標(biāo)題: Easyarm lpc2200外部中斷使用小結(jié) [打印本頁]
作者: liuda    時間: 2015-1-23 23:38
今天夠郁悶的,下午寫了個中斷程序玩玩,一直到晚上8:00才把它搞定,原因是我沒有開啟IRQ中斷,實(shí)在是郁悶,好在解決了,且又學(xué)到東西,先把程序附下,我就沒怎么注釋啦,反正要記得在InitStacks.s中要把系統(tǒng)管理模式堆棧處的代碼改為“MSR     CPSR_c, #0x5f”,即使能IRQ,否則永遠(yuǎn)也實(shí)現(xiàn)不了。有什么問題可以在下面留言。
#include "config.h"
#define        spi_shcp    0x00000010    //0.4
#define        spi_stcp    0x00000100    //0.8
#define        spi_q7        0x00000020    //0.5
#define        spi_ds        0x00000040    //0.6
void  delay(uint32  dly)
{  uint32  i;
   for(; dly>0; dly--)
      for(i=0; i<5000; i++);
void hc595send_data(uint8 data)
    uint8 i;
    IO0CLR = spi_stcp;
    for(i=0;i<8;i++)
        IO0CLR = spi_shcp;
        if((data&0x80)!=0)IO0SET = spi_ds;
            else IO0CLR = spi_ds;
        data <<= 1;
        IO0SET = spi_shcp;
    IO0SET = spi_stcp;
const uint8  DISP_TAB[16] = { 0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,
                              0x81,0x42,0x24,0x18,0x24,0x42,0x81,0x00 };
void __irq IRQ_Eint1(void)
    uint8 a;
    for(a=0;a<16;a++)
        hc595send_data(~DISP_TAB[a]);
        delay(5);
       EXTINT = 0x02;                // 清除EINT1中斷標(biāo)志
    VICVectAddr = 0;                    // 向量中斷結(jié)束
int main (void)
{// add user source code
    PINSEL0 = 0x20000000;
    IO0DIR = 0x00000150;//0001 1/0 101 0000
    EXTMODE = 0x00;
    EXTPOLAR = 0x02;
    VICIntSelect = 0x00000000;
    VICVectCntl0 = 0x20|15;
    VICVectAddr0 = (int)IRQ_Eint1;
    EXTINT = 0x02;
    VICIntEnable = 0x00008000;
    while(1);
    return 0;
