標(biāo)題: 單片機(jī)矩陣鍵盤查尋鍵值4*4程序P1.0---P1.7 [打印本頁]
作者: ccd    時間: 2008-6-25 11:18
//********單片機(jī)矩陣鍵盤查尋鍵值4*4程序******//為P1.0---P1.7
void Tkey(void)
uchar readkey;//rereadkey;
uchar x_temp,y_temp;
uchar key;
P1=0x0f;
x_temp=P1&0x0f;
if(x_temp==0x0f) goto keyout;
P1=0xf0;
y_temp=P1&0xf0;
readkey=x_temp|y_temp;
readkey=~readkey;
switch(readkey)
   case 0x11:key=0; break;
case 0x21:key=1; break;
case 0x41:key=2; break;
case 0x81:key=3; break;
case 0x12:key=4; break;
case 0x22:key=5; break;
case 0x42:key=6; break;
case 0x82:key=7; break;
case 0x14:key=8; break;
case 0x24:key=9; break;
case 0x44:key=10;break;
case 0x84:key=11;break;
case 0x18:key=12;break;
case 0x28:key=13;break;
case 0x48:key=14;break;
case 0x88:key=15;break;
default: key=16;break;
keyout:_nop_();
