STM32學習-使用DMA功能自動更新PWM的輸出
xiongxiao
2015-5-27 16:28
完整程序源代碼工程文件下載地址:
使用DMA功能自動更新PWM的輸出.RAR
(253.23 KB, 下載次數: 181)
2015-5-27 17:41 上傳
#if (RCC_PLLMul==2) // ok
#define RCC_PLLMul_ RCC_PLLMul_2
#elif (RCC_PLLMul==4)
#define RCC_PLLMul_ RCC_PLLMul_4
#elif (RCC_PLLMul==8)
#define RCC_PLLMul_ RCC_PLLMul_8
#elif (RCC_PLLMul==9)
#define RCC_PLLMul_ RCC_PLLMul_9
#elif (RCC_PLLMul==16)
#define RCC_PLLMul_ RCC_PLLMul_16
#else
error
#endif
#define SYSCLK (float)(FREQ_HSE*RCC_PLLMul)
#if (RCC_AHB_Div==1) // ok
#define RCC_HCLK_Div_ RCC_SYSCLK_Div1
#elif (RCC_AHB_Div==2)
#define RCC_HCLK_Div_ RCC_SYSCLK_Div2
#elif (RCC_AHB_Div==4)
#define RCC_HCLK_Div_ RCC_SYSCLK_Div4
#elif (RCC_AHB_Div==8)
#define RCC_HCLK_Div_ RCC_SYSCLK_Div8
#elif (RCC_AHB_Div==16)
#define RCC_HCLK_Div_ RCC_SYSCLK_Div16
#elif (RCC_AHB_Div==64)
#define RCC_HCLK_Div_ RCC_SYSCLK_Div64
#elif (RCC_AHB_Div==128)
#define RCC_HCLK_Div_ RCC_SYSCLK_Div128
#elif (RCC_AHB_Div==256)
#define RCC_HCLK_Div_ RCC_SYSCLK_Div256
#elif (RCC_AHB_Div==512)
#define RCC_HCLK_Div_ RCC_SYSCLK_Div512
#else
error
#endif
#define HCLK (float)(SYSCLK/RCC_AHB_Div)
#define FCLK (float)(HCLK)
#if (RCC_APB1_Div==1) // ok
#define RCC_PCLK1_Div_ RCC_HCLK_Div1
#elif (RCC_APB1_Div==2)
#define RCC_PCLK1_Div_ RCC_HCLK_Div2
#elif (RCC_APB1_Div==4)
#define RCC_PCLK1_Div_ RCC_HCLK_Div4
#elif (RCC_APB1_Div==8)
#define RCC_PCLK1_Div_ RCC_HCLK_Div8
#elif (RCC_APB1_Div==16)
#define RCC_PCLK1_Div_ RCC_HCLK_Div16
#else
error
#endif
#define PCLK1 (float)(HCLK/RCC_APB1_Div)
#if (RCC_APB2_Div==1) // ok
#define RCC_PCLK2_Div_ RCC_HCLK_Div1
#elif (RCC_APB2_Div==2)
#define RCC_PCLK2_Div_ RCC_HCLK_Div2
#elif (RCC_APB2_Div==4)
#define RCC_PCLK2_Div_ RCC_HCLK_Div4
#elif (RCC_APB2_Div==8)
#define RCC_PCLK2_Div_ RCC_HCLK_Div8
#elif (RCC_APB2_Div==16)
#define RCC_PCLK2_Div_ RCC_HCLK_Div16
#else
error
#endif
#define PCLK2 (float)(HCLK/RCC_APB2_Div)
#if (RCC_ADC_DIV==2)
#define RCC_ADC_DIV_ RCC_PCLK2_Div2
#elif (RCC_ADC_DIV==4)
#define RCC_ADC_DIV_ RCC_PCLK2_Div4
#elif (RCC_ADC_DIV==6)
#define RCC_ADC_DIV_ RCC_PCLK2_Div6
#elif (RCC_ADC_DIV==8)
#define RCC_ADC_DIV_ RCC_PCLK2_Div8
#else
error
#endif
#define FACTOR_TIM234567 1
#else
#define FACTOR_TIM234567 2
#endif
#define TIM234567CLK (PCLK1*FACTOR_TIM234567)
#define TIM2CLK TIM234567CLK
#define TIM3CLK TIM234567CLK
#define TIM4CLK TIM234567CLK
#define TIM5CLK TIM234567CLK
#define TIM6CLK TIM234567CLK
#define TIM7CLK TIM234567CLK
#define TIM1CLK (PCLK2)
#define TIM8CLK (PCLK2)
#else
#define TIM1CLK (PCLK2*2)
#define TIM8CLK (PCLK2*2)
#endif
#define ADCCLK ((float)PCLK2/RCC_ADC_DIV)
#define ADCCLKx10 (10*FREQ_HSE*RCC_PLLMul/(RCC_AHB_Div*RCC_APB2_Div*RCC_ADC_DIV)) // 僅僅用于下面的判斷
