標(biāo)題: 基于stc89c52的4位數(shù)碼管電子鐘 [打印本頁(yè)]
作者: heicad    時(shí)間: 2014-10-21 01:45
/*                                              TabLee                                                 */
#include<reg52.h>
#define uchar unsigned char;
#define uint unsigned int;
uchar position;
uchar tt;
uchar second;
uchar minute;
uchar hour;
uchar code table[]={0xc0,0xf9,0xa4,0x99,0x92,0x82,0xf8,0x80,0x90};
sbit smg_q=P1^0;
sbit smg_b=P1^1;
sbit smg_s=P1^2;
sbit smg_g=P1^3;
sbit key1=P3^7;
sbit key2=P3^6;
sbit key3=P3^5;
sbit key4=P3^4;
void keyscan();
void display(unsigned char hour,unsigned char minute);
void delay(unsigned int timer);
void init();
init();
if(tt==20)
tt=0;
second++;
if(second==60)
second=0;
minute++;
if(minute==60)
minute=0;
hour++;
if(hour==24)
hour=0;
display(hour,minute);
delay(1);
void keyscan()
if(key1==0)
TR0=0;
hour++;
if(hour==24)
hour=0;
delay(200);
TR0=1;
if(key2==0)
TR0=0;
hour--;
if(hour<0)
hour=23;
delay(200);
TR0=1;
if(key3==0)
TR0=0;
minute++;
if(minute==60)
minute=0;
delay(200);
TR0=1;
if(key4==0)
TR0=0;
minute--;
if(minute<0)
minute=59;
delay(200);
TR0=1;
void init()
tt=0;
position=0;
second=0;
minute=0;
hour=0;
smg_q=1;
smg_b=1;
smg_s=1;
smg_g=1;
key1=1;
key2=1;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void t0() interrupt 1
tt++;
P0=0xFF;
switch(position)
case 0:
smg_g=1;
smg_q=0;
P0=table[hour/10];
break;
case 1:
smg_q=1;
smg_b=0;
P0=table[hour%10];
if(tt>=10)
P0&=0x7f;
break;
case 2:
smg_b=1;
smg_s=0;
P0=table[minute/10];
break;
case 3:
smg_s=1;
smg_g=0;
P0=table[minute%10];
break;
position++;
if(position>3)
position=0;
void delay(unsigned int time)
unsigned int x,y;
for(x=time;x>0;x++)
for(y=110;y>0;y--);
作者: zxj366    時(shí)間: 2014-10-24 21:52
太湊合了,給點(diǎn)說(shuō)明或者圖文
作者: 星星一眨眼    時(shí)間: 2015-5-1 13:31
有電路圖嗎我想制作個(gè)時(shí)鐘
作者: 萬(wàn)叢草111    時(shí)間: 2015-5-11 13:55
樓主真好
作者: 萬(wàn)叢草111    時(shí)間: 2015-5-11 13:56
謝謝樓主的分享
作者: GG-路人乙    時(shí)間: 2015-5-17 10:36
謝謝樓主的分享
作者: around    時(shí)間: 2015-5-17 11:17
有電路圖嗎
作者: 楊芯芯    時(shí)間: 2015-7-19 11:45
不好看懂啊,可以再詳細(xì)點(diǎn)嗎?
作者: 素顏い如雪    時(shí)間: 2015-12-1 21:16
求電路圖
作者: gaolan2010    時(shí)間: 2015-12-7 20:46
程序有個(gè)標(biāo)注就好了
作者: 拼命四郎    時(shí)間: 2015-12-21 23:03
我和樓主的思路大體相同,但是在調(diào)時(shí)間的時(shí)候某一位是怎么閃爍的呢。這個(gè)程序怎么寫(xiě)。沒(méi)有閃爍不確定調(diào)哪一位啊
作者: tranhunga    時(shí)間: 2017-5-4 15:30
求電路圖
作者: tranhunga    時(shí)間: 2017-5-4 15:40
作者: miu    時(shí)間: 2017-5-7 16:54
謝謝樓主的分享
作者: NEC_HaoZ    時(shí)間: 2017-5-7 17:35
樓主分享一個(gè)電路圖啊
