數(shù)據(jù)類型轉(zhuǎn)換unsigned int long char
daniu
2014-12-26 21:12
任務:怎樣把一個unsigned int(unsinged long)轉(zhuǎn)換成相應的unsigned char,然后從串口發(fā)出?
例如:
extern void put_uchar(unsigned char); //往串口發(fā)送一個無符號字節(jié)數(shù)
unsigned long a;
a=0x12345678;
put_uchar(((unsigned char *)&a)[0]);//發(fā)出0x78
put_uchar(((unsigned char *)&a)[1]);//發(fā)出0x56
put_uchar(((unsigned char *)&a)[2]);//發(fā)出0x34
put_uchar(((unsigned char *)&a)[3]);//發(fā)出0x12
還有其它方法,但我想這種方法編譯效率最高。
goer.lu
2015-6-26 10:14
那問下如何將unsigned char 轉(zhuǎn)換成unsigned int 呢,例如x = MMA845x_readbyte(OUT_X_MSB_REG);
輸出的X=2556,我需要將X除以256后輸出,可是除以以后輸出就是0了,怎么解決啊
