簡易單片機計算器,最基礎的
lsy1219257111
2024-1-17 16:32
簡易單片機計算器,最基礎的
剛學到,求助多功能計算器的設計
代碼:
#include "reg51.h"
#include "math.h"
#define ON 10
#define ADD 11
#define SUB 12
#define MUL 13
#define DIV 14
#define EQU 15
#define BLANK 10
#define ERROR 11
#define MINUS 12
sbit SPEAKER = P3^7;
long Result,VarTmp;
unsigned char code LED[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff,0x86,0xbf};
unsigned char code KeyTable[]={ON,0,EQU,ADD,1,2,3,SUB,4,5,6,MUL,7,8,9,DIV};
unsigned char DisplayNo ,Operate,MS,DisplayBuffer[8];
bit Over,NoError=1,FirstInput=1;
unsigned int BeepTime,DelayTime;
void delayms(unsigned int ms)
{ DelayTime=ms;
while(DelayTime);
unsigned char Key()
{ unsigned char Row,Col,k;
P1=0x0f;
k=P1&0x0f;
if(k==0x0f) return -1;
delayms(20);
k=P1&0x0f;
BeepTime=300;
for(Row=0;Row<4;Row++)
{ P1=0x7f>>Row;
k=P1&0x0f;
if(k!=0x0f)
{ Col=0;
while(k&(1<<Col)) Col++;
break;
while((P1&0x0f)!=0x0f);
k= Row+Col*4;
return KeyTable[k];
void ClrDisplayBuffer()
{ unsigned char i;
for(i=0;i<7;i++)
DisplayBuffer[ i]=BLANK;
DisplayBuffer[7]=0;
void ModifyDisplayBuffer(long num)
{ unsigned char i;
if(num>9999999||num<-9999999)
{ ClrDisplayBuffer();
DisplayBuffer[0]=ERROR;
NoError=0;
return;
ClrDisplayBuffer();
if(num<0)
{ num=labs(num);
DisplayBuffer[0]=MINUS;
i=7;
do
{ DisplayBuffer[ i]=num%10;
num/=10;
i--;
}while(num!=0);
void Calculate()
{ switch(Operate)
{ case ADD:
Result=Result+VarTmp;
ModifyDisplayBuffer(Result);
break;
case SUB:
Result=Result-VarTmp;
break;
case MUL:
Result=Result*VarTmp;
break;
case DIV:
if(VarTmp!=0)
{ Result=Result/VarTmp;
NoError=0;
break;
void KeyProcess(unsigned char k)
{ if(k==ON)
{ Result=0, VarTmp=0,Operate=0,Over=0,NoError=1,FirstInput=1;
ClrDisplayBuffer();
if(!NoError) return;
if(k<10)
{ if(Over) Over=0,VarTmp=0,Result=0,Operate=0,FirstInput=1;
VarTmp=VarTmp*10+k;
if(VarTmp>9999999) VarTmp=VarTmp/10;
if(Operate) FirstInput=0;
ModifyDisplayBuffer(VarTmp);
if(k>10&&k<15)
{ if(Over)
{ Over=0,VarTmp=0,FirstInput=1, Operate=k;
return;
if(Operate&&FirstInput==0)
{ Calculate();
VarTmp=0,FirstInput=1;
if(Operate==0)
{ Result=VarTmp;
VarTmp=0;
Operate=k;
if(k==EQU)
{ if(Operate&&FirstInput==0)
{ Calculate();
Over=1;
{ unsigned char k;
TMOD=1;
TR0=1;
ET0=1;
EA=1;
ClrDisplayBuffer();
{ k=Key();
if(k!=-1)
KeyProcess(k);
void Display() interrupt 1
{ TL0=64536%256;
TH0=64536/256;
if(DelayTime)DelayTime--;
if(BeepTime)
{ BeepTime--;
SPEAKER=~SPEAKER;
P2=0;
P0=LED[DisplayBuffer[DisplayNo]];
P2=1<<DisplayNo;
if(++DisplayNo==8)
DisplayNo=0;
(210.4 KB, 下載次數: 90)
2024-1-17 16:29 上傳
Proteus圖
