標(biāo)題: VHDL除法器宏模塊及編程調(diào)用 [打印本頁(yè)]
作者: heicad    時(shí)間: 2014-10-17 18:51
1.在要調(diào)用項(xiàng)目的文件夾創(chuàng)建除法器宏模塊
    按下圖設(shè)置和添加宏模塊
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
Use ieee.std_logic_arith.all;
Entity dddd is
Port(a:in std_logic_vector(6 downto 0);
     b:in std_logic_vector(3 downto 0);
   x:out std_logic_vector(6 downto 0);
   y:out std_logic_vector(3 downto 0));
end ;
architecture dd of dddd is
--------定義調(diào)用宏模塊
component chufa is
port(numer:in std_logic_vector(6 downto 0);
     denom:in std_logic_vector(3 downto 0);
   quotient:out std_logic_vector(6 downto 0);
     remain:out std_logic_vector(3 downto 0) );
end component;
-----------------結(jié)束定義
begin
U:chufa port map(a,b,x,y);  -----調(diào)用
end;
