28BYJ—48步進電機單片機驅動程序(沒加延時函數效率高)
nius
2015-4-10 02:36
#include<reg51.h>
void Circle_The_Number(unsigned long Number )
static bit a=0;
static unsigned long Num2=0;
Num2=Number*4076;
while(a==0)
unsigned char code BYJ[8]={0x07,0x03,0x0b,0x09,0x0d,0x0c,0x0e,0x06};
static unsigned char Num1=0;
static unsigned char i=0;
static unsigned char d=0;
unsigned char Save;
if(Num2<=0)
a=1;
Save=P1;
Save=Save&0xf0;
Save=Save|BYJ[Num1];
P1=Save;
i++;
if(i==32)
Num1++;
Num1=Num1&0x07;
Num2--;
i=0;
d++;
Circle_The_Number(2);
