中斷服務(wù)函數(shù)
[打印本頁(yè)]
hujia
時(shí)間:
2015-2-18 01:19
中斷服務(wù)函數(shù)
.INCLUDE hardware.inc
//C段中必須包含如下函數(shù),如果沒有書寫,就在每行前加//注釋掉,同
//時(shí)必須注釋掉對(duì)應(yīng)的中斷子程序中的CALL語(yǔ)句
//.EXTERNAL _FIQ_call_F_1024;
//.EXTERNAL _IRQ0_call_F_1024;
//.EXTERNAL _FIQ_call_TMA;
//.EXTERNAL _IRQ1_call_TMA;
//.EXTERNAL _FIQ_call_TMB;
//.EXTERNAL _IRQ2_call_TMB;
//.EXTERNAL _IRQ3_call_EXT2;
//.EXTERNAL _IRQ3_call_EXT1;
//.EXTERNAL _IRQ3_call_KEY;
//.EXTERNAL _IRQ4_call_1KHz;
//.EXTERNAL _IRQ4_call_2KHz;
//.EXTERNAL _IRQ4_call_4KHz;
.EXTERNAL _irq5_call_2hz;
.EXTERNAL _irq5_call_4hz;
//.EXTERNAL _IRQ6_call_TMB1;
//.EXTERNAL _IRQ6_call_TMB2;
.EXTERNAL _Clear_WatchDog;
.TEXT
.PUBLIC _FIQ;
.PUBLIC _IRQ0;
.PUBLIC _IRQ1;
.PUBLIC _IRQ2;
.PUBLIC _IRQ3;
.PUBLIC _IRQ4;
.PUBLIC _IRQ5;
.PUBLIC _IRQ6;
_FIQ:
PUSH r1,r4 TO [sp]; // 現(xiàn)場(chǎng)保護(hù)
PUSH BP TO [SP];
CALL _Clear_WatchDog; // 清看門狗
r1 = ASM_FIQ_TMA; // 中斷源 _FIQ_TMA 定時(shí)器A, 快速中斷
TEST r1,[ASM_Port_INT_Ctrl]; // 測(cè)試r1,[P_INT_Ctrl]
JNE _FIQ_TMA; // 進(jìn)入_FIQ_TMA 定時(shí)器A
r1 = ASM_FIQ_TMB; // 中斷源 _FIQ_TMB 定時(shí)器B, 快速中斷
JNE _FIQ_TMB; // 進(jìn)入_FIQ_TMB 定時(shí)器B
_FIQ_F_1024:
r1 = ASM_FIQ_F_1024; // 中斷源 ASM_FIQ_F_1024, 快速中斷
[ASM_Port_INT_Clear] = r1; // ASM_FIQ_F_1024清除中斷標(biāo)志
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _FIQ_call_F_1024;
JMP _FIQ_OVER;
_FIQ_TMA:
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _FIQ_call_TMA;
JMP _FIQ_OVER;
_FIQ_TMB:
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _FIQ_call_TMB;
_FIQ_OVER:
POP BP FROM [SP];
POP r1,r4 FROM [sp];
RETI;
_IRQ0:
PUSH r1,r4 TO [sp];
PUSH BP TO [SP];
r1 =ASM_IRQ0_F_1024;
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ0_call_F_1024;
POP BP FROM [SP];
POP r1,r4 FROM [sp]; // 恢復(fù)現(xiàn)場(chǎng)
RETI;
_IRQ1:
PUSH r1,r4 TO [sp];
PUSH BP TO [SP];
r1 =ASM_IRQ1_TMA;
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ1_call_TMA;
POP BP FROM [SP];
RETI;
_IRQ2:
PUSH r1,r4 TO [sp];
PUSH BP TO [SP];
r1 =ASM_IRQ2_TMB;
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ2_call_TMB;
POP BP FROM [SP];
RETI;
_IRQ3:
PUSH r1,r4 TO [sp];
PUSH BP TO [SP];
r1 =ASM_IRQ3_EXT1;
JNE _IRQ3_EXT1;
r1 =ASM_IRQ3_EXT2;
JNE _IRQ3_EXT2;
_IRQ3_KEY:
r1 = ASM_IRQ3_KEY;
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ3_call_KEY;
JMP _IRQ3_OVER;
_IRQ3_EXT1:
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ3_call_EXT1;
JMP _IRQ3_OVER;
_IRQ3_EXT2:
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ3_call_EXT2;
_IRQ3_OVER:
POP BP FROM [SP];
RETI;
_IRQ4:
PUSH r1,r4 TO [sp];
PUSH BP TO [SP];
r1 =ASM_IRQ4_4KHz;
JNE _IRQ4_4KHz;
r1 =ASM_IRQ4_2KHz;
JNE _IRQ4_2KHz;
_IRQ4_1KHz:
r1 = ASM_IRQ4_1KHz;
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ4_call_1KHz;
JMP _IRQ4_OVER;
_IRQ4_2KHz:
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ4_call_2KHz;
JMP _IRQ4_OVER;
_IRQ4_4KHz:
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ4_call_4KHz;
_IRQ4_OVER:
POP BP FROM [SP];
RETI;
_IRQ5:
PUSH r1,r4 TO [sp];
PUSH BP TO [SP];
r1 =ASM_IRQ5_4Hz;
JNE _IRQ5_4Hz;
_IRQ5_2Hz:
r1 = ASM_IRQ5_2Hz;
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> call _irq5_call_2hz;
jmp _IRQ5_over;
_IRQ5_4Hz:
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> call _irq5_call_4hz;
_IRQ5_over:
POP BP FROM [SP];
POP r1,r4 FROM [SP]; // 恢復(fù)現(xiàn)場(chǎng)
RETI;
_IRQ6:
PUSH r1,r4 TO [sp];
PUSH BP TO [SP];
r1 =ASM_IRQ6_TMB1;
JNE _IRQ6_TMB1;
_IRQ6_TMB2:
r1 = ASM_IRQ6_TMB2;
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ6_call_TMB2;
JMP _IRQ6_over;
_IRQ6_TMB1:
//C段中有書寫,并需要時(shí),去掉下行的//注釋,否則不要?jiǎng)?br /> //call _IRQ6_call_TMB1;
_IRQ6_over:
POP BP FROM [SP];
RETI;
