單片機獨立式鍵盤輸入實驗
liuda
2015-1-22 00:42
單片機獨立式鍵盤輸入實驗
電路:p2上面接8個按鍵 p1上面接8個led
#include<reg52.h>
uchar flag;
void delay(uint k)
uint data i,j;
for(i=0;i<k;i++){
for(j=0;j<121;j++)
uchar scan_key(void)
uchar temp;
temp=P2;
return temp;
void main(void)
P2=0xff;
if(P2!=0xff)
{delay(20);
P2=0xff;
if(P2!=0xff)flag=scan_key();
else flag=0;
switch(flag)
case 0xef:P1=0xfb;break;
case 0xdf:P1=0xf0;break;
case 0xbf:P1=0xc0;break;
case 0x7f:P1=0x00;break;
default:P1=0xff;break;