#if (ADCCLKx10<6)
error // adc的時鐘最小為0.6MHz
#elif (ADCCLKx10>140)
error // adc的時鐘最大為14MHz
#else
// 正常的adc頻率范圍
#endif
編譯環境: EWARM V5.30
硬件環境: DZY2.PCB
STM32 FW: V3.0.0
作者 : szlihongtao
REV : V1.00
DATE : 2017-04-18
NOTE :
#include "stm32f10x.h"
#include "stm32_m.h"
#include "dzy.h"
#include "myRCC.h"
#define TIM1_CCR3_Address 0x40012C3C
bit f_tb; // 基本定時標志
bit f_100ms,f_1000ms;
INT16U cnt_test; // 計數器,僅供軟件調試使用
float clk_sys; // 僅供軟件調試使用
#if 0
uint16_t SRC_Buffer[]={72*5};// 由于載波頻率取20kHZ,所以最大脈沖寬度不要超50us,即常數不要超過72*50
#else
uint16_t SRC_Buffer[]={72*2,72*5,72*10,72*20,72*40,72*10};// 由于載波頻率取20kHZ,所以最大脈沖寬度不要超50us,即常數不要超過72*50
#endif
// 延時程序,單位為*1ms
void delayms(INT16U cnt)
//#define CONST_1MS 7333 // 72MhZ
//#define CONST_1MS 3588 // 32MhZ
#define CONST_1MS (105*FCLK)
INT16U i;
__no_operation();
while(cnt--)
for (i=0; i<CONST_1MS; i++);
// pcb上的指示燈
static void led_toggle(void)
GPIOC->ODR ^= GPIO_Pin_7; // led2 toogle
GPIOC->ODR ^= GPIO_Pin_6; // led3 toogle
// 時鐘設置初始化
static void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
RCC_AdjustHSICalibrationValue 調整內部高速晶振(HSI)校準值
RCC_ITConfig 使能或者失能指定的RCC中斷
RCC_ClearFlag 清除RCC的復位標志位
RCC_GetITStatus 檢查指定的RCC中斷發生與否
RCC_ClearITPendingBit 清除RCC的中斷待處理位
/* RCC system reset(for debug purpose) */
// 時鐘系統復位
RCC_DeInit();
// 使能外部的8M晶振
// 設置外部高速晶振(HSE)
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
// 使能或者失能內部高速晶振(HSI)
RCC_HSICmd(DISABLE);
// 等待HSE起振
// 該函數將等待直到HSE就緒,或者在超時的情況下退出
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
// 設置AHB時鐘(HCLK)
RCC_HCLKConfig(RCC_HCLK_Div_); // 36 MHz
// 設置低速AHB時鐘(PCLK1)
RCC_PCLK1Config(RCC_PCLK1_Div_); // 2.25 MHz
// 設置高速AHB時鐘(PCLK2)
RCC_PCLK2Config(RCC_PCLK2_Div_); // 2.25 MHz
/* ADCCLK = PCLK2/8 */
// 設置ADC時鐘(ADCCLK)
RCC_ADCCLKConfig(RCC_ADC_DIV_); // 0.281Mhz
// 設置USB時鐘(USBCLK)
// USB時鐘 = PLL時鐘除以1.5
//RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
// 設置外部低速晶振(LSE)
RCC_LSEConfig(RCC_LSE_OFF);
// 使能或者失能內部低速晶振(LSI)
// LSE晶振OFF
RCC_LSICmd(DISABLE);
// 設置RTC時鐘(RTCCLK)
// 選擇HSE時鐘頻率除以128作為RTC時鐘
//RCC_RTCCLKConfig(RCC_RTCCLKSource_HSE_Div128);
// 使能或者失能RTC時鐘
// RTC時鐘的新狀態
RCC_RTCCLKCmd(DISABLE);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* PLLCLK = 8MHz * 9 = 72 MHz */
// 設置PLL時鐘源及倍頻系數
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_);
/* Enable PLL */
// 使能或者失能PLL
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
// 檢查指定的RCC標志位設置與否
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
// 設置系統時鐘(SYSCLK)
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
// 返回用作系統時鐘的時鐘源
while(RCC_GetSYSCLKSource() != 0x08)
// 使能或者失能AHB外設時鐘
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1
