單片機自動澆花器程序和仿真圖
12345qwe1
2025-1-8 13:53
單片機自動澆花器程序和仿真圖
(82.08 KB, 下載次數: 0)
2025-1-8 13:53 上傳
#include<reg51.h>
sbit ad_cs=P1^3; //ADC0832????
sbit ad_clk=P1^0;
sbit ad_dat=P1^1;
sbit lcd_rs=P2^7; //LCD1602????
sbit lcd_e=P2^6;
sbit key1=P1^4; //????
sbit key2=P3^2;
sbit key3=P3^3;
sbit relay=P1^6; //???
bit flag=1; //??????
bit flag_motor=1; //?????,???????
bit flag_jia=0;
bit flag_jian=0;
uchar Hum_H=60; //?????,???????
uchar Hum_L=30; //?????,???????
uchar num=0;
/********************????1ms*****************
void delay_ms(uint a)
uint i;
while(a--)
for(i=0;i<125;i++);
/*******************????50us******************/
void delay_50us(uint a)
uint i;
while(a--)
for(i=0;i<19;i++);
/*******************ADC??******************/
uchar read_ad(uchar channel)
uchar i;
uchar dat1,dat2;
ad_clk=0;
ad_cs=0;
ad_dat=1;
ad_clk=1;
ad_clk=0; //????
ad_dat=1;
ad_clk=1;
ad_clk=0; //???????
ad_dat=channel;//0????0,1????1
ad_clk=1;
ad_clk=0;
ad_dat=1;
for(i=0;i<8;++i)
ad_clk=1;
ad_clk=0;
dat1=dat1<<1;
if(ad_dat)
dat1|=0x01;
for(i=0;i<8;i++)
dat2=dat2>>1;
if(ad_dat)
dat2|=0x80;
ad_clk=1;
ad_clk=0;
ad_cs=1;
return (dat1==dat2)?dat1:0;
/*******************LCD1602???******************/
void write_com(uchar com) //???
lcd_e=0;
lcd_rs=0;
P0=com;
delay_50us(10);
lcd_e=1;
delay_50us(10);
lcd_e=0;
void write_data(uchar dat) //???
lcd_e=0;
lcd_rs=1;
P0=dat;
delay_50us(10);
lcd_e=1;
delay_50us(10);
lcd_e=0;
void init_lcd1602() //lcd ???
delay_50us(300);
write_com(0x38);
delay_50us(100);
write_com(0x38);
delay_50us(100);
write_com(0x38);
write_com(0x38);
write_com(0x08);
write_com(0x01);
write_com(0x06);
write_com(0x0c);
void display_shu(uchar add,uchar dat) //????
uchar l,m;
// k=dat/100;
l=dat%100/10;
m=dat%10;
write_com(0x80+add);
// write_data(k+0x30);
write_data(l+0x30);
write_data(m+0x30);
void display_string(uchar add,uchar *dat) //?????
uchar i;
while(dat!=0&&(*dat!='\0')&&i<16)
write_data(*dat);
dat++;
i++;
if(i==15) i=0;
EA=1; //????
EX0=1; //?????0
EX1=1; //?????1
IT0=0; //????0????????
IT1=0; //????1????????
init_lcd1602();
display_string(0,"Hum: %"); //?????????
display_string(11,"H: %"); //??????????
display_string(0x40,"Mode:"); //??????
display_string(0x40+11,"L: %"); //??????????
uchar i;
i=100-read_ad(0)*0.39;
display_shu(4,i);
display_shu(13,Hum_H);
display_shu(0x40+13,Hum_L);
if(key1==0)
delay_50us(100);
if(key1==0)
while(!key1);
num++;
if(num>2) num=0;
switch (num) //???????????????????
case 0:flag=~flag;
flag_jia=0;
flag_jian=0;
//write_com(0x80+0x40);
//write_com(0x0f);
break;
case 1://write_com(0x80+9);
//write_com(0x0f);
//delay_50us(1000);
//write_com(0x0c);
flag_jia=1;
flag_jian=0;
break;
case 2://write_com(0x80+0x40+9);
//write_com(0x0f);
//delay_50us(1000);
//write_com(0x0c);
flag_jian=1;
flag_jia=0;
break;
if(flag==0&&num==1)
flag=~flag;
num=0;
flag_jia=0;
flag_jian=0;
if(flag==0) //????
display_string(0x40+5,"MT");
if(flag_motor) relay=1;
else if(i<Hum_H) relay=0; //?????????
else relay=1;
else //????
display_string(0x40+5,"AT");
if(i<(Hum_L+Hum_H)/2) //???????????????????
relay=0;
else relay=1;
void int0() interrupt 0
delay_50us(20);
if(key2==0)
while(!key2);
flag_motor=~flag_motor;
if(flag&&flag_jia)
//write_com(0x0f);
//delay_50us(1000);
//write_com(0x0c);
//delay_50us(1000);
Hum_H++;
if(Hum_H>=99) Hum_H=99;
if(flag&&flag_jian)
//write_com(0x0f);
//delay_50us(1000);
//write_com(0x0c);
//delay_50us(1000);
Hum_L++;
if(Hum_L>=Hum_H) Hum_L=Hum_H-1;
void int1() interrupt 2
delay_50us(20);
if(key3==0)
while(!key3);
if(flag&&flag_jian)
//write_com(0x0f);
//delay_50us(1000);
//write_com(0x0c);
//delay_50us(1000);
Hum_L--;
if(Hum_L<=1) Hum_L=1;
if(flag&&flag_jia)
//write_com(0x0f);
//delay_50us(1000);
//write_com(0x0c);
//delay_50us(1000);
Hum_H--;
if(Hum_H<=Hum_L) Hum_H=Hum_L+1;
榆林上校
2025-7-22 10:27
謝謝分享
