標題: STC12C5410AD.h 頭文件 [打印本頁]
作者: xiaos    時間: 2015-4-3 01:35
  1. /* After is STC additional SFR or change */
  2. /* sfr  AUXR  = 0x8e; */
  3. /* sfr  IPH   = 0xb7; */
  4. /* Watchdog Timer Register */
  5. sfr  WDT_CONTR = 0xe1;
  6. /* ISP_IAP_EEPROM Register */
  7. sfr ISP_DATA  = 0xe2;
  8. sfr ISP_ADDRH = 0xe3;
  9. sfr ISP_ADDRL = 0xe4;
  10. sfr ISP_CMD   = 0xe5;
  11. sfr ISP_TRIG  = 0xe6;
  12. sfr ISP_CONTR = 0xe7;
  13. /* System Clock Divider */
  14. sfr CLK_DIV  = 0xc7;
  15. /* I_O Port Mode Set Register */
  16. sfr P0M0  = 0x93;
  17. sfr P0M1  = 0x94;
  18. sfr P1M0  = 0x91;
  19. sfr P1M1  = 0x92;
  20. sfr P2M0  = 0x95;
  21. sfr P2M1  = 0x96;
  22. sfr P3M0  = 0xb1;
  23. sfr P3M1  = 0xb2;
  24. /* SPI Register */
  25. sfr SPSTAT  = 0x84;
  26. sfr SPCTL   = 0x85;
  27. sfr SPDAT   = 0x86;
  28. /* ADC Register */
  29. sfr ADC_CONTR  = 0xc5;
  30. sfr ADC_DATA   = 0xc6;
  31. sfr ADC_LOW2   = 0xbe;
  32. /* PCA SFR */
  33. sfr CCON   = 0xD8;
  34. sfr CMOD   = 0xD9;
  35. sfr CCAPM0 = 0xDA;
  36. sfr CCAPM1 = 0xDB;
  37. sfr CCAPM2 = 0xDC;
  38. sfr CCAPM3 = 0xDD;
  39. sfr CCAPM4 = 0xDE;
  40. sfr CCAPM5 = 0xDF;
  41. sfr CL     = 0xE9;
  42. sfr CCAP0L = 0xEA;
  43. sfr CCAP1L = 0xEB;
  44. sfr CCAP2L = 0xEC;
  45. sfr CCAP3L = 0xED;
  46. sfr CCAP4L = 0xEE;
  47. sfr CCAP5L = 0xEF;
  48. sfr CH     = 0xF9;
  49. sfr CCAP0H = 0xFA;
  50. sfr CCAP1H = 0xFB;
  51. sfr CCAP2H = 0xFC;
  52. sfr CCAP3H = 0xFD;
  53. sfr CCAP4H = 0xFE;
  54. sfr CCAP5H = 0xFF;
  55. sfr PCA_PWM0 = 0xF2;
  56. sfr PCA_PWM1 = 0xF3;
  57. sfr PCA_PWM2 = 0xF4;
  58. sfr PCA_PWM3 = 0xF5;
  59. sfr PCA_PWM4 = 0xF6;
  60. sfr PCA_PWM5 = 0xF7;
  61. /*  CCON  */
  62. sbit CF    = CCON^7;
  63. sbit CR    = CCON^6;
  64. sbit CCF5  = CCON^5;
  65. sbit CCF4  = CCON^4;
  66. sbit CCF3  = CCON^3;
  67. sbit CCF2  = CCON^2;
  68. sbit CCF1  = CCON^1;
  69. sbit CCF0  = CCON^0;
