DS18B20溫度測試
heicad
2014-10-24 14:42
DS18B20溫度測試
#include"reg51.h"
#define led P1
#define ledw P2
uchar ledtab[]={0xc0,0xf9,0xa4, 0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
sbit dq=P3^7 ;
uchar delay,f;
void dela(uchar i) //5us t=5+i*2
while(--i);
void ds18b20_reset()
dq=1;
dq=0;
delay=250; //540us延時,當delay=1時延時為2us ,T=2*x
while(--delay);
dq=1;
delay=25;
while(--delay);
while(dq==0)
delay=220;
while(--delay);
if(dq==1)
break;
delay=150;
while(--delay);
break;
void ds18b20_write(uchar dat)
uchar i=0;
for(i=0;i<8;i++)
dq=1;
dq=0;
delay=3;
while(--delay);
dq=dat&0x01;
delay=35;
while(--delay);
dq=1;
dat=dat>>1;
uchar ds18b20_read()
uchar i=0,m=0;
for(i=0;i<8;i++)
//m>>=1
dq=1;
dq=0;
delay=4;
while(--delay);
dq=1;
delay=4;
while(--delay);
if(dq==1)
m|=0x01<<i;
//m=m|0x80;
delay=25;
while(--delay);
dq=1;
delay=1;
while(--delay);
return m;
uchar ds18b20_temp()
uchar temp=0,temph=0,templ=0,k=0;
ds18b20_reset();
ds18b20_write(0xcc);
ds18b20_write(0x44);
ds18b20_reset();
ds18b20_write(0xbe);
templ=ds18b20_read();
temph=ds18b20_read();
if((temph&0xf80)!=0)
f=1;
templ=~templ;
temph=~temph;
k=templ+1;
templ=k;
if(templ>0xff)
temph++;
f=0;
templ=templ>>4;
temph=temph<<4;
temp=templ|temph;
return temp;
uchar a=0,b=0,c=0,temp=0;
temp=ds18b20_temp();
a=temp/100;
b=temp0/10;
c=temp;
if(f==1)
led=0xbf;
ledw=1;
dela(5000);
ledw=0;
dela(600);
led=ledtab[c];
ledw=8;
dela(5000);
ledw=0;
dela(600) ;
led=ledtab
ledw=4;
dela(5000);
ledw=0;
dela(600) ;
led=ledtab[a];
ledw=2;
dela(5000);
ledw=0;
dela(600) ;
51hei電控2112312
2014-12-21 04:46
很好,正需要
hhtl
2016-4-18 17:02
坑爹啊,原理圖都不見
15890155710
2017-5-27 12:58
仿真顯示不正常啊?
