12864在單片機(jī)上顯示圖片
[打印本頁(yè)]
NB沒(méi)B
時(shí)間:
2014-8-28 16:06
12864在單片機(jī)上顯示圖片
#include<stc12.h>
#include<intrins.h>
#define LCD_data P0
sbit LCD_RS=P1^0; // 數(shù)據(jù)/命令選擇端
sbit LCD_RW=P1^1; // 讀寫(xiě)選擇端
sbit LCD_EN=P1^2; // 使能信號(hào)
sbit LCD_PSB=P1^6; // 并/串選擇
uchar code table[64][16]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFE,0xDF,0x00,0x1C,0x0E,0x1D,0xFE,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFE,0xBF,0xF5,0xFD,0xEF,0xD0,0x21,0xB7,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFD,0x81,0x80,0x3C,0x0E,0xD7,0xBD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xF9,0x7D,0xB5,0xBD,0xEE,0xD0,0x20,0x03,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xF4,0xEF,0x80,0x3C,0x0E,0xD7,0xFD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFD,0xAB,0xF7,0xFF,0xFE,0x10,0x3D,0x37,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFD,0xAB,0x00,0x00,0x03,0xD2,0xB8,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFD,0x6D,0xEE,0xFB,0x7F,0x90,0x25,0xDF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFC,0xED,0xC5,0xF9,0x06,0x4A,0xBD,0x9B,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFD,0xEF,0xF8,0xF6,0x7F,0xDA,0xBC,0x6B,0x7B,0xEF,0xBD,0xF8,0x00,0x00,0x00,
0xFF,0xFD,0x8F,0x07,0x2F,0x03,0x1F,0x31,0xF3,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
0xEA,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFD,0xFF,0xF8,0x00,0x00,0x00,
0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x3F,0xDC,0xFF,0xF8,0x00,0x00,0x00,
0xC0,0x2F,0xFF,0xFF,0xF3,0xFF,0xFF,0xFF,0xFF,0xBD,0x8C,0xFF,0xF8,0x00,0x00,0x00,
0xF1,0xFF,0xFF,0xFF,0xC7,0xEF,0xFF,0xFC,0xFF,0xB9,0x04,0xFF,0xF8,0x00,0x00,0x00,
0xE8,0xFF,0xFF,0xFF,0x07,0x1F,0x7F,0xFF,0x3F,0xF0,0x20,0xFF,0xF8,0x00,0x00,0x00,
0xDB,0x7F,0xFF,0xFC,0x0C,0x1C,0x7F,0x7F,0xCF,0xEE,0x71,0xFF,0xF8,0x00,0x00,0x00,
0xFB,0xF7,0xE3,0xF8,0x00,0x10,0xDF,0x8F,0xF3,0xFE,0x7D,0xFF,0xF8,0x00,0x00,0x00,
0xFF,0xFB,0xC1,0xF0,0x00,0x00,0x97,0xC1,0xF8,0xFE,0xFF,0xEF,0xF8,0x00,0x00,0x00,
0xFB,0xEB,0x98,0xE0,0x00,0x39,0x10,0xF0,0x3C,0x3F,0xFF,0xBF,0xF8,0x00,0x00,0x00,
0xFF,0xF1,0xA4,0xE0,0x00,0x04,0x10,0x1C,0x06,0x1F,0x8F,0x97,0xF8,0x00,0x00,0x00,
0xFF,0xD1,0x8A,0xC0,0x00,0x00,0x30,0x00,0x01,0x0F,0x07,0x8F,0xF8,0x00,0x00,0x00,
0xFF,0xE0,0x8A,0x00,0x00,0x00,0x30,0x38,0x00,0x06,0x33,0x1B,0xF8,0x00,0x00,0x00,
0xFF,0xA0,0x44,0x00,0x00,0x00,0x50,0x40,0x00,0x06,0x4B,0x17,0xF8,0x00,0x00,0x00,
0xFF,0xC0,0x60,0x00,0x0F,0xC0,0x48,0x00,0x00,0x02,0xA2,0x05,0xF8,0x00,0x00,0x00,
