標題: CRC算法的研究 [打印本頁]
作者: shaonv    時間: 2015-1-1 21:37
標題: CRC算法的研究
  這兩天,由于用AVR對DS18B20讀取數據匹配需要效驗,在家里研究CRC算法,借鑒網上的一些方法,我把它終于被研究出來了,編寫成了一個C++類庫希望對大家有所幫助。經過試驗,成功!
直接調用CRC :: get(char* pData, int nLength, char bitWidth)就可返回CRC。
pData:需要效驗的數組首地址
nLength:數組的寬度,單位(字節)
bitWidth:需要生成的CRC編碼方式,7,8,16可選.
此函數基于IAR AVR設計
  1. __flash UINT crc16_REF[256]=
  2. {
  3.   0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50a5, 0x60c6, 0x70e7,
  4.   0x8108, 0x9129, 0xa14a, 0xb16b, 0xc18c, 0xd1ad, 0xe1ce, 0xf1ef,
  5.   0x1231, 0x0210, 0x3273, 0x2252, 0x52b5, 0x4294, 0x72f7, 0x62d6,
  6.   0x9339, 0x8318, 0xb37b, 0xa35a, 0xd3bd, 0xc39c, 0xf3ff, 0xe3de,
  7.   0x2462, 0x3443, 0x0420, 0x1401, 0x64e6, 0x74c7, 0x44a4, 0x5485,
  8.   0xa56a, 0xb54b, 0x8528, 0x9509, 0xe5ee, 0xf5cf, 0xc5ac, 0xd58d,
  9.   0x3653, 0x2672, 0x1611, 0x0630, 0x76d7, 0x66f6, 0x5695, 0x46b4,
  10.   0xb75b, 0xa77a, 0x9719, 0x8738, 0xf7df, 0xe7fe, 0xd79d, 0xc7bc,
  11.   0x48c4, 0x58e5, 0x6886, 0x78a7, 0x0840, 0x1861, 0x2802, 0x3823,
  12.   0xc9cc, 0xd9ed, 0xe98e, 0xf9af, 0x8948, 0x9969, 0xa90a, 0xb92b,
  13.   0x5af5, 0x4ad4, 0x7ab7, 0x6a96, 0x1a71, 0x0a50, 0x3a33, 0x2a12,
  14.   0xdbfd, 0xcbdc, 0xfbbf, 0xeb9e, 0x9b79, 0x8b58, 0xbb3b, 0xab1a,
  15.   0x6ca6, 0x7c87, 0x4ce4, 0x5cc5, 0x2c22, 0x3c03, 0x0c60, 0x1c41,
  16.   0xedae, 0xfd8f, 0xcdec, 0xddcd, 0xad2a, 0xbd0b, 0x8d68, 0x9d49,
  17.   0x7e97, 0x6eb6, 0x5ed5, 0x4ef4, 0x3e13, 0x2e32, 0x1e51, 0x0e70,
  18.   0xff9f, 0xefbe, 0xdfdd, 0xcffc, 0xbf1b, 0xaf3a, 0x9f59, 0x8f78,
  19.   0x9188, 0x81a9, 0xb1ca, 0xa1eb, 0xd10c, 0xc12d, 0xf14e, 0xe16f,
  20.   0x1080, 0x00a1, 0x30c2, 0x20e3, 0x5004, 0x4025, 0x7046, 0x6067,
  21.   0x83b9, 0x9398, 0xa3fb, 0xb3da, 0xc33d, 0xd31c, 0xe37f, 0xf35e,
  22.   0x02b1, 0x1290, 0x22f3, 0x32d2, 0x4235, 0x5214, 0x6277, 0x7256,
  23.   0xb5ea, 0xa5cb, 0x95a8, 0x8589, 0xf56e, 0xe54f, 0xd52c, 0xc50d,
  24.   0x34e2, 0x24c3, 0x14a0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405,
  25.   0xa7db, 0xb7fa, 0x8799, 0x97b8, 0xe75f, 0xf77e, 0xc71d, 0xd73c,
  26.   0x26d3, 0x36f2, 0x0691, 0x16b0, 0x6657, 0x7676, 0x4615, 0x5634,
  27.   0xd94c, 0xc96d, 0xf90e, 0xe92f, 0x99c8, 0x89e9, 0xb98a, 0xa9ab,
  28.   0x5844, 0x4865, 0x7806, 0x6827, 0x18c0, 0x08e1, 0x3882, 0x28a3,
  29.   0xcb7d, 0xdb5c, 0xeb3f, 0xfb1e, 0x8bf9, 0x9bd8, 0xabbb, 0xbb9a,
