標題: 能幫我改一下這個代碼嗎?就是動畫顯示的那里 [打印本頁]
作者: Derive    時間: 2024-2-7 09:38
#include <reg51.h>
typedef unsigned char u8;
typedef unsigned int u16;
#define DOT_MATRIX_PORT P0
#define LINE_SELECT_PORT P2
#define INTERRUPT_PIN P3^2
void delay_10us(u16 ten_us)
    while(ten_us--);
void delay_ms(u16 ms)
    u16 i, j;
    for(i=ms;i>0;i--)
        for(j=110;j>0;j--);
unsigned char heart_pattern[16][16]={0x78,0xFC,0x7E,0x3F,0x7E,0xFC,0x78,0x00,
                                    0x70,0xF8,0x7C,0x3E,0x7C,0xF8,0x70,0x00,
                                    0x60,0xF0,0x78,0x3C,0x78,0xF0,0x60,0x00,
                                    0x40,0xE0,0x70,0x38,0x70,0xE0,0x40,0x00,
                                    0x78,0xFC,0x7E,0x3F,0x7E,0xFC,0x78,0x00};
volatile bit donghua_on = 0;
void display_heart(void);
void init_interrupt(void);
void main(void)
    init_interrupt();
        if (donghua_on)
            display_heart();
            donghua_on = 0;
            delay_ms(1000);
        int row;
  for(row=0; row<16; row++)
                LINE_SELECT_PORT = ~(1<<row);
    DOT_MATRIX_PORT = heart_pattern[row];
    delay_us(1000);
void interrupt isr(void)
    donghua_on = 1;
    EXTI0_IF = 0;
    IT0 = 1;
    EX0 = 1;
    EA = 1;
作者: lkc8210    時間: 2024-2-7 16:01
改啥啊?啥都不說
作者: cedtek    時間: 2024-2-8 10:19
請明確的表達您的需求、現有問題
作者: xxxevery    時間: 2024-2-14 00:13
雖然不知道具體問題說的哪里,但下面這段程序肯定是有問題的
        int row;
                delay_us(1000);
LINE_SELECT_PORT 即P2是8位的,移16位肯定有問題
DOT_MATRIX_PORT = heart_pattern[row];這句里heart_pattern是二維數組,寫成一維數組形式肯定也有問題
