標題: CMD一些素材 [打印本頁]
作者: hujia    時間: 2015-2-18 01:02
標題: CMD一些素材
::從本體的skip=9行復制文本內容到一個新文件run2.cmd
for /f "useback skip=9 tokens=* " %%a in ("%~f0") do (echo %%a>>run2.cmd)
::判斷循環執行開始
set /a mix=1
set /a max=1000
set /a temp=1
:go1
if %temp%==%max% goto go2
  set /a temp=%temp%+1
  echo %time%
  goto go1
:go2
::判斷循環執行結束
::改ip
set ipd="192.168.1.25"      ::本機IP
set maskd="255.255.255.0"   ::子網掩碼
set gated="192.168.1.1"     ::網關
set dns1=202.103.44.150     ::主DNS
set dns2=202.103.24.68      ::副DNS
netsh interface ip set address  source=static addr=%ipd% mask=%maskd% gateway=%gated% gwmetric=1
netsh interface ip set dns  source=static addr=%dns1% register=primary
netsh interface ip add dns  addr=%dns2% index=2