  30.   0x4a75, 0x5a54, 0x6a37, 0x7a16, 0x0af1, 0x1ad0, 0x2ab3, 0x3a92,
  31.   0xfd2e, 0xed0f, 0xdd6c, 0xcd4d, 0xbdaa, 0xad8b, 0x9de8, 0x8dc9,
  32.   0x7c26, 0x6c07, 0x5c64, 0x4c45, 0x3ca2, 0x2c83, 0x1ce0, 0x0cc1,
  33.   0xef1f, 0xff3e, 0xcf5d, 0xdf7c, 0xaf9b, 0xbfba, 0x8fd9, 0x9ff8,
  34.   0x6e17, 0x7e36, 0x4e55, 0x5e74, 0x2e93, 0x3eb2, 0x0ed1, 0x1ef0
  35. };
  36. class CRC
  37. {
  38. public:
  39.   UINT get(char *pData, int nLength , char bitWidth = 8)
  40.   {
  41.     switch(bitWidth)
  42.     {
  43.     case 7:
  44.       return getCRC8(pData , nLength);
  45.     case 8:
  46.       return getCRC8(pData , nLength);
  47.     case 16:
  48.       return getCRC16(pData , nLength);
  49.     }
  50.     return getCRC8(pData , nLength);
  51.   }
  52.   UINT getCRC7(char* pData,int nLength)
  53.   {
  54.     UINT i;
  55.     UINT crc = 0x0000;
  56.     while(nLength--)
  57.     {
  58.       for(i = 0x80; i != 0; i /= 2)
  59.       {
  60.         if((crc & 0x40) != 0)
  61.         {
  62.           crc *= 2;
  63.           crc ^= 0x09;
  64.         }
  65.         else
  66.         {
  67.           crc *= 2;
  68.         }
  69.         if((*pData & i) != 0)
  70.         {
  71.           crc ^= 0x09;
  72.         }
  73.       }
  74.       pData++;
  75.     }
  76.     crc = crc & 0x7f;
  77.     crc = crc << 1;
  78.     crc = crc | 0x01;
  79.     return(crc);
  80.   }
  81.   UINT getCRC8(char* pData, int nLength)
  82.   {
  83.     UINT crc,  j;
  84.     crc = 0;
  85.     for (j = 0; j < nLength; j++)
  86.     {
  87.       char x = *pData++;
  88.       for (char i = 0 ; i < 8 ; i++)
  89.       {
  90.         if (((crc & 0x01) ^ (x & 0x01)))
  91.         {
  92.           crc ^= 0x18;
  93.           crc >>= 1;
  94.           crc |= 0x80;
  95.         }
  96.         else
  97.           crc >>= 1;
  98.         x >>= 1;
  99.       }
  100.     }
  101.     return crc;
  102.   }
  103.   UINT getCRC16(char* pData, int nLength)
  104.   {
  105.     UINT crc = 0x0000;    // 初始化
  106.     unsigned char i;
  107.     while(nLength--)
  108.     {
  109.       i = (unsigned char) (crc / 256);
  110.       crc <<= 8;
  111.       crc ^= crc16_REF[i ^ *pData];
  112.       pData++;
  113.     }
  114.     return crc;
  115. }
  116. };
