標(biāo)題: 無源蜂鳴器歌曲演奏 [打印本頁]
作者: hutians    時(shí)間: 2015-2-10 00:32
標(biāo)題: 無源蜂鳴器歌曲演奏
//此程序在硬件上調(diào)試通過//本程序的單片機(jī)晶振采用11.0592M
#include <reg51.h>
sbit      speaker=P1^2;
unsigned char timer0h,timer0l,time;
// 音階頻率表
code unsigned int  OctaveFreTab[]={// ffff-921600/f
//      do(1)    re(2)               m(3)            fa(4)                so(5)          la(6)          si(7)
// 低 262Hz      294        330        349             392            440       494
// 中_524Hz     587        659        698             784           880       988
// 高_(dá)1046Hz  1175      1318       1397           1568        1760      1976
//超高2092Hz  2351                 2636       2794        3136       3520      3952
262,  294,  330, 349, 392,440,494,
524,  587,  659, 698, 784,880,988,
1046, 1175, 1318,1397,1568,1760,1976,
2092, 2351, 2636,2794,3136,3520,3952,
        //世上只有媽媽好數(shù)據(jù)表
code unsigned char sszymmh[]={        6,2,3,      5,2,1,      3,2,2, 5,2,2, 1,3,2, 6,2,1, 5,2,1,
                                      6,2,4,      3,2,2,      5,2,1, 6,2,1, 5,2,2, 3,2,2, 1,2,1,
                                      6,1,1,      5,2,1,      3,2,1, 2,2,4, 2,2,3, 3,2,1, 5,2,2,
                                      5,2,1,      6,2,1,      3,2,2, 2,2,2, 1,2,4, 5,2,3, 3,2,1,
                                      2,2,1,      1,2,1,      6,1,1, 1,2,1, 5,1,6, 0,0,0
void delay(unsigned char t)                //
   unsigned char t1;
   unsigned long t2;
   for(t1=0;t1<t;t1++)
    for(t2=0;t2<8000;t2++)
   TR0=0;
void t0int() interrupt 1
TR0=0;
speaker=!speaker;
TH0=timer0h;
TL0=timer0l;
TR0=1;
void song()
TH0=timer0h;
TL0=timer0l;
TR0=1;
delay(time);
void main(void)
   unsigned char t1;
   unsigned long t2;
   for(t1=0;t1<t;t1++)
   TR0=0;
TR0=0;
speaker=!speaker;
TH0=timer0h;
TL0=timer0l;
TR0=1;
void song()
TH0=timer0h;
TL0=timer0l;
TR0=1;
delay(time);
void main(void)
unsigned char k,i;
unsigned int  f_temp;
TMOD=1; //置CT0定時(shí)工作方式1
EA=1;
ET0=1;//IE=0x82 //CPU開中斷,CT0開中斷
       i=0;
       while(i<100){         //音樂數(shù)組長度 ,唱完從頭再來
       k=sszymmh[i]+7*sszymmh[i+1]-1;
       f_temp =  921600/OctaveFreTab[k];
       f_temp  = 0xffff- f_temp  ;
       timer0h=f_temp  >>8;
       timer0l=f_temp&0xff;
       time=sszymmh[i+2];
       i=i+3;
       song();
           P3++;
作者: double-naze    時(shí)間: 2017-5-25 11:28
有圖嗎
作者: 呂馬璐    時(shí)間: 2018-12-25 10:14
可以播放其他音樂么