0xFF,0x40,0x70,0x00,0x3F,0xE0,0x88,0x00,0x00,0x00,0xA2,0x03,0xF8,0x00,0x00,0x00,
0xFF,0x80,0xF8,0x00,0x00,0xF1,0x04,0x07,0xE0,0x00,0x44,0x01,0xF8,0x00,0x00,0x00,
0xFE,0x81,0xE8,0x00,0x01,0xC2,0x04,0x4F,0xF8,0x00,0x0F,0x03,0xF8,0x00,0x00,0x00,
0xFF,0x00,0x08,0x00,0x01,0x84,0x02,0x3E,0x00,0x00,0x1F,0x82,0xF8,0x00,0x00,0x00,
0xFD,0x00,0x10,0x00,0x00,0x88,0x01,0x06,0x00,0x00,0x10,0x41,0xF8,0x00,0x00,0x00,
0xFE,0x01,0xE0,0x01,0x13,0x08,0x00,0x87,0x00,0x00,0x10,0x01,0xB8,0x00,0x00,0x00,
0xFF,0x06,0x20,0x00,0x88,0x10,0x00,0x43,0x00,0x00,0x10,0x01,0x18,0x00,0x00,0x00,
0xFD,0x0A,0x10,0x01,0x44,0x10,0x00,0x22,0x00,0x00,0x18,0x01,0xB8,0x00,0x00,0x00,
0xF8,0x11,0x10,0x00,0x80,0x10,0x00,0x21,0x91,0x00,0x14,0x01,0xF8,0x00,0x00,0x00,
0xFC,0x10,0x88,0x70,0x00,0x10,0x00,0x10,0x22,0x03,0xE0,0x00,0xB8,0x00,0x00,0x00,
0xFE,0x20,0x84,0x4C,0x00,0x20,0x00,0x10,0x45,0x05,0x31,0x00,0xF8,0x00,0x00,0x00,
0xF4,0x20,0x43,0x8B,0x80,0xC0,0x00,0x10,0x02,0x08,0x88,0x80,0xB8,0x00,0x00,0x00,
0xFC,0x20,0x40,0x08,0xFF,0x00,0x00,0x10,0x00,0x18,0x40,0x40,0x78,0x00,0x00,0x00,
0xF6,0x20,0x40,0x08,0x80,0x00,0x00,0x08,0x00,0x68,0x40,0x00,0xD8,0x00,0x00,0x00,
0xFC,0x20,0x40,0x08,0x80,0x00,0x00,0x06,0x03,0x90,0x20,0x20,0x68,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void delay(uint z) // 延時(shí)函數(shù)
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<110;y++);
//寫(xiě)指令數(shù)據(jù)到LCD
void write_cmd(uchar cmd)
LCD_RS=0;
LCD_RW=0;
LCD_EN=0;
P0=cmd;
delay(5);
LCD_EN=1;
delay(5);
LCD_EN=0;
//寫(xiě)顯示數(shù)據(jù)到LCD
void write_dat(uchar dat)
LCD_RS=1;
LCD_RW=0;
LCD_EN=0;
P0=dat;
delay(5);
LCD_EN=1;
delay(5);
LCD_EN=0;
//12864初始化
void lcd_init()//12964初始化
LCD_PSB=1; //并口模式
write_cmd(0x34); //基本指令操作
delay(5);
write_cmd(0x0c); //顯示開(kāi),光標(biāo)關(guān)
delay(5);
write_cmd(0x01); //消除所有顯示
delay(5);
//主函數(shù)
main()
uchar i,j;
delay(10);
lcd_init(); //初始化
for(i=0;i<32;i++)
write_cmd(0x80+i);
write_cmd(0x80);
for(j=0;j<16;j++)
write_dat(table[i][j]);
for(i=0;i<32;i++)
write_cmd(0x80+i);
write_cmd(0x88);
for(j=0;j<16;j++)
write_dat(table[i+32][j]);
write_cmd(0x36); //打開(kāi)繪圖模式
write_cmd(0x30); //基本操作模式
while(1); //沒(méi)有的話 會(huì)一直閃爍 甚至不顯示
hujia
時(shí)間:
2014-8-28 16:49
很好 正好需要
NB沒(méi)B
時(shí)間:
2014-8-28 17:10
hujia 發(fā)表于 2014-8-28 16:49
很好 正好需要
給點(diǎn)評(píng)分唄
淺墨畫(huà)青梅
時(shí)間:
2014-8-29 10:20
有完整的電路圖就好了
aaaaabbbbb
時(shí)間:
2015-4-22 10:44
謝謝樓主
JY腳印
時(shí)間:
2015-5-1 15:12
觀摩觀摩!!!!!!!!!!
