標題: 51單片機溫度檢測 [打印本頁]
作者: DinosaurKing    時間: 2024-3-12 16:24
標題: 51單片機溫度檢測
#include "reg51.h"
#include "LCD1602.h"
#include "stdio.h"
#include "DS18B20.h"
#include <intrins.h>
#define uchar unsigned char                //宏定義
uchar  code table1[] = "0123456789012345";          //定義數組
uchar  code table2[] = "abcdefghABCDEFGH";
uchar *str1 = table1;        //定義指針,把數組的首地址賦給它
uchar *str2 = table2;          //數組名表示數組首元素的地址
uchar  Temperature_Disp1[] = "abcdefghABCDEFGH";
uchar  Temperature_Disp2[] = "abcdefghABCDEFGH";
unsigned char Key_Value;
uint Temperature;
uint Temperature_Max = 40;
uint Temperature_Min = 20;
sbit L0=P1^0;
sbit L1=P1^1;
sbit L2=P1^2;
sbit L3=P1^3;
sbit Beep=P2^4;
sbit DQ=P2^3; //數據傳輸線接單片機的相應的引腳
sbit LED_Green=P2^5;
sbit LED_Red_Max=P2^6;
sbit LED_Red_Min=P2^7;
sbit motor=P3^0;
void delay_Key(unsigned int time)                   //延時子程序//
   unsigned int i;
   for(i=0;i<time;i++)
unsigned char Key_Scan(void)
                unsigned char Key_Value = 11;
                P1=0xef;            //行掃描初值11101111//
                if (L0==0) Key_Value = 0;
                if (L1==0) Key_Value = 1;
                if (L2==0) Key_Value = 2;
                if (L3==0) Key_Value = 3;
                delay_Key(5000);
                P1=0xdf;           //行掃描初值11011111//
                if (L0==0) Key_Value = 4;
                if (L1==0) Key_Value = 5;
                if (L2==0) Key_Value = 6;
                if (L3==0) Key_Value = 7;
                delay_Key(5000);
                P1=0xbf;             //行掃描初值10111111//
                if (L0==0) Key_Value = 8;
                if (L1==0) Key_Value = 9;
                if (L2==0) Key_Value = 10;
                if (L3==0) Key_Value = 11;
                delay_Key(5000);
                P1=0x7f;             //行掃描初值//
                if (L0==0) Key_Value = 12;
                if (L1==0) Key_Value = 13;
                if (L2==0) Key_Value = 14;
                if (L3==0) Key_Value = 15;
                delay_Key(5000);
                return Key_Value;
void Key_Proc()
        Key_Value = Key_Scan();
        switch(Key_Value)
                case 0:
                        Temperature_Max++;
                        break;
                case 1:
                        Temperature_Max--;
                        break;
                case 2:
                        Temperature_Min++;
                        break;
                case 3:
                        Temperature_Min--;
                        break;
                case 4:
                        Beep = 1;
                        break;
void Display(unsigned char *Temperature_Disp1,unsigned char *Temperature_Disp2)
                Lcd_Show(0,0);        //定位         從1行的第1個位置開始顯示
    while(*Temperature_Disp1 !='\0')           //判斷是否顯示完字符串
                        LcdWrDat(*Temperature_Disp1++) ;                //         把字符串一個一個放到相應位置
                Lcd_Show(0,1);        //定位         從2行的第1個位置開始顯示
                while(*Temperature_Disp2!='\0')
                        LcdWrDat(*Temperature_Disp2++) ;
void Temperature_Proc()
        Temperature = (uint)ReadTemperature();
        sprintf(Temperature_Disp1,"Max:%dC Min:%dC",Temperature_Max,Temperature_Min);
        sprintf(Temperature_Disp2,"Now:%dC        ",Temperature);
        Display(Temperature_Disp1,Temperature_Disp2);
        if(Temperature > Temperature_Max)
                Beep = 1;
                LED_Red_Max = 0;
                LED_Red_Min = 1;
                LED_Green = 1;
                motor = 1;
        else if((Temperature <= Temperature_Max)&&(Temperature >= Temperature_Min))
                LED_Red_Max = 1;
                LED_Red_Min = 1;
                Beep = 0;
                LED_Green = 0;
                motor = 0;
        else if(Temperature < Temperature_Min)
                Beep = 1;
                LED_Red_Max = 1;
                LED_Red_Min = 0;
                LED_Green = 1;
                motor = 0;
void main(void)
        Beep = 0;
        motor = 0;
        Delay500ms();
        Lcd_Init();
                Key_Proc();
                Temperature_Proc();
作者: fosu頑童    時間: 2024-3-26 09:12
建議LZ補充附上原理圖
