標題: IIC存儲芯片的訪問 24c02 24c16 [打印本頁]
作者: wangyin    時間: 2014-8-10 12:30
#include
__CONFIG(0x0012);
#define scl RA3
#define sda RA4
void delay_nop()
   NOP();NOP();NOP();NOP();NOP();
void start()
  TRISA4=0;
  sda=1;
  delay_nop();
  scl=1;
  delay_nop();
  sda=0;
  delay_nop();
void stop()
  TRISA4=0;
  sda=0;
  delay_nop();
  scl=1;
  delay_nop();
  sda=1;
  delay_nop();
void respons()
  unsigned int i;
  TRISA4=1;
  scl=1;
  delay_nop();
  while((sda==1)&&(i<400)) i++;
  scl=0;
  delay_nop();
void init_24c16()
  ADCON1=0X07;
  TRISA3=0;
  TRISA4=0;
  sda=1;
  delay_nop();
  scl=1;
  delay_nop();
void write_byte(unsigned char date)
  unsigned char i,temp,temp1;
  temp=date;
  TRISA4=0;
  for(i=0;i<8;i++)
scl=0;
delay_nop();
temp1=temp&0x80;
if(temp1!=0) sda=1;
else sda=0;
temp=temp<<1;
delay_nop();
scl=1;
delay_nop();
  scl=0;
  delay_nop();
  sda=1;
  delay_nop();
unsigned char read_byte()
  unsigned char i,k;
  TRISA4=0;
  scl=0;
  delay_nop();
  sda=1;
  delay_nop();
  for(i=0;i<8;i++)
TRISA4=1;
scl=1;
delay_nop();
k=(k<<1)|sda;
scl=0;
delay_nop();
  return k;
void write_add(unsigned int address,unsigned chardate)
  unsigned char MSbyte,LSbyte;
  MSbyte=address/256;
  LSbyte=address%6;
  start();
write_byte(0xa0+(MSbyte<<1));
  respons();
  write_byte(LSbyte);
  respons();
  write_byte(date);
  respons();
  stop();
unsigned char read_add(unsigned int address)
  unsigned char date;
  MSbyte=address/256;
  LSbyte=address%6;
  start();
  respons();
  write_byte(LSbyte);
  respons();
  start();
  write_byte(0xa1+(MSbyte<<1));
  respons();
  date=read_byte();
  stop();
  return date;
作者: k1200    時間: 2014-8-23 19:41
一看就是很專業的樣子,新手只能慢慢努力了
作者: mqwu    時間: 2014-9-18 17:06
有硬件I2C不用,為什么要用軟件I2C呢?硬件I2C執行效率更高, 代碼更優化。