無(wú)悔青春
時(shí)間:
2015-5-1 17:46
不錯(cuò)
念念念念念念
時(shí)間:
2015-5-7 08:59
觀摩觀摩!!!!!!!!!!
232046
時(shí)間:
2015-5-12 17:20
小白新手,沒(méi)想到這么簡(jiǎn)單
yangkai3bu
時(shí)間:
2015-5-12 17:32
仔細(xì)看看
新洛克
時(shí)間:
2015-5-12 20:57
學(xué)習(xí)一下
海闊天空2015
時(shí)間:
2015-7-4 18:36
有交流才有進(jìn)步,謝謝樓主分享資料
海闊天空2015
時(shí)間:
2015-7-4 18:37
這個(gè)程序沒(méi)有使用指針,用數(shù)組顯示圖片很慢
xiangshu
時(shí)間:
2015-7-15 20:13
很好 正好需要
mmfkl
時(shí)間:
2015-7-15 20:30
不錯(cuò)不錯(cuò)!!!
孫曉云
時(shí)間:
2015-7-17 11:14
好像要
weijiaji
時(shí)間:
2015-7-17 11:23
看看學(xué)學(xué)
1176658950
時(shí)間:
2015-7-17 23:09
看這么多數(shù),看花了
cuizhihao100
時(shí)間:
2015-7-20 07:28
我也正在學(xué)12864
根碩的爸爸
時(shí)間:
2015-7-20 09:55
看下怎么實(shí)現(xiàn)顯示圖片,學(xué)習(xí)了
騰飛的龍
時(shí)間:
2015-7-29 13:15
謝謝分享,值得尊敬!
1678
時(shí)間:
2015-8-9 21:32
這是什么啊這么主函數(shù)都嗎沒(méi)有
ville95
時(shí)間:
2015-8-10 09:26
謝謝樓主了哈
lth0320
時(shí)間:
2015-8-23 15:24
要是能串口發(fā)送就好了
5151大家好
時(shí)間:
2015-8-23 19:23
應(yīng)該不錯(cuò) 欣賞下
yamglang
時(shí)間:
2015-10-12 01:06
51Hei(51黑)論壇有你更精彩
js很忙
時(shí)間:
2015-11-7 00:47
看看如何先
血一
時(shí)間:
2015-11-8 10:55
有電路圖嗎,,,,,
pandslu
時(shí)間:
2015-11-11 22:26
很好 看看
東方云裳
時(shí)間:
2015-11-11 23:16
學(xué)習(xí)一下,謝謝啦
fyang
時(shí)間:
2015-11-12 21:59
看看是什么圖片
騰飛的龍
時(shí)間:
2015-11-13 10:36
不是什么圖形啊
jack-R
時(shí)間:
2015-11-13 12:48
看看,初學(xué)者,向前輩學(xué)習(xí)
51道
時(shí)間:
2015-12-1 01:48
LIAOZHENRU
時(shí)間:
2015-12-1 10:46
很不錯(cuò)的
風(fēng)翼
時(shí)間:
2015-12-9 20:00
很好 正好需要 謝了
好久不見(jiàn)597
時(shí)間:
2015-12-20 11:00
看看啊 我的12864怎么都不顯示
好久不見(jiàn)597
時(shí)間:
2015-12-20 11:01
看看啊 我的12864怎么都不顯示
永遠(yuǎn)的王同學(xué)
時(shí)間:
2015-12-22 23:30
用C8051F很快就會(huì)好吧?但是89C51。。。慢了點(diǎn)兒吧?
