標(biāo)題: 單片機(jī)簡易萬年歷實(shí)例 [打印本頁]
作者: liuda    時間: 2015-1-21 23:26
是用51hei單片機(jī)開發(fā)板 電路圖詳見:http://m.raoushi.com/f/51hei-5.pdf  的數(shù)碼管部分, 用2個74hc573 鎖存,p0口作為數(shù)據(jù)口 ,注意圖中要改一下p3.6和p3.7分別是段和位的鎖存端口.P2口上面是按鍵
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. //======================
  5. uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  6. uchar  ACT[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  7. uchar code WEEK_SEG7[8]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x7f};
  8. sbit D=P3^6;
  9. sbit V=P3^7;
  10. uchar deda,sec,min,hour,week=1;
  11. uchar cnt;
  12. //===========
  13. void init(void)
  14. {
  15. TMOD=0x11;
  16. TH0=-(50000/256);
  17. TL0=-(50000%256);
  18. ET0=1;
  19. TR0=1;
  20. TH1=-(1000/256);
  21. TL1=-(1000%256);
  22. ET1=1;
  23. TR1=1;
  24. EA=1;
  25. }
  26. //==========
  27. void time0(void) interrupt 1
  28. {
  29. TH0=-(50000/256);
  30. TL0=-(50000%256);
  31. deda++;
  32. }
  33. //============
  34. void time1(void) interrupt 3
  35. {
  36. TH1=-(1000/256);
  37. TL1=-(1000%256);
  38. if(++cnt>7)cnt=0;
  39. switch(cnt)
  40. {
  41. case 0:D=1;P0=SEG7[sec%10];D=0;P0=0xff;V=1;P0=ACT[5];V=0;break;
  42. case 1:D=1;P0=SEG7[sec/10];D=0;P0=0xff;V=1;P0=ACT[4];V=0;break;
  43. case 2:D=1;P0=SEG7[min%10];D=0;P0=0xff;V=1;P0=ACT[3];V=0;break;
  44. case 3:D=1;P0=SEG7[min/10];D=0;P0=0xff;V=1;P0=ACT[2];V=0;break;
  45. case 4:D=1;P0=SEG7[hour%10];D=0;P0=0xff;V=1;P0=ACT[1];V=0;break;
  46. case 5:D=1;P0=SEG7[hour/10];D=0;P0=0xff;V=1;P0=ACT[0];V=0;break;
  47. case 6:D=1;P0=0x00;D=0;P0=0xff;V=1;P0=0xff;V=0;break;
  48. case 7:D=1;P0=WEEK_SEG7[week];D=0;P0=0xff;V=1;P0=ACT[7];V=0;break;
  49. default:break;
  50.     }
  51. }
  52. //========
  53. void conv(void)
  54. {
  55. if(deda>=20){deda=0;sec++;}
  56. if(sec>=60){sec=0;min++;}
  57. if(min>=60){min=0;hour++;}
  58. if(hour>=24){hour=0;week++;}
  59. if(week>7){week=1;}
  60. }
  61. //===========
  62. void main(void)
  63. {
  64. init();
  65. while(1)
  66. {
  67. conv();
  68.     }
  69. }