|RCC_AHBPeriph_DMA2
|RCC_AHBPeriph_SRAM
|RCC_AHBPeriph_FLITF
|RCC_AHBPeriph_CRC
|RCC_AHBPeriph_FSMC
|RCC_AHBPeriph_SDIO,DISABLE);
// 使能或者失能APB1外設時鐘
RCC_APB1PeriphClockCmd(RCC_APB1Periph_ALL,DISABLE);
// 強制或者釋放高速APB(APB2)外設復位
RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,ENABLE);
// 退出復位狀態
RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,DISABLE);
// 強制或者釋放低速APB(APB1)外設復位
RCC_APB1PeriphResetCmd(RCC_APB1Periph_ALL,ENABLE);
// 強制或者釋放后備域復位
RCC_BackupResetCmd(ENABLE);
// 使能或者失能時鐘安全系統
RCC_ClockSecuritySystemCmd(DISABLE);
// NVIC設置
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* Configure one bit for preemption priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel=TIM1_UP_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
//NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel=TIM1_CC_IRQn;
NVIC_InitStructure.NVIC_IRQChannel=DMA1_Channel5_IRQn;
// SysTick設置初始化
static void SysTick_Config1(void)
#if 1
#define SystemFreq (FCLK*1000000.0) // 單位為Hz
#define TB_SysTick (TIME_TB*1000) // 單位為uS,與示波器實測一致
static INT32U ticks;
ticks=(INT32U)((TB_SysTick/1000000.0)*SystemFreq);
SysTick_Config(ticks);
#endif
// GPIO設置
static void GPIO_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA
|RCC_APB2Periph_GPIOB
|RCC_APB2Periph_GPIOC
|RCC_APB2Periph_GPIOD
|RCC_APB2Periph_AFIO, ENABLE);
GPIO_Write(GPIOA,0xffff);
/* GPIOA Configuration: Channel 3 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
// GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_Write(GPIOB,0xffff); // 11111101-11111111
/* GPIOB Configuration: Channel 3N as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_Write(GPIOC,0xff0f); // 11111111-00001111
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_6|GPIO_Pin_4|GPIO_Pin_5;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_Write(GPIOD,0xffff); // 11111111-11111111
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOD, &GPIO_InitStructure);
void DMA_Configuration(void)
DMA_InitTypeDef DMA_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE); // dma1時鐘使能
DMA_DeInit(DMA1_Channel5); // DMA復位
DMA_StructInit(&DMA_InitStructure);// DMA缺省的參數
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM1_CCR3_Address; //外設地址
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SRC_Buffer;//內存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //dma傳輸方向,單向
DMA_InitStructure.DMA_BufferSize = sizeof(SRC_Buffer)/2; //設置DMA在傳輸時緩沖區的長度
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//設置DMA的外設遞增模式,一個外設
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;//設置DMA的內存遞增模式,
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //外設數據字長
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //內存數據字長