455861916
時(shí)間:
2016-1-3 23:37
謝謝樓主
g782373711
時(shí)間:
2016-1-4 15:50
好好學(xué)習(xí) 天天向上
HAIMING
時(shí)間:
2016-1-9 18:21
不錯(cuò)學(xué)習(xí)了
HAIMING
時(shí)間:
2016-1-9 18:22
很好 正好需要
不錯(cuò),
qq270097653
時(shí)間:
2016-1-11 13:30
正在看這方便資料 謝謝分享
linx
時(shí)間:
2016-1-14 14:45
圍觀。我要程序
南天白云
時(shí)間:
2016-1-14 17:07
樓主有電路圖嗎?液晶屏是什么型號(hào)?
狼牙小帥
時(shí)間:
2016-2-17 12:43
12864顯示圖片時(shí)除了把圖片改為bmp格式,大小像素應(yīng)該怎么改呢
迷戀520冬天
時(shí)間:
2016-2-27 13:09
看看程序
麒麟科技
時(shí)間:
2016-3-4 21:13
看看。學(xué)習(xí)下。。。
koenlee93
時(shí)間:
2016-3-29 16:45
謝謝分享了
哈哈哈1
時(shí)間:
2016-4-29 00:12
要是能有電路圖就好了
肖邦的夜曲
時(shí)間:
2016-4-29 17:23
學(xué)習(xí)了
zxc5230
時(shí)間:
2016-4-30 23:04
為什么我用那個(gè)轉(zhuǎn)換代碼的腳本轉(zhuǎn)換后沒(méi)辦法顯示出來(lái)
missmb
時(shí)間:
2016-5-1 00:27
不錯(cuò),正在學(xué)習(xí)來(lái)看看
gxzhi
時(shí)間:
2016-5-1 01:27
謝謝樓主
greatfun2006
時(shí)間:
2016-5-1 16:37
感謝分享!!!!
hjsbs2
時(shí)間:
2016-5-1 22:33
我要看隱藏內(nèi)容
salewy
時(shí)間:
2016-5-2 21:44
12864在單片機(jī)上顯示圖片
MUCV
時(shí)間:
2016-5-3 00:03
剛好要學(xué)12864
小珂
時(shí)間:
2016-5-3 23:39
來(lái)吧.................
a1298703610
時(shí)間:
2016-9-12 11:47
看看是不是需要的
hjyanbin
時(shí)間:
2016-9-25 13:37
正需要這個(gè)啊
2gy88yhs
時(shí)間:
2016-10-21 21:22
很好 正好需要
5551
時(shí)間:
2016-10-30 18:16
1231231231312312313
5551
時(shí)間:
2016-10-30 18:16
不錯(cuò)不錯(cuò)!!!
abc659990927
時(shí)間:
2016-10-31 18:29
666要是有電路圖就更好了
long2022
時(shí)間:
2016-11-1 22:01
看看......
nishiwodeweiyi
時(shí)間:
2016-11-2 19:33
期待,希望能幫到我
nishiwodeweiyi
時(shí)間:
2016-11-2 19:34
感覺(jué)不錯(cuò) 希望能幫助我
ems
時(shí)間:
2016-11-2 20:33
看一下有再說(shuō)
