TI牛人寫的運算放大器參數的解釋和分析,固有噪聲的分析與測量
jiajiamei
2015-3-20 19:16
目錄
1、 輸入偏置電流和輸入失調電流 ........................................................................................... 2
2、 如何測量輸入偏置電流Ib,失調電流Ios ......................................................................... 6
3、 輸入失調電壓Vos 及溫漂 ................................................................................................. 10
4、 運放噪聲快速計算 ............................................................................................................. 14
5、 電源抑制比DC-PSRR .......................................................................................................... 18
6、 電源抑制比AC-PSRR .......................................................................................................... 19
7、 共模抑制比CMRR .............................................................................................................. 22
8、 共模抑制比CMRR 的影響 ................................................................................................. 25
9、 放大電路直流誤差(DC error) ....................................................................................... 28
10、 放大電路直流誤差(DC error)的影響因素 ............................................................... 29
11、 輸入阻抗和輸入電容 ..................................................................................................... 31
12、 輸入電容Cin 的測量 ...................................................................................................... 33
13、 軌至軌輸入(rail to rail input) .................................................................................... 35
14、 軌至軌輸入_TI 的領先技術 ........................................................................................... 38
15、 開環增益Aol .................................................................................................................. 40
16、 增益帶寬積(GBW)..................................................................................................... 43
17、 從開環增益曲線談到運放穩定性 ................................................................................. 44
18、 壓擺率(SR) ...................................................................................................................... 47
19、 全功率帶寬(FPBW) ......................................................................................................... 50
20、 建立時間(Settling Time) ................................................................................................. 52
21、 總諧波失真(THD) ........................................................................................................... 53
22、 軌至軌(rail to rail)輸出 ................................................................................................... 55
23、 輸出短路電流 ................................................................................................................. 57
24、 輸出阻抗Ro 和Rout ...................................................................................................... 58
25、 運放的熱阻 ..................................................................................................................... 62
運放參數的詳細解釋和分析
運算放大器電路中固有噪聲的分析與測量
下載地址:
運算放大器電路中固有噪聲的分析與測量.pdf
(4 MB, 下載次數: 140)
2015-3-20 19:14 上傳
運算放大器設計與應用.pdf
(1.14 MB, 下載次數: 131)
2015-3-20 19:14 上傳
c51流浪者
2015-10-18 23:07
感覺很厲害,先收藏,謝謝
lclhitwh
2016-11-16 19:59
謝謝分享,真是好資料
leh
2018-1-6 08:53
學習學習
WLBWXX
2018-1-7 00:50
謝謝分享!
鳳姐438
2018-2-27 09:05
好像 兩個下載的 PDF都沒有 貼中目錄對應的內容 查看PDF頁眉顯示 是(下) 貼中目錄內容是不是再上 希望貼主上傳(上)
921837991
2018-5-10 11:04
學習一下
天天精彩
2018-5-13 03:02
資料可以系統點嗎
