1602液晶的驅(qū)動(dòng)案例
[打印本頁(yè)]
huyun
時(shí)間:
2015-6-5 00:26
#include<reg52.h>
uchar code table[]="Yin Jian Jun !";
uchar code table1[]="TEL: 18755359012";
sbit lcden=P3^4;
sbit lcdrs=P3^5;
sbit dula=P2^6;
sbit wela=P2^7;
uchar num;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date)
lcdrs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
dula=0;
wela=0;
lcden=0;
write_com(0x38);
write_com(0x0e);
write_com(0x06);
write_com(0x01);
write_com(0x80+0x10);
init();
for(num=0;num<14;num++)
write_data(table[num]);
delay(20);
// write_com(1);
write_com(0x80+0x50);
for(num=0;num<16;num++)
write_data(table1[num]);
delay(20);
write_com(0x18);
delay(20);
delay(20000);
write_com(0x01);
while(1);