//循環模式開啟,Buffer寫滿后,自動回到初始地址開始傳輸
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //設置DMA的傳輸模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //設置DMA的優先級別
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //設置DMA的2個memory中的變量互相訪問
DMA_Init(DMA1_Channel5, &DMA_InitStructure);
DMA_ClearFlag(DMA1_IT_TC5);
DMA_ITConfig(DMA1_Channel5, DMA_IT_TC, ENABLE);
DMA_Cmd(DMA1_Channel5, ENABLE);
/* TIM1 DMA Transfer example -------------------------------------------------
TIM1CLK = 72 MHz, Prescaler = 0, TIM1 counter clock = 72 MHz
The TIM1 Channel3 is configured to generate a complementary PWM signal with
a frequency equal to: TIM1 counter clock / (TIM1_Period + 1) = 17.57 KHz and
a variable duty cycle that is changed by the DMA after a specific number of
Update DMA request.
The number of this repetitive requests is defined by the TIM1 Repetion counter,
each 3 Update Requests, the TIM1 Channel 3 Duty Cycle changes to the next new
value defined by the SRC_Buffer .
void Tim1_Configuration(void)
INT16U TIM_Prescaler,TIM_Period;
INT32U utemp;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
TIM_DeInit(TIM1);
utemp=(INT32U)(TIM1CLK*1000000.0)/Freq_PWM;
TIM_Prescaler=utemp/65536;
++TIM_Prescaler; // 注意這句話,一定要++
utemp=(INT32U)(TIM1CLK*1000000.0)/TIM_Prescaler; // 分頻后的定時器輸入頻率
TIM_Period=utemp/Freq_PWM; // 周期常數
TIM_TimeBaseStructure.TIM_Period = TIM_Period-1;
TIM_TimeBaseStructure.TIM_Prescaler = TIM_Prescaler-1;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 1-1;// 每次直接更新
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
/* PWM1 Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; // 使能輸出比較狀態
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; // 失能輸出比較N狀態
TIM_OCInitStructure.TIM_Pulse = 72;
TIM_OCMode_PWM2 TIM_OCPolarity_Low 正脈沖模式
TIM_OCMode_PWM2 TIM_OCPolarity_High 負脈沖模式
TIM_OCMode_PWM1 TIM_OCPolarity_Low 負脈沖模式
TIM_OCMode_PWM1 TIM_OCPolarity_High 正脈沖模式
TIM1_OCPolarity輸出極性---TIM_OCPolarity_High,輸出比較極性高,輸出的是正脈沖
TIM1_OCPolarity輸出極性---TIM_OCPolarity_Low, 輸出比較極性低,輸出的是負脈沖
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low; // 互補輸出極性
// 選擇空閑狀態下的非工作狀態
// 當MOE=0設置TIM1輸出比較空閑狀態
// 默認輸出位低電平
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
// 選擇空閑狀態下的非工作狀態
// 當MOE=0重置TIM1輸出比較N空閑狀態
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
TIM_OC3Init(TIM1, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);// 使能TIMx在CCR1上的預裝載寄存器
/* TIM1 Update DMA Request enable */
TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
//TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE); // 定時中斷使能
//TIM_ITConfig(TIM1,TIM_IT_CC3,ENABLE); // 定時中斷使能
TIM_Cmd(TIM1, ENABLE); // 定時器開始運行
// 這條語句必須要有!!!
