0 和 P2 作為點陣接口                                 *
*要求學員掌握 LED點陣的工作原理和 各點陣腳的定義及接法,具體接線請參考接線說明       *
*我們采用的LED點陣式是低功耗,在做實驗時可以用單片機腳直接驅動                          *
#include<reg51.h>
unsigned char code tab[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,};  //列選通控制
unsigned char code digittab[18][8]={
{0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
{0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
{0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
{0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
{0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
{0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
{0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
{0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
{0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
{0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
{0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
{0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
{0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
{0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
{0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
{0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
{0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00}, //N
{0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00}  //中
unsigned int timecount1 , timecount2;  //定義的變量
unsigned char cntx , cnty ;  //cntx列控制數的變量   cnty用來控制 字符與字符之間的切換
void main(void)
  cnty=0;
   if(cnty<18) //紅色
    P1=0xFF; //列選通都關閉掉
    P2=tab[cntx];  // 列線
    P0=digittab[cnty][cntx];   // 行線
  else //綠色
    P2=0xFF;  //紅色的列選通都關閉掉
    P1=tab[cntx];   // 列線
    P0=digittab[cnty-18][cntx];  // 行線
//用于控制動態掃描的速度
  if(++timecount1>=50)
    timecount1=0;
    if(++cntx>=8) cntx=0;
//用于控制動字符間的切換速度
  if(++timecount2>=20000)
    timecount2=0;
    if(++cnty>=36)cnty=0;
