標題: 精確到百分之一秒的跑表 [打印本頁]
作者: huyun    時間: 2015-6-5 00:29
標題: 精確到百分之一秒的跑表
#include <reg52.h>
sbit key1=P3^4;
        sbit wexu=P2^7;
sbit duxu=P2^6;
uchar code table[]=
{0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71
uint shu;
uchar bai,shi,ge;
void chushi();
void yanshi(uint z);
void xianshi(uint shu);
        chushi();
                if(key1==0)
                        yanshi(5);
                        if(key1==0)
                                TR0=0;
                        while(!key1);
                        yanshi(5);
                        while(!key1);
                TR0=1;
                xianshi(shu);
void chushi()
        key1=1;
        EA=1;
        ET0=1;
        TMOD=0x01;
        TH0=(65536-10000)/256;
        TL0=(65536-10000)%256;
        TR0=1;
        wexu=0;
        duxu=0;
        shu=0;
        ge=shu%10;
        shi=shu%100/10;
        bai=shu/100;
        wexu=1;
        P0=0xfb;
        wexu=0;
        P0=0xff;
        duxu=1;
        P0=table[ge];
        duxu=0;
        yanshi(5);
        wexu=1;
        P0=0xfd;
        wexu=0;
        P0=0xff;
        duxu=1;
        P0=table[shi];
        duxu=0;
        yanshi(5);
        wexu=1;
        P0=0xfe;
        wexu=0;
        P0=0xff;
        duxu=1;
        P0=table[bai];
        duxu=0;
        yanshi(5);
void yanshi(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void timer0() interrupt 1
        shu++;
        if(shu==1000)
                shu=0;