TIM_CtrlPWMOutputs(TIM1, ENABLE); /* Main Output Enable */
// 基本定時程序,周期為 TIME_TB
static func_tb(void)
static INT16U tmr_100ms;
static INT16U tmr_1000ms;
if (!f_tb)
return;
f_tb=0;
if (++tmr_100ms>=(100/TIME_TB))
tmr_100ms=0;
f_100ms=1;
GPIOC->ODR ^= GPIO_Pin_4; // led5 toogle
if (++tmr_1000ms>=(1000/TIME_TB))
tmr_1000ms=0;
f_1000ms=1;
GPIOC->ODR ^= GPIO_Pin_5; // led4 toogle
// 進入睡眠模式
// 自行編寫
void myPWR_EnterSleepMode(void)
//PWR->CR |= CR_CWUF_Set; /* Clear Wake-up flag */
/* Set SLEEPDEEP bit of Cortex System Control Register */
//*(__IO uint32_t *) SCB_SysCtrl |= SysCtrl_SLEEPDEEP_Set;
/* This option is used to ensure that store operations are completed */
__WFI(); /* Request Wait For Interrupt */
// 主程序
void main(void)
int i;
RCC_Configuration();
GPIO_Configuration();
delayms(100); // 延時,等待電壓穩定
Tim1_Configuration();
DMA_Configuration();
SysTick_Config1();
NVIC_Configuration();
for(i=0;i<6;++i)
//i=0;
//GPIOA->ODR ^= GPIO_Pin_10; // led3 toogle
//GPIOA->ODR ^= GPIO_Pin_11; // led3 toogle
delayms(1);
led_toggle();
for(;;)
//if (set_sw&0x01)
//myPWR_EnterSleepMode(); // 休眠,降低功耗
func_tb();
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval : None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
LED2---------PC7
LED3---------PC6
LED4---------PC5
LED5---------PC4
KEY2---------PD3
KEY3---------PD4
@par Example Description
This example provides a description of how to use DMA with TIM1 Update request
to transfer Data from memory to TIM1 Capture Compare Register3.
a frequency equal to 17.578 KHz and a variable duty cycle that is changed
by the DMA after a specific number of Update event.
each 3 Update Requests, the TIM1 Channel3 Duty Cycle changes to the next new value
defined by the SRC_Buffer.
- STM3210E-EVAL and STM3210B-EVAL Set-up
- Connect the following pins to an oscilloscope to monitor the different waveforms:
- TIM1 CH3 (PA.10) pin69
- TIM1 CH3N (PB.15) pin54
wwchang
2015-6-4 13:54
東西不錯啊。。。
cf5256
2016-1-17 11:40
謝謝分享,51黑有你更精彩!!
jiji800
2016-3-24 14:56
所有的好東西我都要 哇哈哈哈哈
liujiacheng
2016-3-26 09:46
謝謝分享
rdt2016
2017-1-3 13:55
正是我想要的,謝謝
wwkkww1983
2017-1-12 19:08
正是我想要的,謝謝
tigergatlin
2017-2-24 09:46
支持一下
小小視界jjj
2017-9-13 12:10
木有黑幣,下載不了源碼
小小視界jjj
2017-9-13 16:06
你好~
這能改變PWM頻率嗎?還是只改變占空比?
jei8566
2017-11-3 10:36
正在做自動改變PWM頻率的項目,對我幫助很大,但下不了啊!
calvinxxw
2018-5-20 22:25
好資源,謝謝
as3393969
2018-8-16 08:49
支持樓主,好資源
tehity
2019-5-26 20:24
好東西要支持啊
huiui
2019-5-26 21:50
厲害
wjsxgd
2019-5-27 14:14
在要使用這方面的功能,來做可控PWM脈沖數量的PWM輸出。
lisd70
2020-2-2 12:05
學習了,謝謝,很好的參考資料
