標題: 從0到20每隔一秒循環閃爍閃爍 [打印本頁]
作者: huyun    時間: 2015-6-5 00:31
標題: 從0到20每隔一秒循環閃爍閃爍
電路圖詳見:http://m.raoushi.com/f/51hei-5.pdf
#include <reg52.h>
sbit wexu=P2^7;
sbit duxu=P2^6;
uchar a,bai,shi,ge,shu;
uchar code table[]=
{0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71
void yanshi(uint z);
void xianshi(uint shu);
void chushi();
        chushi();
                if(a==20)
                        a=0;
                        shu++;
                        if(shu==20)
                                shu=0;
                xianshi(shu);
void chushi()
        EA=1;
        ET0=1;
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=1;
        wexu=0;
        duxu=0;
        a=0;
        shu=0;
        ge=shu%10;
        shi=shu%100/10;
        bai=shu/100;
        wexu=1;
        P0=0xfb;
        wexu=0;
        P0=0xff;
        duxu=1;
        P0=table[ge];
        duxu=0;
        yanshi(5);
        wexu=1;
        P0=0xfd;
        wexu=0;
        P0=0xff;
        duxu=1;
        P0=table[shi];
        duxu=0;
        yanshi(5);
        wexu=1;
        P0=0xfe;
        wexu=0;
        P0=0xff;
        duxu=1;
        P0=table[bai];
        duxu=0;
        yanshi(5);
void yanshi(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void timer0() interrupt 1
        a++;