  70. /* Above is STC additional SFR or change */
  71. /*--------------------------------------------------------------------------
  72. REG51F.H
  73. Header file for 8xC31/51, 80C51Fx, 80C51Rx+
  74. Copyright (c) 1988-1999 Keil Elektronik GmbH and Keil Software, Inc.
  75. All rights reserved.
  76. Modification according to DataSheet from April 1999
  77. - SFR's AUXR and AUXR1 added for 80C51Rx+ derivatives
  78. --------------------------------------------------------------------------*/
  79. /*  BYTE Registers  */
  80. sfr P0   = 0x80;
  81. sfr P1   = 0x90;
  82. sfr P2   = 0xA0;
  83. sfr P3   = 0xB0;
  84. sfr PSW  = 0xD0;
  85. sfr ACC  = 0xE0;
  86. sfr B    = 0xF0;
  87. sfr SP   = 0x81;
  88. sfr DPL  = 0x82;
  89. sfr DPH  = 0x83;
  90. sfr PCON = 0x87;
  91. sfr TCON = 0x88;
  92. sfr TMOD = 0x89;
  93. sfr TL0  = 0x8A;
  94. sfr TL1  = 0x8B;
  95. sfr TH0  = 0x8C;
  96. sfr TH1  = 0x8D;
  97. sfr IE   = 0xA8;
  98. sfr IP   = 0xB8;
  99. sfr SCON = 0x98;
  100. sfr SBUF = 0x99;
  101. /*  80C51Fx/Rx Extensions  */
  102. sfr AUXR   = 0x8E;
  103. /* sfr AUXR1  = 0xA2; */
  104. sfr SADDR  = 0xA9;
  105. sfr IPH    = 0xB7;
  106. sfr SADEN  = 0xB9;
  107. sfr T2CON  = 0xC8;
  108. sfr T2MOD  = 0xC9;
  109. sfr RCAP2L = 0xCA;
  110. sfr RCAP2H = 0xCB;
  111. sfr TL2    = 0xCC;
  112. sfr TH2    = 0xCD;
  113. /*  BIT Registers  */
  114. /*  PSW   */
  115. sbit CY   = PSW^7;
  116. sbit AC   = PSW^6;
  117. sbit F0   = PSW^5;
  118. sbit RS1  = PSW^4;
  119. sbit RS0  = PSW^3;
  120. sbit OV   = PSW^2;
  121. sbit P    = PSW^0;
  122. /*  TCON  */
  123. sbit TF1  = TCON^7;
  124. sbit TR1  = TCON^6;
  125. sbit TF0  = TCON^5;
  126. sbit TR0  = TCON^4;
  127. sbit IE1  = TCON^3;
  128. sbit IT1  = TCON^2;
  129. sbit IE0  = TCON^1;
  130. sbit IT0  = TCON^0;
  131. /*  P3  */
  132. sbit RD   = P3^7;
  133. sbit WR   = P3^6;
  134. sbit T1   = P3^5;
  135. sbit T0   = P3^4;
  136. sbit INT1 = P3^3;
  137. sbit INT0 = P3^2;
  138. sbit TXD  = P3^1;
  139. sbit RXD  = P3^0;
  140. /*  SCON  */
  141. sbit SM0  = SCON^7; // alternatively "FE"
  142. sbit FE   = SCON^7;
  143. sbit SM1  = SCON^6;
  144. sbit SM2  = SCON^5;
  145. sbit REN  = SCON^4;
  146. sbit TB8  = SCON^3;
  147. sbit RB8  = SCON^2;
  148. sbit TI   = SCON^1;
  149. sbit RI   = SCON^0;
  150.
  151. sbit T2EX = P1^1;
  152. sbit T2   = P1^0;
  153. /*  T2CON  */
  154. sbit TF2   = T2CON^7;
  155. sbit EXF2  = T2CON^6;
  156. sbit RCLK  = T2CON^5;
  157. sbit TCLK  = T2CON^4;
  158. sbit EXEN2 = T2CON^3;
  159. sbit TR2   = T2CON^2;
  160. sbit C_T2  = T2CON^1;
  161. sbit CP_RL2= T2CON^0;
  162. /* PCA Pin */
  163. sbit CEX3 = P2^4;
  164. sbit CEX2 = P2^0;
  165. sbit CEX1 = P3^5;
  166. sbit CEX0 = P3^7;
  167. sbit ECI  = P3^4;
  168. /*  IE   */
  169. sbit EA   = IE^7;
  170. sbit EPCA_LVD  = IE^6;
  171. sbit EADC_SPI  = IE^5;
  172. sbit ES   = IE^4;
  173. sbit ET1  = IE^3;
  174. sbit EX1  = IE^2;
  175. sbit ET0  = IE^1;
  176. sbit EX0  = IE^0;
  177. /*  IP   */
  178. sbit PPCA_LVD  = IP^6;
  179. sbit PADC_SPI  = IP^5;
  180. sbit PS   = IP^4;
  181. sbit PT1  = IP^3;
  182. sbit PX1  = IP^2;
  183. sbit PT0  = IP^1;
  184. sbit PX0  = IP^0;
作者: 杰諾科技    時間: 2017-9-27 08:37
非常有意義的
